- Joined
- Aug 3, 2019
- Messages
- 933
- Likes
- 1,434
Clearly he doesn’t need those to sell the products.WOW... at 1:00 in Paul says that he has the same Audio Precision Equipment that ASR uses, where are the measurements?
It just goes to show, there are a lot of stupid people with money...Clearly he doesn’t need those to sell the products.
Okay, so he brings up the impedance argument, which was already thoroughly debunked in the ASR review.
Also, weren’t these devices not mainly recommended for DACs and preamps? Don’t these devices already have active regulation, and therefore the AC impedance is irrelevant? Never mind the few Watts those class of devices draw..
And in case of amps: it’s far cheaper to lower impedance of an amps unregulated PSU by just adding more capacitance behind the transformer. Speaking about transformers, guess what the transformer will do to the impedance…?
I don’t think that is the correct question though. The questions should be: why should you care? How does this impact the output signal of the devices? Can you backup any of the audibility and visibility claims?So, what is the actual output impedance of the PS audio device? We know Amir's initial measurement was completely wrong. A second or third measurement showed two different numbers including one about half his mains supply impedance.
Thing is, stupidity may help but it's not at all a prerequisite. Lots of smart people, even with impressive resumes, enjoy being taken for a ride into the snake oil realm, under the assumption that if they hear it then it exists objectively, and because of their ingrained craving to buy that shiny gear that would improve their system a notch.It just goes to show, there are a lot of stupid people with money...
Ohms
Our most powerful compact AC regenerator, the P12 regenerates new, safe, and pure AC from your home's power outlets for breathtaking improvement.
The DirectStream Power Plant 12 takes your incoming AC power and regenerate new sine-wave-perfect, regulated high current AC power. In the process of regeneration any problems on your power line such as low voltage, distorted waveforms, sagging power and noise are eliminated. The results are both audibly and visually stunning when powering either audio or video products. Further, the level of protection afforded connected equipment is extraordinary. Feel 100% confident that a P12 will provide pure and safe power under any condition. Don’t starve your music or risk damaging your equipment. A P12 gives you greatly improved performance and safety from just plugging into the wall socket and far better dynamics, bass and a much bigger, open soundstage than any passive power conditioner on the market.
That really is fraudulent ad copy. I'd be ashamed to work for them.
PowerPlant 12
The DirectStream Power Plant 12 features an all new analog power amplifier and FPGA sine wave generator based on pure, clean, analog DSD (PDM). The P12 is our most powerful compact regenerator with 1250 watts of pure power. From medium to large power amplifiers to the smallest pieces of source...www.psaudio.com
JSmith
Sure, go ahead!That may be your question, but it sure isn't mine. I like to ask my own questions, thanks.
If it doesn't have any real-world impact, why should I care? If it has real-world impact, under what specific instances is that? What's the exact gain I can expect to get? None of this is made clear.That is a good thing and nobody with the slightest semblance of intelligence could argue otherwise.
It's not a question for you specifically, it's a question that should be asked for basically any audio product.Don't ask me to be a spokesperson for PS Audio. It's not my job, I don't work for them and I make zero claims in relation to their product.
Maybe use one of those Power Plants then, they may remove some noise from that picture...I look at the whole picture objectively.
He's the one making nonsense and contradictory claims. Does the thing remove noise now, or add noise? I don't know, his website says the opposite thing from the video now... Making claims about improved video performance with this thing...? I'm sorry, but I see no reason not to ridicule this.Just stop the puerile keel-hauling attacks on a company and a man.
