Roland68
A very simple one and not particularly long, about 80-100cm. Since it is only for ARC, HDMI 1.4 is enough.Does anyone know what version of the HDMI cable comes with the amplifier?
I have an amplifier connected via this HDMI cable to the TV, periodically the TV loses connection with force, the connection is displayed on the amplifier itself, and only switching the output on the amplifier itself helps, I thought maybe replacing the HDMI cable will correct this error.A very simple one and not particularly long, about 80-100cm. Since it is only for ARC, HDMI 1.4 is enough.
In such a case, it obviously makes sense to try a different cable.I have an amplifier connected via this HDMI cable to the TV, periodically the TV loses connection with force, the connection is displayed on the amplifier itself, and only switching the output on the amplifier itself helps, I thought maybe replacing the HDMI cable will correct this error.
I can’t fully understand whether the problem is in the TV, cable or amplifier, I read several forums and no one had such a problem, ARC either did not work at all or worked completely without any problems.In such a case, it obviously makes sense to try a different cable.
Look for a cable that is as short as possible and as long as necessary. It doesn't hurt to get one with a higher specification.
Above all, pay attention to enough positive recessions and as few negative ones as possible.
Unfortunately, it is not very possible to find out the version from most HDMI cables (which are not packaged) afterwards, but I don't think it is something super new and of high quality, because it is thin, short, and does not look like a quality piece. I don't even use it because it doesn't reach from the TV to the amplifier. The included power cable is also a pretty lousy PC power cable, so he got a better one instead. The USB cable works, it serves the purpose, but it is not suitable for distance and the DAC also deserves better.Does anyone know what version of the HDMI cable comes with the amplifier?
I once had a similar problem, which was just due to bad plug contacts. After replacing the cable I no longer had any problems.I can’t fully understand whether the problem is in the TV, cable or amplifier, I read several forums and no one had such a problem, ARC either did not work at all or worked completely without any problems.
I didn't find anything about HDMI CEC in the specifications of the amplifier. But we can turn the power on and off using the remote control and knob. I think this is controlled by the processor. So HDMI CEC can be programmed if desired.Anything above 1.4 for ARC is good and works, but why CEC doesn't work properly (auto on/off) is still a good question, I don't know if the cable could be the problem here as well or if it's more of the software/hardware crippling between devices
Yes, it might not work on this device, because the manufacturer also indicated it back to me. According to the definition of the HDMI standard, "CEC wiring is mandatory, although implementation of CEC in a product is optional", so I wrote to them to program this function, because it's a joke, since it's only about interpreting some understandable commands.I didn't find anything about HDMI CEC in the specifications of the amplifier. But we can turn the power on and off using the remote control and knob. I think this is controlled by the processor. So HDMI CEC can be programmed if desired.
SMSL support does not send an answer, but if you impatiently write there for a long time, it will be transferred to Aoshida, they will answer, but they don't really understand technical things, so they will direct you (if you let them) to the seller, let him struggle. ;-)I'm having a weird issue where my AO300 is extremely sensitive to electrostatic discharge while wearing headphones. It's a similar issue to the one being reported by these C200 users where their unit would stop working after they removed their headphones. In my case, the unit keeps working but it does some sort of soft reset. I've reached out to Aoshida and SMSL support but haven't heard back from either of them for a few days. If anyone has some advice, I'd appreciate it. I've already tried the firmware off the support site and from this thread. The issue is still there. I may just return this back to Amazon which is too bad. I otherwise am enjoying the unit.
There was talked about grounding in that topic, about AO300. Therefore, you can try soldering a small piece of wire from the ground pin of the electrical outlet to any screw that is screwed into the case of device. This is my amplifier for example.I'm having a weird issue where my AO300 is extremely sensitive to electrostatic discharge while wearing headphones. It's a similar issue to the one being reported by these C200 users where their unit would stop working after they removed their headphones. In my case, the unit keeps working but it does some sort of soft reset. I've reached out to Aoshida and SMSL support but haven't heard back from either of them for a few days. If anyone has some advice, I'd appreciate it. I've already tried the firmware off the support site and from this thread. The issue is still there. I may just return this back to Amazon which is too bad. I otherwise am enjoying the unit.
The pentaconn 4.4mm is an unbalanced there, it have only three wire.1x Pentaconn 4.4mm, to plug balanced headphone/IEM
Yes, you may be right, it seems. But then I don't understand something, do they even produce unbalanced connectors in 4.4mm size?The pentaconn 4.4mm is an unbalanced there, it have only three wire.View attachment 364251
Typically this 4.4mm pentacon is a balanced connector. For example, in my Fiio K7 it is balanced. But not in SMSL AO300. If we look at the CS43131 DAC block diagram, we will see that there is no balanced headphone output. And since in this amplifier the headphones are connected directly to the DAC headphone output, it simply cannot have a balanced output. I think that the pentaconn is implemented to be able to connect balanced headphones without any adapters, directly to the amplifier. And this is a good idea, and also simple and inexpensive to implement.Yes, you may be right, it seems. But then I don't understand something, do they even produce unbalanced connectors in 4.4mm size?
I appreciate the suggestion. I didn't go through with the full soldering but used a connector to the ground plug instead. So that may have an effect in this not working. But I just tried this with 3 different screws attached to the case: this screw, one screw attached to the front faceplate, and one screw on the other PCB. Unfortunately, none of the options solved my problem.There was talked about grounding in that topic, about AO300. Therefore, you can try soldering a small piece of wire from the ground pin of the electrical outlet to any screw that is screwed into the case of device. This is my amplifier for example.
It's a pity... I did this to remove low-frequency hum. This partly solved my problem.Unfortunately, none of the options solved my problem.
YesHi, can anyone tell me if the amp turns itself on as soon as the power is switched on? I want to connect the amp to a switchable power strip.
Ready for useThanks! Is it then in standby and needs to be woken up or is it ready for use?
