PecanPi® DAC, Streamer and USB - Rev 2.0
orchardaudio
orchardaudio
Succasunna, NJ
So the 2 adapters (XLR to RCA and RCA to 3.5mm headphones) for Rev2 version hasn't changed output impedance at all for headphones use?
The output impedance is measured without adapters, the adapters will add a little bit but the resistance of the wires inside the adapter is almost negligible.
Music1969
Can you please measure and confirm with these 2 adapters, for 3.5mm headphones use?
If you have a spare moment...
Music1969
Thanks !
I would guess it's still under 1ohm with both XLR-to-RCA + RCA-to-3.5mm but would love to know your measurement.
How do you measure output impedance btw? Could you share details of setup/gear used?
Veri
He has an audio precision analyser, so he can connect it to the output and measure output impedance. The only variable is in his cabling/interconnects which add their own impedance.
orchardaudio
orchardaudio
Succasunna, NJ
orchardaudio
orchardaudio
Succasunna, NJ
Thanks !
Here you go
Damping Factor Balanced (XLR) = ~220
Damping Factor RCA with XLR to RCA Adapter and Headphone Adapter = ~260
orchardaudio
orchardaudio
Succasunna, NJ
Ohhhh. Maybe you could PM @amirm or @WolfX-700 they should have an APx project file for output impedance like so
The damping factor is a ratio between the output impedance and the load (32ohm) in this scenario so the
Output impedance for a balanced connection is 32/220 = 0.145 ohm
Output impedance for RCA connection is 32/260 = 0.123 ohm
