Neumann KH120 Disassembly Pictures
hyperplanar
Los Angeles
Hi all, it seems pretty hard to find any pictures of the KH120's internals online, so I thought I would post these here. Maybe they can be of use to someone! :)
These pictures aren't of my own KH120s. I found them several years ago with great difficulty thru Google Translate on a registration-only Chinese hi-fi forum. I'll also try to include my interpretation of the original poster's comments on each picture.
The enclosure and main screws holding it all together.
There's a gasket between the two halves of the enclosure, which is covered in an oily sealant substance.
The bass reflex port is well designed, with flared endings, multiple openings to reduce resonances, and plenty of damping material.
Seems like a good amount of care was taken to secure the speaker wires so they don't rattle around.
The tweeter. The magnet is very strong. Titanium diaphragm with fabric (silk?) dampening.
Speaker connections are soldered, so no worries about them coming loose.
Spring washers on the screws.
Woofer. The basket looks like the one on the Peerless SDS series, but (according to the original poster) this woofer's impedance inductance is even lower than the Peerless HDS series.
Woofer side view. According to the OP, it handles +-5mm excursion at 50 Hz without noise.
Rear of PCB. Marked "Sennheiser" on the bottom left corner.
Front of PCB. Lots of dampening and sealant material. Two TDA7293 Class AB chip amps, one for the woofer and one for the tweeter. ST33079 and TL074 op-amps.
Closeup of upper half of PCB. The six blue trim pots on the top are used for the factory calibration of each unit.
Bottom half of PCB. This studio monitor uses an internal SMPS.
Rear half of enclosure, which the TDA7293s are heatsinked to.
Joachim Herbert
Munich, Germany
Careful engineering with attention to even minor details.
hyperplanar
hyperplanar
Los Angeles
Couldn't agree more. Seems like a robust design and the BOM cost was wisely distributed into where it counts.
As a testament to their factory calibration and stability, my pair of KH120s consists of one bought used from Guitar Center of unknown provenance and another is a Sennheiser refurbished unit. Here's how their frequency responses compare in an untreated room sitting on the edge of a desk, measurements taken freehanded about 1.5 feet away on their acoustical axis.
Needless to say, the stereo imaging and stability amazes me! :)
Joachim Herbert
Munich, Germany
It is dead silent, though.
Vintage57
Ontario, Canada
Does anyone still use a CRT display? Useless extra magnets on the drivers.....
why would you refer to them as "useless extra magnets"?
Great pictures from OP
Ron Texas
Nice contribution. Looks like the cabinet is cast aluminum.
direstraitsfan98
I do. These will mess up your CRT if you put it anywhere under 2 and a half feet away anyway. Very few speakers are truly magnetically shielded.
thewas
I'm surprised (if) they are using trim pots to set the factory calibration and not just doing online (software setting) calibration.
The KH120 opposed to the KH80 isn't DSP based, but has classic analogue active filters.
