New to the audio game - Need help w/ Setup dx3 pro+
rifat10467
Hello folks,
Not an audiophile by any means, but I enjoy good audio.
I updated from a 58x jubilee to hifiman edition xs and topping DX3pro+.
I looked through the booklet for the topping and it's a foreign language.
Any tips on setting this up?
Youtube doesn't seem to have setup guides.
For instance, the gain is -99 to 0. How can I get to positive?
total noob, sorry.
antcollinet
UK/Cheshire
Hello folks,
total noob, sorry.
0 is full volume.
The book might have english in the second half.
If not, the one you can download here has an English section:
dx3-pro-user-manual
eddantes
If you are listening from your PC, get yourself EqualizerAPO and start learning how to apply EQ curves to your phones. Then when you've experimented - go to AutoEQ, select your phones, select EqualizerAPO (either parametric or graphic) download the configuration file, and apply the curve. In this way you will have 99.9% of all the performance most normal people need :).
Aaaaand theeeennn - then you can deviate - as per your preference; because maybe you like things a bit differnet than most people - and that is OK.
antcollinet
UK/Cheshire
It might make sense if he just figures out how to use it first - before getting bogged down in equalisation.
Limopard
Germany
The M key on the remote switches the gain. There is low (+6) and high (+19; GAIN in the display lights up). Afterwards the volume is still from -99 to 0, but it is louder with the high gain setting. With a HD 600 my listening volume is between -46 and -37, depending on the music's inherent loudness.
The FIR key on the remote switches between 7 digital filters. The effect (to me) is close to non-existent.
R
rifat10467
Very helpful information here.
All the video reviews I saw on youtube did not have a (-) before the gain. Any reason as to why mine is that way?
antcollinet
UK/Cheshire
Can you point us to an example - link to video AND time where this is shown.
The reason for 0 being full volume is this is the level at which the music is encoded in the digital signal (Full scale). All the volume control for a DAC can do is turn it down from there. Hence negative numbers for "less than full scale"
IAtaman
Congrats on your purchases, both are excellent devices for enjoying nice music! :)
I dont know DX3 but I suspect you might be confusing the gain of the amplifier with the level of the DAC.
Digital audio signals are scaled in such a way that the highest level that can be achieved would be zero and anything below that would be a fraction of it, usually referred to in decibels, or dBs. What you are seeing on your screen is probably the level of the DAC. I suggest you set it to -3dB and leave it there.
What others are talking about when they say gain is the "multiplier" of the headphone amplifier. That number would be most likely positive. Leave it at low gain if it gets loud enough for you, and if not switch to high gain, but before you do so, bring the volume down on the PC to make sure it does not get too loud suddenly.
R
rifat10467
Thank you!
