I currently have an RCF Evox 8 (a $1.5-2K powered column) connected to a Logitech BT adapter, which I stream music to. It's sitting in my living room (with the volume knob REALLY low, otherwise the whole apartment building will shake). I drag it outside to my balcony (it's a huge balcony) whenver there are guests, or when I want to stream a movie on the 300" canvas screen outside with the projector, using a long XLR cable. This is what it looks like:
my problems:
a. the system is really heavy. It's a hassle to drag it outside each time.
b. i feel like it's an overkill for what I use it for. Yes, the sound is super-crisp, and it's an outstanding system, but can't I get a similar-sounding system at lower volumes? I don't need so much power, i'm using maybe 5-10% of the volume knob when I'ts inside the house, up to maybe 25% when it's outside.
I could use a lighter, more portable system that would look nice at home, with built-in WiFi (so I dont lose quality over Bluetooth).
Do you haev any recommendation for a system that could output 25% of the power of the Evox, with similar quality, and with a much smaller size and weight, and preferably with built-in WiFi? Perhaps those nice Marhsall Tufton / Stanmore / Woburn?
Thank you.
my problems:
Thank you.
