Recommend me a Low Profile (max 7cm heigh) Class D stereo amplifier
joco
Hello! I need help I wanna buy a low profile class D stereo amplifier around 600$ If have DAC chip too maximum 1200$ I wanna pay. I only found the TEAC AI-303 I can connect to computer and have DAC too around 700$. Any good AMP not higher than 7cm? I wanna use 3 way floor standing speakers forexample like Indiana Line Tesi 661, Triangle Borea BR08 or Elac Debut F6.2 I'm right now searching. Thanks your help!
Timcognito
NorCal
staticV3
Grotti
You should be able to get one of these used within your budget:
Pleased note, that i am biased since i own one myself. No objective data, just a subjective recommendation, sorry...
staticV3
The RA3 seems to have the same issue with potted NFCA modules that killed so many PA5 units before:
https://www.audiosciencereview.com/...rackmount-amplifier-review.46085/post-1709616
(scroll down for pictures of the bulging module and videos of the faulty output)
I wouldn't feel comfortable recommending it at the moment.
Timcognito
NorCal
Sokel
Mind you that even if you find your desired dimensions you always have to give it some room to dissipate it's heat,both on sides and top.
That goes for every amp.
pseudoid
Can you tolerate rear fans (and their potential noise)? Do you have clearance in rear?
J
joco
Hi! Yes I know the heat. If the noise is very low ok. I have space in rear about 30-40 cm ok. Somebody can recommend me only amp without DAC around 600$? Thanks
nagster
Lab Gruppen IPX 1200 may be worth considering.
The downside is that it's over budget. The advantage is DSP and monitoring and configuration via Ethernet.
The previous generation IPD series was well received.
Frank2
