PS Audio PowerPlant 12 Review (AC Regenerator)
Rate this product:
    Votes: 250 90.3%
    Votes: 18 6.5%
    Votes: 1 0.4%
    Votes: 8 2.9%
captainbeefheart
I have no idea what could possibly be the mechanism for provoking this noise, and honestly I don't know if I have enough intellectual curiosity to search for the reason, but we'll see.
My guess is you have the Scarlett 4i4 plugged into a computer? I believe that's how they get power is from your computer correct? The RS2 takes power from the wall via an external 20v power supply. The RS2 must have it's output grounds tied together and even with the RS2's power is off there the noise currents must be passing through the shared ground at the output of the RS2 between the Scarlett and the input of the preamp.
Easy enough to test, with the RS2 off probe signal ground on the balanced output and see if there is continuity between it and the ground sleeve on the unbalanced RCA output. This will put the Scarlett directly connected to the input of the preamp.
Reactions: GDK
bambadoo
Crap, it should have an audiophile fuse to work better.
Of course this is Ted Denney´s facebook group. Total freakshow there.
srkbear
Dallas, TX
Of course this is Ted Denney´s facebook group. Total freakshow there. View attachment 201814
Amir facetiously invoked such a concept in his review of the MHDT Pagoda—the fuse had a different color on each side. He mused aloud whether it might be one of those directional audiophile fuses?
captainbeefheart
I would love for Amir to reverse engineer these things while he has them but I understand that would take a lot of time. I don't think Amir is anywhere near where I am but I would offer up my services to reverse engineer anything the forum would want to dive deeper into.
Take the P12, they claim the output is a "perfect wave" yet it had the same exact profile as the mains. This tells me they aren't even using something simple like a 555 IC to make the new sine wave but instead are simply sampling the mains frequency through say a divider and then sending it through a power amplifier with feedback based limiter/compressor to keep the output voltage constant under different loads. I just cannot fathom the point of this thing having the same exact profile as the mains, if the device does what they advertise it to do the output should be a perfect spike at 60Hz on an FFT plot and nothing else. Amir gave us a big clue making the connection between the output profile of the P12 vs the mains profile. Something doesn't smell right in Denmark.
I cannot even do the technical discussions anymore about certain things like audiophile fuses, it's just absolutely ridiculous. Some of these fuses are more expensive than my DAC!!!! Ya I know I probably need to upgrade my DAC but for me the Topping D10s works just fine and I am happy with it. I noticed inside has sockets for the IC's, I was very surprised to see this, has anyone swapped IC's and if yes what did you replace the originals with and what where your opinions about before/after?
solderdude
The Neitherlands
It is known/described how the P12 works.
Mains is not regenerated in this model (was in older models) but filtered and 'repaired'.
The output is stabilized.
And indeed they aren't using a 555 to make the new sine wave. They sync mains, create a new (clean) AC using a regular DAC chip which is used as a reference. That reference waveform can even be manipulated to a certain extend. The voltage difference (shape and amplitude) between mains input and desired output voltage (reference) is fed to an amplifier that is in series with the (filtered) incoming mains which provides the needed correction voltage.
So output = mains input + correction and is based on (compared to) a synchronized to mains newly generated reference voltage.
It is not a completely regenerated output voltage.
captainbeefheart
That explains a lot thank you!
I thought at least the fully regenerated older model types were at least going to give you something that may justify spending this much money, I personally do not think it's necessary unless you live in a place where your power is truly horrendous. Why would they switch to this design when the output is not really any better except for the fact you have a more consistent output amplitude which I don't really consider beneficial due to the fact we design power supplies to deal with mains fluctuations already via regulated DC supplies inside the amp.
I would love to be a fly on the all during the design of these products. What on earth are they sitting down trying to accomplish and why don't they understand how pointless this product is? Especially with switching supplies that accept a very wide range of input voltages. Maybe I am missing something, I'll have to go back and read more about it and watch Amirs review again because from memory I thought the output wasn't any cleaner than the input.
captainbeefheart
I went back to go through the tests again and sorry made a mistake, the distortion is lower but noise increased which is what I thought the point of this device was, to clean up noise from the mains not just distortion? It actually increased noise and created 60Hz ground loops lol. So while it may solve a ground loop for you it also may create one, great.
This goes back to my original assessment that most of the nasty stuff is going to be created inside your device from it's own rectification which is after the mains or regenerator so it's pointless. Like I said, you could have an absolutely perfect 60Hz sine wave transmission from your mains or whatever, distortion and noise below -115db for example and it's moot because the instant it hits the rectifier under load inside your device that's where the nasty business happens and so we clean up and filter AFTER the rectifier, then further regulate if need be. As the tests prove any device plugged into the P12 never shows any improvement of it's noise floor or any other measurement. Pointless headless panther I say.
srkbear
Dallas, TX
This goes back to my original assessment that most of the nasty stuff is going to be created inside your device from it's own rectification which is after the mains or regenerator so it's pointless. Like I said, you could have an absolutely perfect sine wave transmission for your mains or whatever, distortion and noise below -115db for example and it's moot because the instant it hits the rectifier under load inside your device that's where the nasty business happens and so we clean up and filter AFTER the rectifier, then further regulate if need be. As the tests prove any device plugged into the P12 never shows any improvement of it's noise floor or any other measurement. Pointless headless panther I say.
This most recent discussion is admittedly way above the wattage supply above my neck. But it just seems most logical to me that the control of noise should be the prerogative of the power supply design in the amp itself, and consequently, the more electronic junk I put in between that and the wall, the more stressors I’m contributing to that job. And after reading dozens of measurements on this forum and elsewhere, if noise were a common occurrence in well-made audio gear, shouldn’t we be seeing evidence of it in those graphs?
I guess the question would be if this “power conditioner” could clean up noise emitted from crappy amps. But that seems to me a teleological argument—why buy a $6,000 mop when you can just buy an amp that doesn’t spill? Am I oversimplifying this issue?
captainbeefheart
......, if noise were a common occurrence in well-made audio gear, shouldn’t we be seeing evidence of it in those graphs?
Yes exactly. For example many of the tube amplifiers tested here like the VTA ST70 you'll see the 120Hz power supply product at the output which is what gives them the poor SINAD score. This is mostly due to the fact these amps use tube rectifiers which are limited by their repetitive peak forward current ratings to take advantage of extra filtering in the power supply. Many that use solid state rectifier still don't make clean power supplies and combined with circuits that have poor PSRR you get high noise floor at the output.
Nope that's not an oversimplification, good equipment should be designed to run directly from mains and still have a low noise floor. It's not impossible and you do not need a power "conditioner", mains shampoo is just fine.
srkbear
Dallas, TX
Thank you! Just so I make sure I’m reading you correctly, for the VTA the tubes are functionally part of the power supply, or is the SINAD measured after the tube stage is intercalated after the power supply’s APFs and voltage regulators? And is the 120 hz current the product of DC conversion from the 60 hz AC coming from the wall? And if this isn’t one question too many, why is such a frequency doubling of the sine wave necessary?
I occasionally build vintage Fender Tweed amp repros, and I’ve since I follow schematics without deep diving into the EE, these are questions of interest to me, thanks!
DonH56
Monument, CO
One of a myriad of explanations of how a full-wave rectifier works -- notice the output frequency is doubled before filtering. Each "half" of the 60 Hz cycle is converted (rectified) to quasi-DC, doubling the frequency, then filter capacitors smooth the signal to provide an essentially constant DC voltage to power the circuits.
In many tube amplifiers, the diodes D1 and D2 are actually tubes as well.
HTH - Don
srkbear
Dallas, TX
HTH - Don
It certainly does, much appreciated! Yes, the one bit of tech I did thankfully learn before starting was not to crispy critter myself by touching the filter caps before discharging them. But I unfortunately do have my share of soldering iron scars.
I’ll get to reading this right away—appreciate the link. Cheers
captainbeefheart
The VTA has zero voltage regulation inside, it's just a full wave rectifier with simple pi filters.
One of the tubes is functionally part of the power supply, it has two diodes inside one bottle. The full wave rectifier doubles mains frequency and is chosen because it's essentially conducting current into the load and supply capacitors every 8mS instead of 16mS and the filters are at half the impedance they would be with a half wave rectifier so they filter better given same value of reactance. Half wave you are just conducting the positive cycle of the 60Hz sine wave which takes 16mS between each current pulse.
captainbeefheart
@srkbear
That link provided by @DonH56 shows how a center tapped full wave circuit would work to create charge cycles every 8mS or 120Hz. Here is an image of a full wave bridge rectifier showing each cycle's current flow through the diodes to give the same charge pulses every 8mS or 120Hz. There are differences for each type in regard to voltage and current outputs. Basically for center tapped full wave you get .7x the AC secondary voltage for DC voltage and 1x the secondary AC current rating. So you get to use the whole current rating of the secondary of the power transformer so nothing to worry about. BUT, with a full wave bridge rectifier since you are getting 1.4x the secondary AC voltage for your DC voltage, you can now only use .65x the secondary winding AC current. Think of it this way, for a bridge the whole secondary winding is passing current every half cycle where the center tapped full wave has current flowing in one half the winding in the first half cycle and then switches to the other half of the winding the other half cycle. So the you can see how there needs to be a reduction of current in a bridge rectifier to stay within the average VA or wattage rating of the winding. The center tapped full wave has half of it's winding conducting every 16mS instead of every 8mS like the bridge, therefore you can use the entire current rating of the secondary because the winding has double the time to cool down between conduction cycles.
iu
captainbeefheart
For all you hobbyists out there building stuff here is a great rectifier design reference to keep in your files. I have most of it memorized at this point and forgot about it but wanted to post for anyone else that may find it useful. I know a very long time ago when I was getting into designing power supplies I found having a "cheat sheet" on each rectification method and sizing the transformer secondary AC voltage and current ratings in relation to the DC output voltage and load current. Mind you the secondary AC current includes charge current for the filters + load.
http://hammondmfg.com/pdf/5c007.pdf
solderdude
The Neitherlands
Heat, longevity, weight, production costs.
Paul 'heard' everything sounds 'better' when it is used and even picture 'cleans' up in video.
PS Audio is targeted to people that believe 'everything' makes a difference and that they (PS Audio) poses the knowledge how to achieve this.
They also sell a lot of those power plants and make money of it.
Regardless if PS Audio believes it themselves, their customers do which is half the battle.
There will certainly be real world cases where it actually solves a problem and there will be plenty more cases where owners believe they actually get better sound. Win-win in both situations.
There are other 'conditioners' around as well but these look better and when your favorite manufacturer tells you it is better they will buy it when funds permit.
srkbear
Dallas, TX
I’m not sure whether there are any consumer grade applications for these power conditioners (excluding surge protectors), but I can certainly relate to its appeal based on my own journey with this hobby.
Before I had spent much time on this site, I had purchased an iFi Pro iCAN Signature for my headphone setup, along with several other of iFi’s offerings. It had certainly gotten raves over at Head-Fi, along with the salient (corporate-funded) audiophile websites around. I was really happy with it and still am. But once I became invested in their brand, I did a deeper dive into their accessories and gave in to an iFi Power Station ($599), a power strip that purports to have active noise cancellation circuitry and a number of likely redundant stages of passive filtering for each of its eight power outlets—promising an array of sonic improvements.
The thing reeks of heft and quality. And having this statement piece anchoring my gear provided me with a sense of authenticity as an “Audiophile”, before I had even considered whether noise was an issue for me. IFi seemed pretty sure it was there though, despite the fact that we had purchased our home brand new, and I knew its build quality included a fastidious investment in sound electrical wiring.
But that didn’t occur to me or factor into my purchase decision at the time at all—I was relatively new to this hobby, and in my inexperience I didn’t trust my ears to detect noise, nor had I sufficiently digested the principles evident on this site’s reviews. Given how much I had invested in my setup already, I was obsessed with FOMO, susceptible to any claims offering to make my already formidable investment sound even “better”—better cables, connectors, power supplies, and conditioners such as this one. It was an obsessive, exhausting quest without any definable endpoint.
Then after some time on this site, someone here took me to task on an expensive digital cable, and I felt crummy enough trying to defend it that I chose to bow to their reason and return it for a serviceable one at a fraction of the price. Admittedly it bugged me for awhile. But after spending a year or so immersing myself in the spectrum of opinions here, I gradually got deprogrammed from the elitist platitudes on Head-Fi and leaned into my own reason-based training as a scientist in another field. And not only has this saved me a ton of money, it’s freed me up to enjoy my music instead of listening for illusory imperfections in my system.
The term “audiophile” has been appropriated by so many bad actors that it has not only become pretentious, but arguably meaningless. For those who haven’t done the work to confidently earn it, buying it has become a facile choice. And when music is exploited for status-seeking tastes, this is how predators such as PS Audio can successfully turn outlandish profits, producing little black boxes that offer fantastical promises that cannot be refuted.
Ricardus
Northern GA
Yup. This is exactly how I feel, and when I hate watch PS Audio's videos I laugh out loud when someone calls themself an audiophile.
srkbear
Dallas, TX
PS Audio may claim to be targeting the audiophile segment, but their marketing tactics are clearly aimed at the uninitiated and Paul McGowan’s pontifications on audio woo are clearly designed to keep them that way.
