Quick measurements of Forte 1a, a 50wpc class A amp by Nelson Pass
pkane
North-East
Nelson updated Forte with more of the audiophile tweaks in later versions. 1a, while operating in pure class A mode, has a significant amount of negative feedback compared to its younger siblings. I had the amp on the bench to try to measure ultrasonic and RF interference from DACs into the amp, and since it was already hooked up, decided to take some quick measurements. All measurements were made at 1w into 8Ω.
PLEASE NOTE: An updated set of measurements with better power isolation, bias adjustment, and a different DAC were performed here (link). This resulted is a much better set of amp measurements. Some of the original measurements were updated in this post.
1kHz and harmonic distortion measurement using REW and Apogee Element24 as ADC @ 192kHz:
I couldn't find a way to get rid of the 120Hz frequency.
Here's no signal going into the amp, but the amp is on (nearly the same as amp being off!)
Frequency response is pretty good, about 4dB down at 40kHz, 3dB down at 10Hz:
Multi-tone test shows increased noise due to IMD towards higher frequencies:
And for good measure :) here's the 1k square wave:
I didn't do any stress tests (at least not intentionally!) this time, and don't have the load simulator to measure output at greater powers.
I did take some Picoscope measurements (also posted in another thread) to see what it look like above the audible range. This is playing a 10-22k sweep in REW, also at 192kHz:
pkane
pkane
North-East
What does distortion vs power look like?
Didn't measure this. As is I had to replace the fuses a couple of times and on the first attempt sent 0dBFS into the amp. The 20w 8Ω resistors were not very happy. They were hot to the touch for the next 20 minutes :)
I guess I could measure this up to, say, 5w in some reasonable increments.
SIY
Alfred, NY
If it's really Class A, the dissipation at full power won't be higher than the dissipation with no signal. Or is it the dummy load that complained?
maxxevv
Would the measurements have looked better had those wires been properly twisted and shielded ? The circuit board shielded from the toroidal transformer ?
pkane
pkane
North-East
Would you like a real grown-up dummy load? I feel like I owe you for all the use I've gotten out of your software.
Kind of you to offer! Probably wouldn't be the best use of the dummy load, as I don't have that many amps to measure :) Forte just happened to be the smallest one that was easy to carry upstairs.
pkane
pkane
North-East
Maybe a little. Most of the harmonic distortion wouldn't change with twisted wires or shielded transformer. The mains frequency and related noise were there even when the power was turned off, so I have to believe it's not related to the active circuitry inside. Likely forming some kind of a ground loop with the rest of the test equipment (computer, Apogee interface, etc.)
restorer-john
That's so sweet SIY. :)
You know we are in a room full of geeks when someone is offered a big boy's dummy load instead of a beer.
restorer-john
Can you show the generator square wave and the reproduced square wave on the one trace/screen, that way we can see what the amplifier does to it.
NTomokawa
Holy harmonics, Batman!
Very impressive-looking power block. Reminds me of the Krell KSA-50.
pma
Prague
1kHz sine spectrum looks rather like underbiased class AB than class A. Like typical crossover distortion. Very poor result.
It looks like if you used a soundcard to generate square wave signal? Such test would make no sense. The amp square response goes before the input, in other words input signal is delayed behind output? I do not get it.
pkane
pkane
North-East
Look up some other Nelson Pass class A designs :)
https://www.audiosciencereview.com/...ass-a-power-amplifier-review.9741/post-261454
Or look up some more recent designs as measured by Stereophile. None of them will break the SINAD records (except maybe on the low side). And I like Nelson's amps and have enjoyed them for a very long time :D
The square wave was generated by REW, converted into analog by a high quality 24/192k DAC in Apogee Element24. What puzzles me is that the square wave coming out of the amp looks better than the original digital version of it from REW. I'll have to try to do this from scratch another time, as the digital waveform appears to be missing a lot of the higher frequency components compared to the one captured at the output of the amp.
The delay you are seeing is simply because I had to record digital and analog in two steps. There's no sound card.
Doodski
Maybe it's time for a idle current and bias calibration. Is this your first rodeo @pkane?
