Which preset sounds best?
  • 1: ASR
    Votes: 3 11.5%
  • 2: Crinacle
    Votes: 3 11.5%
  • 3: oratory1990 Grapher
    Votes: 4 15.4%
  • 4: oratory1990 PDF
    Votes: 17 65.4%
  • 5: Resolve
    Votes: 0 0.0%
  • 6: rtings
    Votes: 1 3.8%
  • 7: SSN
    Votes: 0 0.0%
AdamG
Enjoy the Music your way…
Moderator
Reality
This is a Subjective Topic and conversation about what Sounds Best! Demanding scientific proof is meaningless and continuing to argue that point repeatedly is harassment. Several post deleted a warning issued and a Perm thread ban dropped.
Carry On!
shaney777
Can someone post a link to the Crinacle preset info? I want to try it out.
AdamPA1006
Hi I'll throw in my novice opinion. I don't have much experience w/ headphones, this is the first time I've ever tried EQ on anything.
I really didn't like Oratorys! I was expecting greatness based on the hype, but the mids sounded very unnratural, way too much boost on 1.9K. He really beefed up the bass nicely though. Compared to Amir, who's tune is MUCH more delicate, WAY less of a difference compared to stock. With Amir's tune, I struggle to notice a difference w/ his two bass bands. I'll probably use the bass shelf from Oratory, and the 1.9K tune that Amir has, that is AWESOME!
I like bright highs, I'm currently rocking this for the treble and really liking it!
High Shelf 9500hz, +3dB, Q0.71
sblrog
Crinacle measurements to Harman 2018 via AutoEQ parametric.
Preamp: -6.4 dB
Filter 1: ON LS Fc 105 Hz Gain 6.8 dB Q 0.70
Filter 2: ON PK Fc 167 Hz Gain -1.6 dB Q 0.35
Filter 3: ON PK Fc 1895 Hz Gain 5.9 dB Q 2.62
Filter 4: ON PK Fc 947 Hz Gain -2.5 dB Q 3.15
Filter 5: ON PK Fc 69 Hz Gain -3.4 dB Q 1.20
Filter 6: ON HS Fc 10000 Hz Gain -2.7 dB Q 0.70
Filter 7: ON PK Fc 3288 Hz Gain -1.6 dB Q 5.17
Filter 8: ON PK Fc 1276 Hz Gain 1.1 dB Q 6.00
Filter 9: ON PK Fc 6699 Hz Gain 1.2 dB Q 6.00
Filter 10: ON PK Fc 4151 Hz Gain 1.0 dB Q 6.00
abdo123
Brussels, Belgium
I don’t like the dip caused by the Harman Low shelf filter around 250 Hz. Amir doesn’t correct for it and I appreciate that.
staticV3
staticV3
That's not to Harman 2018, that's to the AutoEQ target:
sblrog
staticV3
staticV3
shaney777
Preamp: -6.4 dB
Thank you!
shaney777
No worries. It's a common criticism of AutoEQ that it's not clearly explained how the target curve is not stock Harman.
So those are not the Crinacle measurements? I need to know what to enter into the PEQ
sblrog
Sorry, those PEQ settings were Crinacle's measurements EQd to the AutoEQ target. Based on the graph posted above by StaticV3, it's the same as Harman, but with less bass below 200 Hz, maxing out at 2 dB less at about 60 Hz.
If you want Crinacle EQd to Harman, I can try to generate the PEQ settings for you with AutoEQ command line.
