Objective and Subjective Audio
omm0910
Hoped to ask people's views and about experimental results anywhere, on these old audiophile theories:
- amps need a "break in" period
- speakers need to "break in"
- you need big thick cables
Certainly it would be possible to run those SINAD graphs every 100 hours on an amp and look for changes. Similarly speakers could be tested for response changes over time with the spinorama. Also SINAD could be used to see any changes resulting from different interconnect and speaker cables.
q3cpma
France
- No.
- If break-in there is, it's counted in seconds or minutes; just the time needed for the surround to reach a stable compliance.
- Maybe depending on the distance (I think?). What's for sure is that you don't need to put a lot of money in it.
solderdude
The Neitherlands
- amps need a "break in" period = No, but they may take some time to reach optimal working temperature after switch on.
- speakers need to "break in" = Some may change somewhat but speakers are usually designed with units that have reached their intended specs.
- you need big thick cables = yes with longer cable runs, no with short runs but it will never hurt to use thick cables but might with thin lamp cords.
- Certainly it would be possible to run those SINAD graphs every 100 hours on an amp and look for changes - Yes, you can do that but nothing will change. With some amps when the proper working temperature has been reached you may see small (inaudible) differences from cold. Not because of 'run-in'.
- There will be NO differences between interlinks and speakers cables over time. That said when speaker cables corrode over the years this may present some issues.
Jimbob54
Plenty of discussions and even measurements on some or all of those topics on here if you search- feel free to post links back on here to the ones that interest you
Joachim Herbert
Munich, Germany
How polite these answers are.
No, depends, not really.
Killingbeans
Bjerringbro, Denmark.
O
omm0910
Observations:
- Got a lot of replies quickly wow
- Impressively polite despite that
- Yes I was lazy and didn't do my own fishing
So now I feel safe bringing up a follow on question, "the warm tube sound". Has this been analyzed and dissected as simply certain measurable changes to the signal. Is anyone selling a "tube filter" that processes a perfectly flat amp and transmogrifies it into "the warm tube sound".
I've always been skeptical that speakers need break in, because its like, that implies that they change physically, and I had trouble thinking that the designers select some material that somehow, changes for 500 hours, but then stops changing then once its dialed in. I suppose its possible there is something outside the measurement devices. Or that there is some brain neuron adaptation that takes place, though this would imply that its different to "break in while you listen" and "break in by leaving the system running over the weekend while you go out of town." Anyway I see some other threads here that may treat this issue so I will also look there.
Joachim Herbert
Munich, Germany
Observations:
Yes and yes. Look at pro audio saturation stuff, exciters or simulation. They sell you every distortion you might wish for and then some.
Be prepared to pay.
Jimbob54
Observations:
Not sure if there is a one button solution- but I suspect a combination of EQ for the freq response and "distort" from @pkane https://www.audiosciencereview.com/...lity-of-distortions.10163/page-13#post-501240
might get you there.
Killingbeans
I think you are sort of on the right track here. The difference between the two types of "break-in" being that one is about accepting the changes (imaginary or real, doesn't matter) as the new 'correct', while the other purely relies on the powers of expectation bias.
