New Soncoz Headphone Amp coming soon?
Racheski
Chicago
Somebody on Drop posted these. Appears to be fully balanced with a digital display.
cursive
Looks awesome, really like their designs, and I'm a sucker for amber colored displays. If you look closely you can see a "PRE" option on the front screen as well, very happy to see a pre amp mode as this is what's sorely lacking on the SMSL SP400, and Gustard H16 amps.
lizhuoyin
NH
IN - for input selection, Single ended or Balanced
HPA - for headphone amp output, Single ended or Balanced
PRE - for preamp output, Single ended or Balanced
V - for Volume control, both for HPA and PRE???
G - for HPA gain???
cursive
G - for HPA gain???
Good call, hopefully that means you can turn off the preamp outputs when using headphones, and vice versa. From the labeling maybe it just allows you to change the output jacks.
Ben1987
ChengDu,PRC
IN - for input selection, Single ended or Balanced YES
HPA - for headphone amp output, Single ended or Balanced YES
PRE - for preamp output, Single ended or Balanced YES
V - for Volume control, both for HPA and PRE??? YES
G - for HPA gain???
Both for HPA and PRE gain.
preload
California
Not bad but would benefit from a slab aluminum faceplate and panel mount heavy duty rca jacks. Also would like to see panel off pics.
vlydog
I emailed Soncoz in March and this was their response:
"Thanks for your interest in SONCOZ products. Yes, we will launch the headphone amplifier SGA-1 soon. It will match our DAC SGD1. We will post pre-sale information on ASR late next month probably."
Racheski
Racheski
Chicago
Over/Under is $499. I'm taking the over.
