HarmonicTHD
- Joined
- Mar 18, 2022
- Messages
- 3,326
- Likes
- 4,837
Don’t despair (just ignore). He does this nonsense with absolute regularity in every Neumann and Genelec thread since years. Although people have explained it over and over again, still he comes back.aren't you bored of talking enclosure materials 24/7? Really? Is this really what you can contribute to conversations in an audio science server?
MDF bad. : (
Plastic even worse : (((
Paper drivers fragile : (
Metal dome or soft dome?!?!?
Genelec good but what about Neumann???
What matters is the output. You are like the people who pay 10k$ more on dacs because their PSU is shielded against RF and they have DisCreTe output stage. It doesn't matter what decisions a designer took inside an input-output device. (speakers, dacs, amps) As long as it performs well(and we check the output of the system for that), you do not have to care about anything else.
As long as cabinets do not resonate, it doesn't matter what material the manufacturer used. As long as a material allows complex waveguide shapes without introducing diffractions, that material can't bottleneck the performance of speakers.
Paper used in drivers is not the same with the paper you write on. "Paper" is great because it is light and a woofer has to be as light as possible to maximize efficiency of the system.
Soft Domes start behave like ring radiator drivers in high frequencies hence they start beaming very early around 6-7khz. Bad for controlled directivity.
Genelec & Neumann, both are usually great. Check the directivity index of the speakers within your budget and buy the one which has the smoothest DI and smoothest constant DI behaviour from 200hz to 20khz.
I answered all the questions you are repeating 10 times a day. Can you please move on to asking different and more importantly more performance-relevant questions about speakers? Thank you.
