power amp or Sabaj for marantz AVR?
oneofakind
Hey there,
i'm new here. I just got new JBL L100 Classic MKII and now my cheap "Marantz NR1508" is clipping at high volumes. So i thought about getting a power amp for the fronts.
Budget: ~600€/$
I've read here alot of good things about AUDIOPHONICS MPA-S250NC but i'm not sure if this is what i'd need. Also the Sabaj A30a is mentioned alot but this one would change my RCA analog input into digital? I'd like the Sabaj more cause of the looks, the remote and i could buy it in my home land (and return it easily).
Also i considered the Yamaha A-S701 but i don't like the size.
Thanks and merry christmas everyone
Power Pop 23
Hey there,
Budget: ~600€/$
If you like your Marantz NR1508 but want more power, I vote for acquiring the Audiophonics MPA-S250NC to power the fronts.
ppataki
Budapest
Hey there,
Budget: ~600€/$
Don't use the Sabaj with analog input since it is an FDA (full digital amp)
Its full potential can be unleashed when using one of the digital inputs
I have three of those amps, love them!!!
Sal1950
The Chicago Crusher
Central Fl
I'm liking this Audiophonics amp for your needs.
I took a moment to look at the L100 mk II specs and was a bit surprised to find it rated at 4 ohms so you do
want an amp that will be comfortable driving this relatively low impedance at high levels.
Cheers
oneofakind
oneofakind
i just use it for a simple 5.1 setup. My focus is on the JBL's and stereo music
ok thanks guys. I'll go with the MPA-S250NC
