- Joined
- Jan 15, 2020
- Messages
- 6,934
- Likes
- 17,046
No, its glass reinforced composite material.since when it's plastic? as i know is mdf..
Source: https://assets.kef.com/documents/reference/KEF_Blade_Ref_Meta_Tech_Paper.pdf
Don't overestiamte the ability of what we can hear reliable! We don't have a RELIABLE hearing memory, you always have to do A/B with short switching times. 30cm difference in the room can influence low frequency response more as a different tuning. I build complete prototypes to A/B different chassis/membran materials - it's a lot of work to do this properly.I wouldn’t say ‘listening and fine tuning are always the last step’ when designing. I’d say listening, measuring and fine tuning are an ongoing process throughout the design process.
Yes to both. Also you need 2 extra speakers for your kitchen. The sound is especially bad there. Don't sit on your cash, support your local businesses.hello, i already have kh120, do i need to switch to mk2 and if i switch to mk 2, will i need a sub thanks in advance
How big is your room? A do you use them only in nearfield as monitors, or for "Home HiFi" listening in midfield too? I'm thinking about KH120II with SUB and KH150 without SUB. And I'm not able to decide. KH120II are way more cheaper than KH150 and in most frequencies are even better except low bass. My room has longer side only 4,7m and this is exactly 36Hz which can be fully develop nad even boost. It makes me thinking about KH150 only. I think, that KH120II will need SUB for best performance. In case of SUB addition I can't find any reason for KH150. A asked Neumann "specialist" for differences between KH150 and KH120II and except woofer size and cabinet size there are any. Same power, same DSP, same tweeter,....hello, i already have kh120, do i need to switch to mk2 and if i switch to mk 2, will i need a sub thanks in advance
Measurements of a Neumann system in a 4.8m long room: https://www.audiosciencereview.com/...n-a-small-room-subs-ma1-absorbers-avaa.27288/How big is your room? A do you use them only in nearfield as monitors, or for "Home HiFi" listening in midfield too? I'm thinking about KH120II with SUB and KH150 without SUB. And I'm not able to decide. KH120II are way more cheaper than KH150 and in most frequencies are even better except low bass. My room has longer side only 4,7m and this is exactly 36Hz which can be fully develop nad even boost. It makes me thinking about KH150 only. I think, that KH120II will need SUB for best performance. In case of SUB addition I can't find any reason for KH150. A asked Neumann "specialist" for differences between KH150 and KH120II and except woofer size and cabinet size there are any. Same power, same DSP, same tweeter,....
Or just keep the KH 120, and get the KH 750 along with MA1, to most likely improve the bass response. Assuming that he has some flexibility for a good placement of the subwoofer.Measurements of a Neumann system in a 4.8m long room: https://www.audiosciencereview.com/...n-a-small-room-subs-ma1-absorbers-avaa.27288/
My suggestion: begin with KH120II + MA1 if you don't need the extra SPL of the 150. Add a KH750 later, if necessary.
I'm not sure if I like KH750. I would prefer some other SUB as Arendal for example. And SPL is only one parameter, low frequency reach is another one.Measurements of a Neumann system in a 4.8m long room: https://www.audiosciencereview.com/...n-a-small-room-subs-ma1-absorbers-avaa.27288/
The advantage of the KH750 is the calibration that it offers when using the MA1 kit. The KH120 needs the KH750 for calibration while the new KH120II does not.I'm not sure if I like KH750. I would prefer some other SUB as Arendal for example. And SPL is only one parameter, low frequency reach is another one.
Odan ne kadar büyük? A Onları sadece yakın alanda monitör olarak mı kullanıyorsunuz yoksa orta sahada da "Ev HiFi" dinleme için mi kullanıyorsunuz? SUB'lu KH120II ve SUB'suz KH150'yi düşünüyorum. Ve karar veremiyorum. KH120II, KH150'den çok daha ucuzdur ve düşük bas dışında çoğu frekansta daha da iyidir. Odamın daha uzun kenarı sadece 4,7 m'dir ve bu tam olarak 36 Hz'dir ve tamamen geliştirilebilir ve hatta artırılabilir. Sadece KH150 hakkında düşünmemi sağlıyor. KH120II'nin en iyi performans için SUB'a ihtiyacı olacağını düşünüyorum. SUB eklenmesi durumunda KH150 için herhangi bir sebep bulamıyorum. Bir Neumann "uzmanına" KH150 ve KH120II arasındaki farklar soruldu ve woofer boyutu ve kabin boyutu dışında herhangi bir fark var. Aynı güç, aynı DSP, aynı tweeter,....
That's why i linked my measurements. If your room is similar to mine, you can expect a massive room gain just in the roll off area of the KH120II. That's why i suggested starting with the 120II without a sub.I'm not sure if I like KH750. I would prefer some other SUB as Arendal for example. And SPL is only one parameter, low frequency reach is another one.
Your KH120 will not stop working, even when v2 arives. You don't have to switch.hello, i already have kh120, do i need to switch to mk2 and if i switch to mk 2, will i need a sub thanks in advance
Trell has a good point as well, but this would only work with a KH750.
