Pioneer’s new DJ VM-50 Powered Monitors Review
hardisj
hardisj
Reviewer
North Alabama
Can you just change this one to have the word "Review" at the end of the thread title? Or do I need to make a new thread altogether?
AdamG
Enjoy the Music your way…
Moderator
Reality
Done!
fun
Thanks for the review. This monitor looks nice. If I read them correctly, seems like the Kali LP6 measured better, and thus a better choice especially considering the price?
hardisj
hardisj
Reviewer
North Alabama
I don't have any personal experience with the Kali LP6 so I can't really make any assessments.
Reactions: fun
MZKM
Land O’ Lakes, FL
Preference Rating
SCORE: 5.1
SCORE w/ sub: 7.3
Frequency response: +/- 9.4dB 40Hz-20kHz ; +/- 6.3dB 80Hz-20kHz
Ericglo
Erin
I wanted to check to see if you received my donation. It was a gift card that I want to throw away.
hardisj
hardisj
Reviewer
North Alabama
Erin
Did you send it June 13? If so, yep. I replied to the PayPal email thanking you. Guessing you didn’t get it. Sometimes they get kicked back out. Same thing happened when I sent a “thank you” to @edechamps this morning; kicked it right back to me. Oh, BTW, thank you @edechamps. :)
so, if anyone sent a donation and didn’t get a reply to me, just know it’s very much appreciated and I always send a thank you but sometimes they don’t make it through.
Maiky76
French, living in China
Copy/Paste from my site, therefore the formatting might not carry over well here. Full review on my site here:
https://www.erinsaudiocorner.com/loudspeakers/pioneer_djvm50/
BLUF: IMHO, this is better than the JBL 305Pmk2. The 305p is more linear in response but has baffle resonance issues which ruin the speaker. The Pioneer is not as linear but most likely will be used with a computer or other source that has EQ readily available and can be EQ'd reasonably well. I'd take this over the 305pmk2, without a doubt.
Pioneer DJ VM-50 2-Way Studio Monitor Review
  • Sunday, Jun 13, 2021
The review on this website is a brief overview and summary of the objective performance of this speaker. It is not intended to be a deep dive. Moreso, this is information for those who prefer “just the facts” and prefer to have the data without the filler. Discussion about the data and my subjective thoughts can be found in my video below.
For a primer on what the data means, please watch my series of videos where I provide in-depth discussion and examples of how to read the graphics presented hereon.
https://youtube.com/playlist?list=PLnIxFR_ey0b37Ex4KV2mBz-kYB7QLffR1
Information and Photos
The recently released Pioneer DJ VM-50 is a powered 2-way Studio Monitor featuring a 5.25-inch midwoofer and a 1-inch dome tweeter in a waveguide. The baffle is made of 4mm thick aluminum which (truly) helps to mitigate baffle resonance; something that was an unfortunate nagging problem in the JBL LSR305P mkII I tested last month. The internal amplifier is a 2-channel Class-D amplifier and each channel supplies 30w to the mid and tweeter, respectively.
This is what the manufacturer says:
The active VM-50 produces clear audio with fast-attacking, punchy bass. The speaker can be tuned to suit the characteristics of any room, making it perfect for recreating a club sound when you’re DJing or providing a flat frequency response when you’re producing music in a home or professional studio setting.
MSRP for the single speaker is approximately $169 USD and $340 USD for a pair.
The back features a variety of switches for boundary settings and basic level adjustments to tailor the sound to the user’s tastes or needs. There is a volume knob and (3) input options: XLR, TRS and RCA phono.
A picture of the setup in my garage:
While the manual doesn’t say, explicitly, where to position the speaker relative to the ear, there is a graphic that shows the listening plane between the midwoofer and the tweeter/waveguide. I tested this speaker on that plane first and realized it was not ideal. Therefore, the reference plane in this test is at the tweeter (I do provide the results of the other in the extras section). Volume set to max with XLR input. The dip switches were all set to ‘L2’ and ‘H2’ for the “flat” (free field) setting.
Note: The roll off rate of this speaker is sharp and therefore some noise was unavoidable at 25Hz - even with 4x averaging - which causes a spike in the response here. Ignore the response below 30Hz.
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
On-Axis Response Linearity
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
  2. 86dB at 1 meter (red)
  3. 96dB at 1 meter (blue)
  4. 102dB at 1 meter (purple)
Based on my results above, it is obvious the output is limited (via internal DSP) somewhere above the 96dB @ 1m output level.
Long Term Compression Tests
Stuffing the Ports
When looking at the SPIN data and the horizontal data, you can see some resonances around 600Hz, 800Hz and 1200Hz. I thought it was possible the port was resonating and sending energy around the speaker through a mechanical means. So, I tested this theory by measuring the speaker with the port open and then stuffing the port. Per the graphic below, there is no difference in the region I am concerned with. This means the port itself is not the cause.
The width of the speaker is about 7.8-inches, but assuming 0.50-inch thick walls, this puts the internal width closer to 6.8-inches. This results in a half-wave of about 1kHz. Figuring the internal dimensions may be a bit off, this leads me to believe what I am seeing is a standing wave inside the enclosure that is simply leaking out of the enclosure in the back. The same assumption applies to all three resonances as the internal dimensions work out to be approximately at these frequencies.
All of that said, these resonances aren’t anything I was actually hearing, at least not to the detriment of my enjoyment of the speaker. Certainly not like other speakers I have experienced resonances with, where in those cases, completely ruined my enjoyment of the speaker. More than anything, it is the sequence of resonances that cause the midrange from 500Hz to 1kHz to be boosted and alter the tonality. In my case, I simply used the built-in EQ of my computer to pad this down about 2dB and it made my musical selection more pleasant to listen to.
Ears at the Tweeter Level
As I mentioned earlier, I initially trusted the manufacturer’s picture which illustrates the listening axis between the midwoofer and tweeter waveguide. Well, as you can see below, that’s not the case. So, keep your ears at tweeter level.
CEA2034%20--%20Pioneer%20DJ%20VM-50%20%28listening%20axis%20between%20Waveguide%20and%20Midwoofer%29.png
Parting / Random Thoughts
  • Subjective listening was primarily at 1.5 meters but varied from 1 to 3 meters. Subjective listening was conducted at 80-95dB at this distance. Higher volumes were done simply to test the output capability in case one wants to try to sit further away.
  • There is zero mechanical noise from these speakers (pops, over-excursion, vent noise) even at higher volumes. However, these are intended to be used as nearfield monitors in the 1-2 meter range. Going past this will naturally mean you’ll need more volume and if you are listening at absurd levels you will certainly run in to the built-in limiter throttling the output as I showed in my linearity test.
  • When listening, I noticed the HF tends to sound brighter the closer I was to the speaker. This is expected as you are getting less room interaction and more of the direct on-axis sound.
  • The bass on these speakers is really quite surprising. As I said above, you can’t crank them because the limiter kicks in and cuts the bass. But at moderate volume (80-85dB at 1-2 meters) the bass is more than sufficient and is really quite well blended. With the f3 at 61Hz, the bass extends low enough into the kick drum region where there is solid punch. Bass guitars sound neutral (other than the 500-1kHz region; see below). There is no resonance in the lower vocals that I’ve experienced from other speakers.
  • The treble region looks low, but remember that you have that 500-1000Hz bump. If you flatten that out then the treble is mostly in-line with the rest of the response. Though, the 3.5kHz-centered dip does result in a sound that may not have as much “bite” as would be expected.
  • Hiss: Most budget powered speakers have a good deal of hiss that comes through them. While these do have some, I can say that it wasn’t a problem at my listening distance. Maybe if my room were dead silent and didn’t have a computer fan running quietly in the background, I would have heard the hiss from the speakers more. But as it was, I don’t have any complaints.
  • Positioning: Horizontally, the 0° axis has a dip (presumably) from the bar grille. If you want, you can toe the speaker in or out a little bit to resolve this. Vertically, you definitely do not want to go below the tweeter axis. The vertical globe plot shows a signficant hole in the response doing this. Even just 10° below the tweeter axis results in a huge dip in response at 3-4kHz. Placing your ears above the tweeter line by about 10° may actually work better.
I do want to mention this, though: Pioneer states these have “flat frequency response". We know that’s a farce.
This is a case where the data does tell an accurate story and we can see that this is definitely not “flat”. It would be easy to dismiss the speaker. Though, when you consider the price and how they are most likely to be used, these speakers are actually pretty good. These aren’t a “home theater” speaker and I can’t imagine anyone would use them in that fashion. Most will use these as computer speakers or with a mixing board. Both of which will almost undoubtedly provide the user with some EQ. Objectively, the 500-1000Hz region’s bumped up output is problematic but it doesn’t ruin the experience. Though, to some degree, the sound does suffer from this. However, if you have the means to add some EQ (I did with Apple Music’s little 1-octave EQ) then you can really transform these speakers into a great budget monitor. I did this and I enjoyed the speaker more as it seems to get rid of both a “forward” sound and “thick” upper vocal. I would personally take them over the JBL 305Pmk2 because of the front baffle resonance issues I had with the JBL.
My recommendation? Buy these, toss a couple bands of EQ from 500-1kHz to bring this down via your music app or mixing board. Try some adjustments in the high frequency region to see what works best for you. And then call it a day.
Support / Contribute
If you like what you see here and want to help me keep it going, please consider donating via the PayPal Contribute button located below. Donations help me pay for new items to test, hardware, miscellaneous items and costs of the site’s server space and bandwidth. All of which I otherwise pay out of pocket. So, if you can help chip in a few bucks, know that it is very much appreciated.
https://www.erinsaudiocorner.com/contribute
You can also join my Facebook and YouTube pages if you would like to follow along with updates.
Hi,
Here is my take on the EQ.
These EQ are anechoic EQ to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 5.0
With Sub: 7.4
Spinorama with no EQ:
  • Not as Flat as i would expect, maybe because the multimedia usage?
Directivity:
Better stay at tweeter height the V directivity is not great.
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated One. The APO config file is attached.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
  • In this particular case the LW EQ and the Score EQ are very similar thanks to the very nice DI so only one is shown
Score EQ Score: 6.2
with sub: 8.5
Code:
Pioneer DJ VM50 APO EQ Score 96000Hz
June172021-115928
Preamp: -2 dB
Filter 1: ON PK Fc 590.50 Hz Gain -2.05 dB Q 2.73
Filter 2: ON PK Fc 857.00 Hz Gain -2.36 dB Q 2.25
Filter 3: ON PK Fc 1325.00 Hz Gain -3.37 dB Q 3.30
Filter 4: ON PK Fc 2140.00 Hz Gain -0.88 dB Q 3.25
Filter 5: ON PK Fc 3167.00 Hz Gain 2.25 dB Q 3.42
Filter 6: ON PK Fc 4250.00 Hz Gain 1.54 dB Q 6.73
Filter 7: ON PK Fc 8928.00 Hz Gain 1.77 dB Q 2.96
Filter 8: ON PK Fc 9810.00 Hz Gain -1.00 dB Q 0.92
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Nice improvements
The rest of the plots is attached.
  • Pioneer DJ VM50 APO EQ Score 96000Hz.txt
edechamps
London, United Kingdom
Did you send it June 13? If so, yep. I replied to the PayPal email thanking you. Guessing you didn’t get it. Sometimes they get kicked back out. Same thing happened when I sent a “thank you” to @edechamps this morning; kicked it right back to me. Oh, BTW, thank you @edechamps. :) so, if anyone sent a donation and didn’t get a reply to me, just know it’s very much appreciated and I always send a thank you but sometimes they don’t make it through.
You're welcome. By the way, last time I checked, all Paypal emails have a "From" address of [email protected] so you can't just reply to them. I think you need to copy-paste the sender's address from the email content.
Ericglo
I forgot that I used my junk email instead of my regular email. Just looked and I did get your email. Glad I could put the Tirebuyer rebate to good use.
dasdoing
Salvador-Bahia-Brasil
not sure how to read
who wins this battle? or is it an audible tie...at least in a 2.1 system?
anyways, after EQ those 2 are the 5 inches champions in terms of 96dB distorsion? or is there another candidate?
sweetchaos
The Curator
BC, Canada
A new set of Pioneer studio monitors got released today!
Pioneer DM-50D.
They are US$200/pair.
If you compare that with DJ VM-50 that Erin reviewed, those are US$170/each (or $340/pair) (or 70% more expensive than DM-50D).
mononoaware
Pioneer DM-50D.
While the DM-50D are described as "Active monitors", to my understanding a true active speaker has the power supply unit, components/circuitry and amplifier built-in to each individual speaker.
The DM-50D are technically a "powered speaker" because power only goes to one unit (where all the components are), and the other speaker is just a passive speaker with bare wire running to it. The left/right speakers are not identical active units. I think this design of the DM-50D is where the lower cost/price comes in.
Alice of Old Vincennes
Interesting. I think I'd recommend these over JBLs as well as the distortion behavior is considerably better on top of the lack of baffle resonances.
They both suck. I guess if your budget is constrained maybe not. But if you are not willing to pay more than a month's worth of fast food pandemic drive through junk food, just your ticket. Hissssss.
dasdoing
it seams to be a single amp for all 4 drivers, while normaly you would have 1 amp for every driver
gasolin75
Denmark
Not bad, not amazing. Certainly a contender for the 305p at the same price point. Any plans to measure the VM-80? I'm always the most interested in the largest speakers in a series.
Jbl is noticeable cheaper in my currency, 899 for the jbl and 1199 pr speaker for the Pioneer vm-50
