Question about O2 amplifier...
LegionOfHell
I have an O2 amplifier and I have some questions:
- Is the standard gain(2.5x , 6.5x) the highest gain possible with O2 ?
- how do I know if my O2 is set to the standard gain without looking at the PCB ?
staticV3
Input a 60Hz sine wave of known amplitude into the O2 and use a basic multimeter to measure the voltage at the output with volume turned up all the way.
The gain in dB is 20*log10(output voltage/input voltage).
DVDdoug
You can create a tone-file with Audacity.
Note that some multimeters are not good for low AC voltages so make sure it has a low AC range (in the ballpark of 1V).
