Qobuz/Audirvana/ASIO/USB 2.0??
el_micko
Hi guys,
Just after some advice as the internet is awash with forums saying different things regarding my below query. Most things below have been discussed individually on here but mine is specific to my machine and setup. Hoping someone can advise.
I've just bought a Supra 2.0 USB (A-B) cable which I'm running out the back of my ifi Zen DAC/Amp straight into a USB 2.0 port on my laptop. Should I be running this into a 3.0 port or doesn't it matter. Also would it matter if I ran it into a USB hub which is also 3.0?
Then, my laptop is 16gb of ram and 250gb ssd and the chip is an ok one, so I'm ok on that front. On the software side, I'm running Qobuz through Audirvana. I'm upsampling by the power of 2 in Audirvana, do I need to? Also which is best for my setup, ASIO, Direct Sound, WASAPI or WASAPI Exclusive? I'm currently upsampling with ASIO but I've not even got into latency settings? I'm also running a modded pair of balanced DT770 Pro 250ohm.
Can you advise on any of this? I also know a lot of it comes down to the original recording, master as well as what my ears can actually hear plus my personal taste but just wondered what your thoughts were?
Thanks in advance
E M
tw99
West Berkshire, UK
My first comment is you've probably wasted a load of money by buying a more expensive cable than is needed to get the bits from your computer to your DAC. Can't comment on the rest of it.
E
el_micko
ok can't do any harm though, right?
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
First question is whether you can still send back that cable. Digital Cables especially, but cables in general are threshold competency items... Beyond Amazon basics, or Blue Jean cables if you want a little nicer presentation is not going to get you better result.
For the rest, upsampling isn't going to make anything sound better.
Are you having any specific issues you are trying to solve, or just trying to maximize your setup for potential SQ?
E
el_micko
Should I just use the stock cable that came with the DAC/amp then and send the Supra back?
No issues just trying to maximise SQ
Also does it matter if I'm using USB 2.0 or 3.0 and should the USB hub make any difference..... and how about ASIO or WASAPI Exclusive?
Thanks
RayDunzl
Central Scrutinizer
Riverview FL
If you are powereing the iFi via USB, maybe a difference:
"In the USB 1.0 and 2.0 specs, a standard downstream port is capable of delivering up to 500mA (0.5A); with USB 3.0, it moves up to 900mA (0.9A)."
The iFi has a 3.0 USB port.
The Supracable (I assume) is wired for USB 2.0, so the higher speed isn't available (I assume again)
Either USB 2.0 or 3.0 will support all the data rates the DAC will accept (from what I can read)
Hubs:
I use a couple of powered 3.0 hubs here. One around the PC, and the other at the rack (with a 2.0 cable in-between them)
PC -> USB 3.0 -> 3.0 cable -> Hub -> 2.0 cable -> 3.0 Hub -> Focusrite, DAC, and two miniDSP, and other stuff when needed.
Beyond that, haven't thought about it.
Should I just use the stock cable that came with the DAC/amp then and served the Supra back?
Is the stock cable a 3.0 cable?
I'd return the Supra unless you really think it does something the stock cable can't (unlikely).
Sukie
Don't beat yourself up about the cable. As you said, the internet is awash with (dodgy) advice.
By the way, welcome to ASR. Stick with this site and you'll safe loads of money whilst still getting top performance!
I agree that you should return the cable, if possible. However it's not like you've wasted vast amounts of money. You'll be able to chalk it up to experience without weeping into your wallet. If truth be told, we've all made purchases that we now regret (particularly when it comes to cables!).
E
el_micko
Hubs:
I'll return the Supra as the stock is indeed a 3.0 B. Any advice on the ASIO/Wasapi front?
Thank you for the detailed reply btw
E
el_micko
Glad to be here. As you can tell I'm just starting out. I'm returning the Supra cable. Do you think running it through a USB 3.0 hub would matter and do you have any experience of what is better with ASIO or WASAPI?
Thanks for you time
Sukie
Thanks for you time
@RayDunzl's post suggests that the USB A to B connection (PC to DAC) can be either 2.0 or 3.0 cable and can use either a 2.0 or 3.0 connection at the A end (whether that's directly into the PC or into a hub). That sounds correct to me.
As to ASIO or WASAPI, I now only use Raspberry Pi's for my streaming, but when I used a PC I tended to use WASAPI in exclusive mode. Having said that I have used ASIO and didn't notice any increase or decrease in SQ.
If you set it up in a "wrong" way you'll know about it. Apart from that, just enjoy the music!
E
el_micko
All great points. Thank you
You're right to try the Supra cable. You should be the one telling us whether or not it was worth it, however.
As for USB ports, I tried straight out of my motherboard, then found that plugging my dac into my monitor as a hub, first, cleaned it up and made it sound better than straight out of my motherboard. After that, I got a PCIe 7-port USB 3.1 card for only $50, because I wanted more ports, not more hubs, and plugged my dac straight into that. It sounded better than straight into the mobo jack, so next, I plugged the monitor into the new card, and then my dac into the monitor again, where it again seemed to clean up the signal some more for me.
Because of this cleaning up that a better hub can do, I have ordered an old used AGD Digital Interface. It will connect to my monitor, and then rebuild the signal as a cleaned up and dedicated audio-only I2S signal sent to my DAC. Many people are raving about how good a digital rebuilding interface is before their dac's, vs straight from the pc. The dedication to audio only seems to improve greatly over the USB signal.
The bad news is, that your original USB port is always too noisy, especially the ones built into your motherboard. Your only option is to always have to admit that if you spend $500 on that audiophile single usb port PCIe card, it can only be better than what you have. But cheer up, you could even get a cheapo $20 2-port PCIe card, that will still beat your mobo.
As for output mode, WASAPI only bypasses the windows mixer at the end of windows loading. Kernel Streaming bypassed the whole OS except for like the first 4k that gets loaded, which is much better, and you could think it was heaven, except that a programmer who thought that it should be the musicians wrote a method that bypasses everything, and called it ASIO. Rock bands sound like they're making more of a racket through ASIO, and it's because it's playing it all properly, compared to KS.
Joachim Herbert
Munich, Germany
Late to the party, I know. While I have a strong preference for minimalistic setups, I use the supra in my work setup to connect PC and DAC. No technical reason. Just for the looks.
I use RMEs ASIO driver as this is needed for automatic sample rate switching. It is also a prerequisite for RME remote.
I would go ASIO if there is a native driver. Not sure about ifi in this respect.
