Replace Powernode 2i with Topping LA90 and Emotiva PT2?
Shaboosh
Hello everyone, I'm looking for advice on a potential upgrade to my system. I currently have the following hifi equipment:
  • Chord Hugo 2 DAC
  • Chord 2go streaming module
  • Powernode 2i streaming amplifier
  • KEF LS50 Meta speakers
  • SVS SB-1000 subwoofer
The DAC, streaming module and speakers are recent acquisitions, and I had initially assumed I would upgrade my amplifier also, but now I'm having second thoughts. The biggest issue for me is bass management — after much trial and error, I've established that my speakers sound best crossed over at 130HZ. Any lower than this and I hear booming bass, no doubt as a result of my relatively compact living room.
This means that I need to have a high-pass filter in my amplifier or pre-amp. I'm considering the Emotiva PT2 paired with the Topping LA90 Discrete. My question is: would I hear an appreciable step-up in sound quality if I swapped out the Powernode 2i for the PT2 with the LA90, or is the Powernode 2i transparent enough to do justice to the Chord Hugo 2 and 2go?
Cgs0409
I’ve been discussing the system I plan purchasing on the Fosi V3 thread. The preamp I’ve been considering I’d the Schiit Kara. I like the fact it has several RCA inputs and XLR connections. It seems to check all the boxes for me but I’ll have to buy a DAC and phono preamp. Now I’ve discovered the Emotiva BasX PT2 preamp/DAC w/phono preamp. The only thing it doesn’t have is XLR connections…no big deal really. The PT2 seems to be a good choice but I want to hear from y’all about your thoughts on this unit.
