PSI AVAA
Purité Audio
Industry Insider
Barrowmaster
London
Just ordered two of PSI’s AVAA bass trap things.
https://www.psiaudio.swiss/avaa-c20-active-bass-trap/
Wanted to try these a couple of years back when they were released, not cheap but seemingly effective and very straightforward to install .
More to follow,
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Arrive tomorrow, available in four exciting colour combos.
The two on the right do look a little like flip top bins though, I would stick to a solid colour.
RayDunzl
Central Scrutinizer
Riverview FL
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
What are you trying to correct with these? Can you do before and after measurements?
They operate between 0 and 150Hz apparently it is like removing the wall, I have two arriving tomorrow, I will post some measurements.
Olli
Very interesting. Looking forward to your measurements!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Roger Roschnik from PSI explains all,
Soniclife
Did you get the cancelation with subs approach working? This seems like the idiot proof alternative.
elberoth
Warsaw, Poland
Did you become a dealer ?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Dutch&Dutch haven’t yet implemented their subwoofer software , so I have been experimenting in REWs simulation mode, which has been interesting.
In the meantime I thought I would try the AVAAs which I discussed with Roger Roschnik a couple of years ago when they were released.
I am a retailer for PSI.
oivavoi
Oslo, Norway
I've been interested in these for some time. Looks like a promising concept. Looking forward to hear more and see some measurements!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Yes well ,we shall see, they haven’t arrived yet, but around lunchtime!
Soniclife
And which wall / corner do they recommend using them on? You would presumably want them a good distance from the listening position.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
RRP is £2200 inc, PSi recommend corner placement, that is where they are most effective , either behind the speakers or behind you, depending where the bass build up is worse.
I understand that you probably ‘need’ two ( depending upon room size) further units do improve response but it is a case of diminishing returns.
RayDunzl
Central Scrutinizer
Riverview FL
Over here we put the bags inside the bins...
Other than that, looks nice, like a fun thing to try out.
FrantzM
Hi
The price is a bit steep IMO. One may get similar or better results with more subs and they don;t need to be expensive subs ... I am a fan of the Gesses multi-sub protocol and it works extremely with even cheap subs ..
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Have they worked ? do we get to see before and after measurements?
Oh you’re back are you!
I am just going to keep them in the plastic bags, for neatness.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Where’s Savage?
AVAA update, they work ( ish) you would need to try them in your own room.
