Question about sampling/PCM/Nyquist
MZKM
Land O’ Lakes, FL
Got into a discussion on another forum. Trying to see if a user‘s claims have any theoretical merit.
So, Nyquist states that if you sample >2x the frequency range you want, it can reproduce that range perfectly (with quantization noise). However, what if there was a super short transient (say 1/45,000 of a second), and if that occurs between the samples (44.1kHz sampling), would it get reconstructed? This is of course not audible at all, but the discussion was if it would be present in the recording.
I‘m an idiot.
LTig
Europe
So, Nyquist states that if you sample >2x the frequency range you want, it can reproduce that perfectly (with quantization noise). However, what if there was a super short transient (say 1/45,000 of a second), and if that occurs between the samples, would it get reconstructed? This is or course not audible at all, but the discussion was if it would be present in the recording.
A super short transient contains a lot of frequencies above the Nyquist frequency. The antialias filter before the DAC removes them, and what is left will be reconstructed.
March Audio
Albany Western Australia
No it wouldn't.
A Transient that occurs between samples by definition contains higher frequency signals than the bandwidth of the system.
M
MZKM
Land O’ Lakes, FL
No it wouldn't.
A Transient that occurs between samples is by definition a higher frequency than the bandwidth of the system.
Ohh, duh. Of course such a transient would be insanely HF. I feel dumb, thanks.
M
MZKM
Land O’ Lakes, FL
March Audio
It's not dumb at all. It's a good question. Many times I see people talk about transients and how they are captured in sampling systems. Many don't make the connection between bandwidth and fast transients.
M
MZKM
Land O’ Lakes, FL
Just updated my comment, as I misunderstood the other user:
What happens if two sounds are 1/50,000 of a second apart in a recording, would the beginning of each sound be reconstructed?
March Audio
However, the other user also claimed that since research has shown that even 10 microseconds (1/100,000) is perceivable in regards to sound localization:
https://www.sciencedaily.com/releases/2017/06/170601124055.htm
That we need sampling rates of >100kHz.
Aahhh that's conflating two things.
In that case we are talking about inter aural timing, the difference between reception time of the 2 ears.
Time resolution in sampling systems is *not* related to sample rate. Its another misconception.
Let me find the video, hang on
M
MZKM
Land O’ Lakes, FL
Time resolution in sampling systems is not related to sample rate. Its another misconception.
Yeah, it was my misconception, I thought the other user was talking about missed sounds, not small timing differences.
pozz
Слава Україні
Editor
I've seen that 10 microsecond number quoted in The Physics and Psychophysics of Music by Juan Roederer. I don't know of any work done tying it to music reproduction specifically.
LTig
Europe
Yes.
LTig
Europe
LTig
Europe
No it wouldn't.
No, a single transient contains energy in a very wide range of frequencies starting at 0 Hz (DC). The part of energy which is below the Nyquist frequency is captured and reproduced.
March Audio
I wasn't talking about a Dirac pulse, but yes you are correct.
An audio transient is not, and would never be a single uni directional excursion.
The question, by definition, referring to signal content above system bandwidth.
LTig
Europe
But even then it would contain low frequencies.
March Audio
Yes, already said you are correct :)
My wording was poor. I have rephrased my initial response to say
So no the original transient will not be reproduced, only content that falls within the bandwidth of the system.
However the important bit to note is that the timing resolution is still much higher than the sample rate implies.
tmtomh
So, Nyquist states that if you sample >2x the frequency range you want, it can reproduce that range perfectly (with quantization noise). However, what if there was a super short transient (say 1/45,000 of a second), and if that occurs between the samples (44.1kHz sampling), would it get reconstructed? This is or course not audible at all, but the discussion was if it would be present in the recording.
I‘m an idiot.
You are not an idiot. This is a very common point of confusion about digital sampling. Partly it's because there are elements of digital sampling theory that do not seem intuitive, at least initially. And part of it is because we've all had the nonsense "digital is blocky stair step" claims and diagrams shoved down our throats ever since CDs became commercially available 35+ years ago.
At some point in the past, many of us probably have had the same epiphany you have about this exact issue.
PaulD
Other
Interesting question! I just read the linked paper - at least the online links to it - and it never seems to mention 1/45,000 of a second, and it's testing mice and gerbil brains... It DOES mention that mammalian brains have developed a specialised structure with minimal synaptic delays (SD) because accurate LF sound localisation requires better timing precision than the general nervous system! That's pretty damn interesting (I teach some of this stuff at uni), it describes the physical changes in the cellular structures required to achieve this. Looks like it was a survival advantage to be able to do this, and we developed a specialised mechanism for it - super! The paper also goes on to say hundreds of microsecond timing precision is required to do this.
"Overall, we found a similar overall trend of increasing SD when comparing onset (385.6 ± 46.2 µs, mean ± standard deviation) to ongoing responses (439.6 ±73.0 μs, mean ± standard deviation, Fig. 2A)." It is examining gerbil and mouse brains.
Later the paper says "Functionally, stable synaptic delays seem to represent a specific adaptation for faithful ITD processing, because it would prevent fluctuations in the relative timing of direct excitation and indirect inhibition for responses to onsets vs. ongoing sounds in the range of tens to hundreds of microseconds. Such fluctuations may be negligible for most neuronal computations, but not for microsecond ITD processing of low-frequency sounds."
Since timing accuracy is not related to sampling frequency, this is all rather moot and you can go back to your other forum with confidence that this is not related to their audio systems and listening in any way. Trying to make such a claim is a VERY long stretch, and really just grasping on something to reinforce a prior prejudice.
Hope that helps! (BTW, the full article is here https://www.pnas.org/content/114/24/E4851)
