bboris77
- Joined
- Oct 23, 2018
- Messages
- 460
- Likes
- 956
Hi,
I am currently running the Klipsch R-15M in a nearfield setup. I know that they have not been measured here, but there are 2 sets of measurements online that state that they are fairly flat. I am about 3 feet away from them. I have lifted them so that the tweeter is at the ear level, and they are toed-in slightly to point a few feet behind my seating position. The front wall is about a foot away, and side walls are far enough. They sound great, but not as smooth in the treble as my main headphones, the HD800S. I know it is apples and oranges, but I find the Klipsch to be extremely energetic and mid-centric (like the HD600), and the HD800S is more trebly, but in a very smooth way. I do not find the treble shrill or piercing at all, but it is not as sparkly and airy as the HD800S.
I am wondering if there is any point in upgrading to higher-end speakers suitable for a nearfield setup that would provide this kind of experience. I do not like "warm" or "smooth" sounding speakers that roll off the treble like some of the Polk speakers do. I am not concerned about super-deep low end either, since I am using a subwoofer with them.
I was looking at the usual suspects, KEF LS50, but I have never heard them in person. Then there is the ELAC DBR62, but I am not sure whether it would work well in a desktop-type situation. Finally, there is the new ELAC Carina BS 243.4, which is a lot more expensive, but seems suitable for a nearfield application.
I would highly appreciate any feedback.
