Newby here with some question( EverSolo DAC Z6/Z8)
adin
Hi everyone, I am tempted to buy one of the relatively recently appeared DAC on the market.
I didn't really find many reviews about it, but I think it has the same processor as the SU-10 DAC, but at half the price.
EverSolo DAC-Z8 by Zidoo has 1 x the latest ESS Sabre Flagship ES9038Pro DAC which has 8-channel decoding capability and MQA.
-My question is if I can connect it to my Bluesound- node 2i streamer. The DAC in the node2i (which I connected to a Denon-amplifier with flor speakers) doesn't do its job very well and I need something better.
-maybe someone can guide me, sorry for the language I'm not a native speaker(I'm from EU)...Thank you!
fpitas
Northern Virginia, USA
It's good that it has a quality DAC, but the devil is in the details, as they say. They may or may not have designed the surrounding circuitry well.
staticV3
You can plug an external DAC into the Node 2i via Toslink or Coax Spdif.
Since the EverSolo DAC-Z8 has both of those, you can plug it into the Node to bypass the Node's internal DAC.
Please don't focus on the DAC chip too much. For example the ES9038Q2M chip can perform like this:
or like this:
What matters is not the components that go into the DAC, but the measured sound that comes out.
antcollinet
UK/Cheshire
Hi
In what way does the built in Dac not perform well for you.
Even though it didn't measure brilliantly here, the level of distortion is probably still inaudible, and it is unlikely you will get better sound from a different DAC. You could well end up spending £600 or so and end up with no improvement.
Alternatively if it is something other that the sound quality that is bothering you, then go for it.
staticV3
Here are measurement of the DAC-Z8: https://www.l7audiolab.com/f/eversolo-dac-z8/
It performs well.
However, with the Topping E70 you get essentially the same measured performance at half the cost.
And there are $100-150 DACs that'll give you the same audible performance as the DAC-Z8 (human ears are not that good).
@adin what Denon amplifier are you using?
JSmith
Algol Perseus
Not here as yet, however L7;
Also, welcome to ASR. :)
JSmith
A
adin
It performs well.
Hi, I've it for several years, it's a entry-level receiver Denon-AVR X1500H with Wharfedale Evo 4.3 speakers . I think the Topping E70 it' very good but doesn't know the MQA-Tidal format and the processor is a class below the Z8 .I only listen to Tidal-HiFi with Roon and Spotify.
I initially set my sights on a german product, RME-2DAC FS with DSP(Equalizer)- best of the best, but the problem is the same, no MQA built in. The DAC in the node2i sounds weak somehow, it has no dynamics,... but it's good for the streaming and software platform. I think Z8 is the same or better than SMSL-SU10.
antcollinet
UK/Cheshire
..... The DAC in the node2i sounds weak somehow, it has no dynamics,... but it's good for the streaming and software platform.
Again - what is it that makes you think it is the DAC that is the problem - and not the amp, or speakers?
A
adin
Surely the speakers are not the problem nor the amplifier, it sounds flat without dynamics, as I wrote above.
staticV3
Since it doesn't have XLR inputs, buying an expensive balanced DAC is a bit of a waste of money.
Ah I see, you want MQA support.
In that case, you should know that MQA is a bit of a scam. Goldensound did a brilliant video on it on YouTube (Part 1, Part 2).
and the processor is a class below the Z8.
Again: please stop focusing on DAC chips and "classes" of hardware.
The E70 and Z8 measure the same and therefore sound the same. Doesn't matter what chip is in them.
If you want to try an external DAC to make sure that the Node 2i's built-in DAC is the problem, then I recommend you try the SMSL C100.
It supports MQA and sounds identical to the Z8, Topping D90SE, or any other high performance DAC at $1000 or more.
They are all 100% transparent with no sound signature of their own.
If the issue persists even with the C100, then you can be sure that the problem is somewhere else.
If the issue is gone, then you'll have fixed it for a fraction of the cost!
fpitas
The DAC would be about the last thing I'd suspect, honestly. Speakers are the wild card in a modern system.
antcollinet
UK/Cheshire
Far more likely to be problems with the speakers, or how they are interacting with the room, than it is anything to do with the DAC.
A
adin
XLR inputs help? I thought RCA outputs it was enough.
Yes, I understand about MQA but the best quality I can get via streaming in the area where I live is from tidal. Spotify is ok but it's only mp3.There would be qobuz, but it is not available at my place.
A
adin
Last year I bought a pair of Wharfedale Evo 4.3 speakers, what can I say...
staticV3
XLR inputs help?
XLR cables don't pick up electrical interference. In an environment with lots of RF, or when you need longer cable runs, XLR is preferred.
Maybe Deezer? That's lossless as well.
As for Spotify vs Tidal, I think I'd rather have Spotify's Opus encoding than whatever mess MQA is doing to the masters (see the video).
A
adin
I wonder if Z8 is work better than RME ADI-2DAC or SU-10/9pro...
