mhardy6647
- Joined
- Dec 12, 2019
- Messages
- 11,431
- Likes
- 24,804
Home
Dayton Audio MK602X 6" 2-Way Bookshelf Speaker PairDayton Audio MK602X Bookshelf SpeakersThe MK Series of home speakers from Dayton Audio are the best way to add rich sound with elegance and sophistication. Built to last, the MK series makes it easy to listen to for hours and hours with it non...
www.parts-express.com
Quite a bit pricier than the original, smaller morph.
I know that "we" (@amirm , that is) reviewed the MK402X (he seemed to like it, too), but I wonder if this new larger/pricer version might be worthy of scruitiny. It's reputed to be a bit more sensitive @ 87 dB/watt@ 1 m vs. 84 dB/watt @ 1 m spec'd for the smaller one).
Specifications
Design: 2-way vented bookshelfWoofer: 6" high excursion driver with a glass fiber cone
Tweeter: 1" soft dome
Finish: Black vinyl
Power handling: 60 watts RMS/120 watts max
Impedance: 4 ohms
Frequency response: 45 to 20,000 Hz
Sensitivity: 87 dB 1W/1m
Crossover: 2-Way 3.3kHz crossover with 2nd order slopes
Terminals: 5-way gold plated binding posts
Port tuning: 45 Hz
Dimensions: 12-3/4" H x 7-7/8" W x 8-3/4" D (depth includes removable grill)
I keep hopin' to find an inexpensive "world beater"/diamond in the rough, you know?
Dayton MK402X Review (Bookshelf Speaker)
This is a review and detailed measurements of the ultra-budget Dayton MK402X bookshelf speaker. It was kindly sent to me by a member and costs US $70 a pair plus $8 shipping on Amazon. Note that this is the revised version of MK402 (hence the letter "X" after its model number). From the...
www.audiosciencereview.com
