Hi all,
Forced air heat and cooling is a bit loud in my listening room.
I've seen reference to use of "mini-split" systems but I am not sure I am willing to go that route. Are they really very quiet?
I've also seen reference to removing/blocking duct work. Has anyone isolated the ducting for a room and used a BLDC motor running on a low speed?
I would think hot water/radiator heat would be very quiet, unless there are expansion or other sounds?
Any exotic options for cooling? I am picturing a cooled line running the perimeter of the entire room along the ceiling, cooling the air and allowing it to sink.
Any thoughts/options are welcome!
