*NEW* AKG K702 has been measured by Oratory!
czt
It's possible that the Sonarworks sounds most neutral to you, but I wouldn't go as far to use the phrase "not surprisingly", I don't think we should expect Sonarworks to be more neutral than GRAS Harman.
Absolutely. This is one of the main topics of the linked (excellent) white paper. And based on that, they had adequate number of sample units, and their method to determine the reference target is sophisticated, beside the developed proprietary measurement method.
roladyzator
It seems to me that both Harman and Sonarworks started with the same core concept - reproducing the tonal balance of well-behaved speakers in a treated (but not anechoic) room.
It's hard to say which target curve is more accurate without actually listening to the actual speakers in the room that was used for the research but in my experience they can be very close (HD700) or quite different (K371 sounds just weird with Sonarworks to me and with Oratory1990's EQ it's just a little less bass but otherwise very similar sound. No EQ is my favorite).
Except for the HD700, my impression is that the Sonarworks calibration provides more energy at 2 kHz but less at 4-8 kHz in comparison to the Harman Target.
Headphones equalized with SoundID sound pretty similar to me when it "works" for me (Superlux HD-668B, K702, HD700, even Koss KSC75 to some extent). If they can get you speakers to sound similar in tonality, then they did a fantastic job
Reactions: czt
Robbo99999
Robbo99999
I quickly read that White Paper that was linked earlier about Sonarworks, and there were some areas of vaguery where it wasn't clear exactly how they executed the various stages of their process, so you can't really assess how valid the work is, and besides the impression I got was that there could be scope for large variance given they use a panel "of experts" (for listening) as part of their process of evaluation for each headphone (most specifically their "process of calibrating headphones to baseline flat") - so I can see a lot of subjective variation coming into play in their process too. For me there's too many unknowns and what is known looks like there's too much variability & scope for interpretation included that would influence the final outcome. I'm not sold on it all.
czt
Understanding the criticism, but despite their "subjectivity" they still want a common, industry standard, "win-win", target base. (But the industry thinks otherwise.) And in the end every EQ is a compromise (headroom loss, distortion, etc.), just like every product, and every sound produced by audio technology.
Robbo99999
Robbo99999
Well, I think we can agree - headphones are tricky beasts!
Reactions: czt
czt
Just now evaluating K702's sound without EQ and/or with crossfeed only. I'm not excluding that I just end up with small fixed-band corrections here and there on the long run.
Music1969
Hi, like the title says, Oratory measured my K702 I sent him, I've got two pairs and I sent him my old pair from year 2015 (made in China, not Austria). Yes, so Oratory published the result today:
https://www.dropbox.com/s/033kxyf8a0o3iv6/AKG K702.pdf?dl=0
https://www.reddit.com/r/oratory1990/wiki/index/list_of_presets
I've tried his EQ & I do like it, previously I was using my own EQ from a measurement by Crinacle.....he uses a GRAS measuring device too, so both Crinacle & Oratory measurements are compatible with the Headphone Harman Curve that we know & love (some hate though!:D)
Oratory measured my headphone both with the old very worn pads from year 2015 vs new pads which he put on for me, and here's the result of worn vs fresh pads:
Oratory advised me to ignore the increased bass roll off of the worn pads, as he said he "only did the quick measurement type, which doesn't give as accurate measurement results below ~50 Hz", so he said to assume for the worn pad bass frequency response it should just track the same shape as the fresh pads in the sub 50Hz, rather than paying any attention in the graph that the bass decrease accelerates faster than the fresh pads...so you should assume that those two lines won't cross over each other in the bass. Yes, so that's not bad, that's quite easy to correct the frequency response for old pads.
Oratory also did some distortion measurements of my K702 at different input voltages, with the maximum level being the equivalent of 104dB, and here's the results, (I have asked if he'd send me through graphs showing measurements at individual levels as the following graph is a bit congested to read, so I might update the graph if he sends me through what I've asked for):
So we can see that distortion in the bass is not bad, not an issue. There are a couple of distortion peaks at 1250Hz & 2000Hz, which seem to vary significantly depending on playback volume.
Oratory also measured Channel Matching of my headphone:
We can see that channel matching is not perfect here! Oratory did say that our hearing sensitivity in the bass area is quite low so the increasingly large difference in the bass as you go down into the subbass is not as bad as it looks. When I get my headphone back I'll be doing Channel Matching EQ on them so I'll be able to flip channel matching on & off whilst listening to Oratory's EQ, thereby I'll see if I can recognise any benefit of channel matching.
Group Delay:
Excess Group Delay:
Not sure on significance of difference to above graph.
EDIT: Oratory did say he'd have a go at finetuning the EQ some more, so it's possible that the EQ will be updated in the near future, so I'll edit this post if anything changes. I may also add my own personal tweak(s) I've added to Oratory's EQ. I'll also probably be editing this post to further to put the distortion measurements into better perspective re the dB values rather than the input voltage, and that graph may be updated with seperate graphs done for each level so it's more readable. I'll also try to see how those distortion measurements equate to Amir's standards that he sets, for instance the graph where he draws the +40dB threshold line on his 94dB distortion graph, or this may come to light in the discussions in this thread. I'll also update this post as more is learned through people's comments & analysis in this thread, and I may include a K702 EQ I've done from Crinacle's measurement too, so this may become a K702 EQ thread as well as initially displaying Oratory's measurements which he did just this week.
Finally, I'd like to say thanks very much to Oratory for measuring my headphones & the great work/contributions he makes to the headphone community....nice one Oratory, you're much appreciated!
@samwell7 , @Ravix , @bobbooo , @jhaider , @thewas , @Nango , @Seta Seta Pop , @Jimbob54 , @Bob-23 , tagging you all as you either have the K702 or expressed interested in Oratory's measurement & EQ of them.
EDIT 8/7/21: Oratory has measured my second (newer) K702 and results located at this post:
https://www.audiosciencereview.com/...as-been-measured-by-oratory.22992/post-819729
Very different to @seanolive 's recent K702 measurement. Especially bass
I wouldnt use oratory's EQ if my sample was the same as Olive's.
At least you have a measurement for your own sample though.
Robbo99999
Robbo99999
Yes, Sean Olive's is very different to everyone else's measurement. He's had one of the newest serial numbered K702 that anybody I've seen has measured, he got it directly from the warehouse I think he said. Yeah, if your unit measured like Sean's there it would barely need any EQ, but I think his result is more of an outlier currently. Sean's unit he measured was even newer than the latest one I bought off Amazon a couple of months ago (you can tell by the production number printed on the headphone). I'd be surprised if all the new K702 measured like that, I think we have to treat it as an outlier currently.
davidk
Hi! I just stumbled upon on this forum a few days ago when I read the post about Sean Olive's measurements. I bought my K702 2nd hand more than a year ago but I was never sure about its age. According to the information found here mine is roughly 4-5 years old (SN is a bit above 171000). I really like it with Oratory's EQ but was curious if I could find a better one to start with (based on the SO post). I was lucky enough to get one very close (SN is 241100 range). The "trick" was that it was an open box model and I had the chance to check the SN before purchase. Now I have no idea if it is already burned in or not, but I can tell for sure that it has definitely more clamping force than my old one and it has definitely more bass/is a bit warmer overall, probably a bit less width in soundstage (only a tad, but still noticeable). I know clamping force affects bass so I can't tell if it's that or a better sample, but it definitely has a somewhat different tonality: when using the same (updated) oratory preset I had to lower the 105 Hz value as it was a bit too much at 5.5dB. 2-3dB seems just fine, and I had to lower the decrease at 5.5kHz as it took away a bit too much of air compared to my old model. I don't have good enough ears to confirm anything and as I said clamping force is different but I definitely like this new one better than the old one. Someone who had an old and bought a new probably can share his opinion about the clamping force difference.
Robbo99999
Robbo99999
About clamping force on K702, it slackens a lot over the years as you wear them, the elastic gets looser, so you can't really compare a newly bought set vs a multiple year old set if you're wanting to compare the clamping performance between them when they were both new.
Deckard01
Hi All, an update on Oratory's EQ, he's released another updated measurement & EQ of the K702 which he released back in October, I've only just realised he's updated it, here's the link to the file:
Basically the new measurement is showing the K702 to have more bass and be a warmer headphone than the previous published versions, so I'm guessing he's measured a few more K702 and therefore changed his published measurement. Therefore his new EQ will make your K702 sound noticeably brighter. I imported his latest measurement into REW to compare against one of his older published measurements, here you can see the difference:
The brown line in the above graph is the latest published measurement (named in the graph as "K702 v4 normalised"). You can see the main change is below 555Hz, where you can see he's described the K702 as now having more energy below 555Hz - so he's basically saying the K702 is a warmer headphone than previously thought. Of course this will make your EQ sound brighter if you use Oratory's latest EQ, as he's not boosting the bass as much and is also providing a bigger cut in the muddy regions of 100-300Hz. He's also decided not to boost the bass all the way down to 20Hz so he's got rid of that silly 24Hz Low Shelf Filter he used to have in there, so now he's only boosting parts of the bass area by +5.5dB rather than the silly +10dB he had before - (note: he was only boosting the very low subbass areas by +10dB before rather than the 5.5dB he's doing now so the audible difference between the two is not quite as large as it seems on the surface). I recommend you try out his new EQ as it is significantly different! (because he's changed the energy below 555Hz in a broad & significant manner) Here are his latest filters and a link to the file directly again:
Rob do you know if I can I use this EQ for my K701? I only use the Oratory which is better from the default sound clearly.
By 701 are old enough Austrian made. Thanks!
roladyzator
Of course you can. While using presets made for other headphones is not recommended for achieving perceptually neutral frequency response (compliant with Haman Target), there is still room for deviations from that idealized frequency response that people may prefer.
And without measuring your individual unit, you have no guarantee you'll actually hear what is shown in the graph.
Robbo99999
Robbo99999
Hi, it's probably better to use the K701 EQ that Oratory has done because even though they're similarities between K701 & K702 I don't think we can call them the same headphone at this point, following is where you can find the K701 EQ:
Yep, so you wouldn't use the K702 EQ, you'd use the K701 EQ, because you have the K701.
Deckard01
I use Oratory eq, but i was thinking if your updated eq could suit to K701.
Thanks for all
Robbo99999
Robbo99999
Thanks for all
The post you quoted was not my EQ, it was Oratory's EQ of the K702. I do have my own EQ I use on my K702's, because I have 4 units of them and I've measured them myself, it's a bit complicated but I outlined it at this post:
Theoretically the K701 EQ that I linked you earlier, from Oratory, should be the one that should be the most valid, but you could try my K702 EQ if you like.....but Oratory's K701 EQ should theoretically be the most valid one for your K701, because you've got the K701 & not the K702, even though they're similar.
roladyzator
@Deckard01 If you're looking for alternative EQ for K701 to try out, you can consider getting a trial version of Sonarwork's SoundID.
They have a preset for K701 and if you like it, there are ways to continue using it after the trial expires.
Soria Moria
Norway
That's really good. I was looking for motivation to buy a 702 to have next to my 560S just like you. :)
But we don't know if he just got really lucky or if the headphone is just better now?
Robbo99999
Robbo99999
I've never seen any K702 measure like the one Sean measured, but he did measure a newer one (higher production number) than any of mine, even though my latest one was bought pretty recently (and well after his measurement was published), my latest one is 224865. I bought my latest one in February, just checked. So if you buy one now I don't know how you can guarantee it's not gonna be an older one than the one Sean Olive measured. I feel that there are large stock piles of this headphone. I also feel that Sean's measurement was a one-off, but obviously I can't be sure of that.....it feels like an aberration to me. However, it would be very cool if the newest ones did measure like the one he showed, albeit we'd need to know from which production number upwards it occurred.....I think it's a one off though, something up with that measurement or headphone......I'd like to see future measurements of newer K702 though to see how they stack up though. @oratory1990 , if you ever get your hands on any newer K702 than the one Sean measured it would be very interesting to hear if it measured like the one Sean measured.
Soria Moria
Norway
Which model number does he have? I'll see if the one I'm getting is younger or older. I sadly can't measure it but I can at least tell you if it comes with flat bass or not.
Robbo99999
Robbo99999
241706 is the number of the headphone measured by Sean. I posted this up back in February, found the post:
For curiosity this is where Sean posted the measurement:
