Hi everyone
If you don't mind, I guess I need your help to push one step forward my ongoing room correction. I'm not sure being on the right sub-forum, so if so, just tell me .
At this step,
- I've made multiple measurements around my listening point (MMM, via REW)
- I've synchronized these measures in the time domain (to avoid any time shift, via REW)
- I've added the signals to get the average measure (via REW)
- I've used the EQ tool of REW to fit a Harman-like target and to get a first global correction
- I've tuned this correction with the Paragraphic Gain EQ via Rephase.
(NB : I avoided to over-tune by using Q<8 and I avoided to fill the down gaps).
(NB: I've tried to tune the phase, too, with the Paragraphic Phase EQ, but the phase is too messy and I've never succeeded to get good results, so I give up)
- Exporting the impulse file (65536 taps, the right sample rate) and uploading into the convolver
- Final test: the listening test. Until now, I find the correction weird: it sounds bad, not natural at all
That makes me think I overdid the correction. So, I'm going back to the basis and I want to start the correction again from the beginning
Could you advise me about the right way to correct the following (average) measures? Which waveband in priority? In which way?
Thanks for your help
At this step,
