Possible to increase RCA output?
Chrispy
PNW
I don't trust Audyssey, I use REW + Umik1 that i could check for SPL level for either individual speaker or in pair once i got the level dialed in, along with FR sweep, etc. But I have better result to set everything manually, if there's peak and valley in the FR I would try to EQ them out if it bothers me enough, or when absolutely necessary. For whatever reason Audyssey always ramp up my surrounds and end up overpowering the fronts.
The sweep below was when i was playing with REW and tried to compare different crossover setting for the R200 just to see how they would affect the rest of the FR
You can just turn the trims on the surrounds down a bit after running Audyssey; the editor app gives you some better options for a house curve, too. With the arbitrary settings of levels surprised you got a measurement like that, tho I'd knock them all to 0 as a starting point for setting levels.
X
Xcaliber
"a bit" ain't gonna cut it, even at -12dB (that's the lowest dB I can go on this Denon) was borderline too much when the front wasn't loud enough. I don't have any FR or tuning issue, the one and only problem i'm trying to mitigate now is the front running on an external amp isn't loud enough and they are being overpowered by the surround. lol
If i skip the brand new external amp i just received and run the front L+R through the Denon internal amp, they are fine.
Chrispy
PNW
Have you tried that power amp maxed out on level? What is its input sensitivity rating? At best that amp is only going to provide 3dB spl advantage.
A 24dB swing "correction" on front to surround would be excessive and annoying. Audyssey could at least help level match the external amp to the avr's amps...
What are the speakers involved?
X
Xcaliber
external amp is maxed out on the gain. LOL It has the same hypex NC252MP tested by Amir here But yea, about 2~3dB gain is the most I could get from it (as I have anticipated), over the Denon's 80w.
ideally, you want to match the input level to the gain.
Chrispy
PNW
The attenuators are maxed out or the gain setting is at its highest? Or both?
X
Xcaliber
Both.
It doesn't look like gain/level matching is important to most people on this thread, or at least it seems like it's at the bottom of their list, but if you're curious you can read more about it here: https://www.audiosciencereview.com/...opagate-through-my-system.33358/#post-1165118
I know you're trying to help, i appreciate it and thanks man. But don't worry about it i'll figure it out, i always do. ;)
Chrispy
PNW
Both.
Just trying to understand setup to start. Am familiar with gain structure.
