Regardless of the semantics over a .9 reduction in dB with a mains power drop, the claims made for this device by the manufacturer are:
"The results of feeding your equipment with low output impedance are dramatic: unrestrained dynamics even under the loudest passages, an open, wide soundstage that does not collapse with volume and a naturalness to the music that is remarkable. "
The DirectStream Power Plant 12 features an all new analog power amplifier and FPGA sine wave generator based on pure, clean, analog DSD (PDM). The P12 is our most powerful compact regenerator with 1250 watts of pure power. From medium to large power amplifiers to the smallest pieces of source...
www.psaudio.com
How does this "remarkable" improvement relate to the output impedance of the mains supply to an amplifier power supply? Short answer is "it doesn't!" Even if it did, the makers of this product should limit their claims to the only obvious effect of this machine which is that *possibly* it will mitigate a drop in mains voltage which would reduce the output volume of the amplifier. That is all, no "naturalness" no "soundstage" just perceived volume.
