New S.M.S.L. M300 SE 120$
taudier
*newbie alert*
Recently picked this up as part of a modest desktop build for work — casual listening, I’m a Graphic Designer — and there’s 2 things that are bugging me, so I’m here asking for advice before I return the unit.
1. Before the audio source starts playing and when it stops I get a ‘pop/pff/static’ kinda sound. This happens before/after tracks on Apple Music (not so bad here as it’s before/after an album or playlist) and on YouTube (all the time, and when nothing is playing).
2. Audio often cuts out for a split second. It’s still streaming so it’s not a connection issue (cable or internet). This happens maybe 5-8 times a day, I listen for about 8 hours straight.
Issue 1. I could live with but not 2.
I’ve tried different ports and cables, directly into my laptop and laptop via a usb hub. I’ve also raised the DAC up to help airflow as I wondered if it could be getting too hot. The issues are still there.
Setup is as follows:
16” MacBook Pro > USB C to USB C > M300SE > XLR > Kali Audio LP6 V2
Is the first issue expected behaviour? Any ideas what might be causing a the second? Indecently neither of these issues are present when connecting via Bluetooth.
Short term lurker on these forums but I’ll be sticking around — such a valuable resource.
it has already been reported and discussed here : 1. is automute 2. is CS43131 runing in class H (https://reference-audio-analyzer.pro/en/demo-cs131.php#gsc.tab=0). There are various workaround for 1. if annoying you. For 2. you have to live with it.
Gordon Shumway
Argentina
*newbie alert*
Hi! I've reported the same "pop/pff" noise at the begining or end of the playback, but only happens via the headphone output and with the first song/video/source, in continuous playing, i.e. with amazon music, i dont hear it before/afeter every track. Is this the same situation with yours?
About the 2nd issue, did you try with another DAC? it reminds me of my issues with a HP elitebook and a Lenovo T14, this "split/stop" for a second happened to me in both devices with any usb powered dac, like fiio K1, Fiio E10k-tc, and of course the M300 SE, fortunately my main setup is a desktop, where this isuue does not exist.
taudier
Leonm771
*newbie alert*
I have issue2 very often now. No idea why is it always happen.
And then I checked the microsoft management console - event viewer.
I found something interesting,
xmos_s_usbaudio
-Get Device Descriptor failed.
-Prepare Set Configuration failed.
-Unable to retrieve language ID list.
-Audio Controller initialization failed.
-Unable to retrieve Serial string.
-Unable to retrieve Product string.
These errors happen every few seconds.
Maybe the USB cable is the problem??
moonman
Ssor
xmos_s_usbaudio
Different cables tried, different ports on the MacBook, plus a usb hub. Also tried caffeine for Mac to try and try and keep the port ‘alive’. Not luck yet.
Zek
Your homepage shows me this...
bilifen
lurk-town
So some more information about the sound quality of the M300Se after a successful SW update:
The microclicks are still there, but! with the setting Digital Filter 5 NOS there is no such thing!!!
At least I don't hear anymore.
That says the whole problem lies with the digital filter on chip.
I would argue that CS43198 and CS43131 sound best on Filter NOS anyway, I could see it on my other devices with the same chipset as well.
!In addition, I don't hear any microclicks with the setting: Fixed. This is very good news! [...]
Received the M300SE, was preinstalled with v1.1.
Same behavior, no clicks with filter 5 (NOS), but clicks with every other filter.
Combined with the A20h and the Sennheiser HD800 I have enough power to prolly blow my ears out.
Coming from the Xonar U7 the sound feels different but I can't really pinpoint it. Want to do some A/B tests, hopefully I'll actually do them.
MezzoMix
Germany
Just wondering, would this be an actual upgrade coming from a Focusrite Scarlett 2i4 2nd Gen?
I'm looking for something with multiple inputs (would actually love to have an analog input with just passthrough functionality, but in the DAC world this seems not very common), balanced outs and a volume knob.
Leonm771
xmos_s_usbaudio
update this post after almost a month.
I change the cable for m300se , what cable did i use? random samsung buds charge cable.
Not kidding, it fixed \. I have not seen that weird disconnect-connect issues almost a month.
Antz123
Between S.M.S.L. M300 S and SMSL D-6s Balanced, which one seems to be better. I am very noob in this space so just trying to gather perspectives.
GGroch
Denver, Colorado
I think you will get multiple perspectives. They are very similar so it will come down to personal preference. Actual difference for most people is small.
There will be no audible difference when using DAC functions through the Balanced Outputs. The D-6s specs a little better, but both spec far better than human ears can discern.
The D-6s has a more sophisticated Bluetooth receiver, with both aptx-HD and LDAC. The Bluetooth receiver is SBC only on the M300 SE, so you might hear that difference if you play from a Bluetooth device that supports fancier codecs a lot.
The M300 SE has a headphone amp which is plenty good enough for most headphones, the D-6s does not.
The remotes are the same.
Both are very well built, but of course they will look different in your home.
The M300 SE is cheaper, arguably a better deal. Personally, I get more of an endorphin release from getting fantastic performance per $ than I do from better but inaudible DAC measurements, so I like the M300 SE.
staticV3
D-6s:
-proper RCA ports for single-ended outputs
-support for aptX HD, AAC, and LDAC
-can output 5V Bal/2.5V SE
-$200
M300 SE:
-single-ended Line out via 3.5mm
-built in headphone Amp
-only supports SBC
-4V Bal/2V SE
-$130
The raw sound quality is identical between them.
The rest are creature comforts that you have to decide if they're valuable.
GGroch
Denver, Colorado
I just updated to the 23H2 release of Windows 11. This is CoPilot (ChatGPT's) comparison of the D-6s and M300 SE:
"There is no definitive answer to which DAC is better, as different DACs may have different features, performance, design, and sound preferences. However, based on the web search results, I can provide some information and comparisons between the SMSL M300 SE and the SMSL D-6s DACs.
Both DACs are made by SMSL, a Chinese company that specializes in audio products. They are both compact and affordable desktop DACs that support high-resolution audio formats, such as PCM up to 768 kHz and DSD up to 512. They both have USB, optical, and coaxial inputs, and both single-ended RCA and balanced XLR outputs. They both have remote controls and display screens
The main difference between the two DACs is the DAC chip they use. The SMSL M300 SE uses two Cirrus Logic CS43131 chips, while the SMSL D-6s uses two ESS Sabre ES9039Q2M chips. These chips have different architectures, features, and sound characteristics.
The Cirrus Logic CS43131 is a low-power, integrated DAC and headphone amplifier chip that supports MQA decoding, a proprietary technology that claims to deliver studio-quality sound in a smaller file size. The ESS Sabre ES9039Q2M is a high-performance, 32-bit, 8-channel DAC chip that features a patented 32-bit HyperStream II architecture and a Time Domain Jitter Eliminator.
According to some reviews and measurements, the SMSL M300 SE has a slightly lower noise floor, higher dynamic range, and lower distortion than the SMSL D-6s. The SMSL M300 SE also has more filter options, including a minimum phase filter that preserves the original phase of the signal. The SMSL D-6s has a higher output level, more input options, including Bluetooth 5.0 with aptX HD and LDAC codecs, and a larger and more colorful display screen.
In terms of sound quality, the SMSL M300 SE is said to have a more natural, smooth, and detailed sound, with a slightly warmer tonality and a wider soundstage. The SMSL D-6s is said to have a more analytical, crisp, and dynamic sound, with a slightly brighter tonality and a more precise imaging. However, these impressions may vary depending on the source, amplifier, headphones, speakers, and personal preferences of the listener"
Not bad, especially for recently released products. CoPilot does report links for each of its assertions which I did not print.
I learned a few things.
One of them is that AI is not immune from expectation bias that it disguises with "It is said". Famous politicians do that too.
Toku
Japan
Everyone who participates in ASR is always interested in numerical data when comparing products. However, these numbers are far below the level that humans can hear, and it is extremely difficult to actually recognize the difference.
When comparing multiple products, the most important thing for me is stability of operation. There are many DAC products on the market, but only a few of them have all functions working properly. Most of these products have some kind of problem.
When comparing the D-6S and M300SE, we see that they operate stably. Unfortunately, we have seen several reports of trouble on the web that seem to be caused by the newly adopted CS43131 chip in the M300SE.
Therefore, in order to avoid disappointment after purchasing, I think you should pay more attention to information on the actual operating status, rather than just looking at the numbers.
