Revel M106 Bookshelf Speaker Review
This is a review and detailed measurements of the Revel M106 bookshelf speaker. It was kindly purchased and drop shipped to me. It is not a new sample but came to me with full packaging and protective wrapper. The M106 costs US $1,000 each or $2,000 for a pair. It is only sold through dealer channel so these are "list prices."
NOTE: our company, Madrona Digital is a dealer for Harman which includes Revel speakers. So please feel free to read as much bias as you like in this review.
The M106 is one of the heaviest and densest speakers I have lifted for its size:
The finish is first class and glass smooth. Back panel is highly curved which should reduce diffraction effects:
Sorry about leaving the protective plastic on. I try to keep as much as these things on so the finish is preserved when the owner gets the unit.
I used over 800 measurement point which was sufficient to compute the sound field of the speaker.
Spinorama Audio Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker can be used. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Revel M106 bookshelf speaker spinorama CEA2034 frequency response measurents.png
There are some variations in the on-axis frequency response but some go away in the listening window (average of a few degrees around the direct axis). The large disparity in size between tweeter and woofer also creates some directivity error where the woofer starts to "beam" (its radiation narrows) yet the tweeter starts with a wider beam width causing a dip in off-axis response.
There are no signs of serious resonances though which is good.
Early window reflections are pretty smooth making this speaker easy to place in a room and have it sound good:
Revel M106 bookshelf speaker spinorama CEA2034 early window frequency response measurents.png
Putting on-axis and reflections together we get a predicted in-room frequency response in a hypothetical average room:
Revel M106 bookshelf speaker spinorama CEA2034 Predicted In-Room frequency response measurents.png
This is really good folks! Some of the variations in on-axis are filed away resulting in almost ideal frequency response. Since what you hear in your room is the sum of direct and indirect sounds, this type of response bodes well for actual performance in one's room.
I read some place that Kevin Voecks (most visible person behind Revel line) said that there was strong effort to reduce distortion and that they had managed to push it below audibility in mid to higher frequencies. So let's measure that:
Wow, seems true! At 86 dB the graphs essentially hugs the bottom of the graph. Even when pushed to 96 dB, there is hardly any rise in distortion. This is the type of performance we expect to see in high-end active studio monitors, not home bookshelf speakers.
Putting the distortion in context at 96 dB we get:
Usually I set the lower limit at -50 dB as shown. But received a good request to show it down to lower levels so here we are. We can see that distortion products linearly go down and hit some of their lowest where our hearing is most sensitive (2 to 5 kHz). Second harmonic dominates across the board. Third harmonic does peak up near 3 kHz but otherwise is not dominant.
Looking at how wide of a "beam" the speaker projects we get about 100 degrees:
The drop off is smooth:
Vertical is not bad for this type of speaker and gives you some wiggle room with respect to the height of your stance and your ear level:
You don't want to go so high or low below tweeter axis as to land in these "eyes" around 2 kHz.
Directivity is reasonably smooth as well again, given the type and design.
Impedance shows the typical minimum impedance:
So don't let the small size make you think you need a small little amplifier to drive it.
You all know I am not a big fan of waterfall graphs but this one sure looks clean and uneventful:
Subjective Speaker Listening Tests
For testing, I go through my reference track list, often playing 20 to 30 seconds before going to next one. This way, I can quickly get a sense of speaker's overall performance across wide range of content with different spectrum. Well, that didn't happen here. As soon as I played the first track, I froze in place. The sound was so incredibly smooth and beautiful that I could not hit "next" on my player! Incredible amount of detail. Resolution to die for. The note decay was tremendous. This was that first track, Youn Sun Nah - My Favorite Things:
The Youtube version sounds poor. I have the 88 kHz high-res download. Get a copy of this track and if it doesn't make you melt in your seat with audiophile bliss, you have the wrong speaker/system!
I go to the next track, Snowflake from Kristin Asbjørnsen
The starting strings seem to jet out of the speaker with startling realism. And then the beautiful vocals came through, with nice layering and separation.
Sit .... back... down. This is not some subjectivist speaker review. To wit, my wife was in the bedroom getting ready to go to sleep but she did not come out to tell me how great the speaker was!
Back to my testing, after listening to a dozen reference track and being most impressed with them all, I switched to bass heavy ones. There is no deep bass here but what is there is incredibly clean. And this speaker can play them loud. Really loud with no sign of strain. I had no trouble filling my huge space with just a single speaker playing. Tracks like the classic Samba by Jean Claude Kerinec & Staff Elmeddah could not be more dynamic coming out of this little speaker:
Words really fail me to describe the clarity, fidelity and yes, neutrality of this speaker.
The Revel M106 is not cheap in a sea of bookshelf speakers selling for 1/5 its price or even lower. But I am here to tell you that it achieves a level of fidelity many of us strive for. Its objective frequency response is very good. But I think part of the superb fluidity and clarity it brings to delicate notes is its extremely low distortion. I wish you could be here to listen to it and experience what I did. To say that I am impressed by it is an understatement.
The Revel M106 is one of the most perfect bookshelf speakers I have heard. As such, I am going to give it my strongest recommendation.
Here is my routine every night: eat dinner, go to the garden and dig, de-weed, put compost on plants, fertilize and water them. The come inside at 9:30 pm (it doesn't get dark till after that!) and wash all the dirt from under my nails. Then go in the garage measure speakers, process them and stumble into bed at 1:00 am. If this didn't make you cry and want to write me a big donation check, I don't know what will: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
  • Revel M106 Spinorama.zip
pozz
Слава Україні
Editor
Very, very similar to the IL10 on first glance.
Nice follow-up review.
Reactions: 617
Webninja
Los Angeles
I have a bias towards towers, but it’s hard to justify the price increase for the F208, especially if you plan on subs.
Indeed. Yet what I miss is exactly what I am getting in M106. If it is frequency response difference, we better damn try to find it as my impression of these two speakers is worlds apart.
@amirm how loud can you play these guys given the low distortion? Can you realistically expect these to be in the same ballpark (block? neighborhood?) as your Salons with good subs in a modest size room?
If you ignore the deep bass that Salon 2s have, then maybe it can rival them. I know I turned them up as much as I wanted and there was no sign of distortion or driver bottoming out.
maty
Tarragona (Spain)
Ron Texas
As expected Revel knocks one out of the park, or did the panther make a hole in one?
Food for thought: https://www.stereophile.com/content/tale-two-speakers an article why the imperfectly measuring LS50 is preferred over the M106.
At the same price, the M106 looks better to me than the R3 and I haven't seen the preference score yet.
Edit, a very solid preference rating, 5.8/8. Not off that much from the best measured around here so far, way beyond the pack, with the ability to play loud and no funny stuff in the treble like the R3.
tecnogadget
Madrid, Spain
Nice review !! It’s a pity Revel speaker’s are not easy to spot in Europe. I wish I could demo the M16 and this M106 and appreciate what Amir’s has listened.
The On-Axis is indeed very good but certainly not enough to achieve golfing panter, however everything gets fixed in a magical fashion with the PIR which is almost textbook.
@amirm With so much speakers measured already and the constant fact you keep enjoying speakers that has tilted down response (harman target). Can we start having some slight supposition that as a speaker manufacturer, the way to go is not to design for On Axis or LW flatnes/neutrality, but all it matters to achieve bliss comes into tailoring the PIR and low-distortion?
Im really intrigued which tricks or methods helps the design process to tailor PIR...or is it just trial and error empiric work until it gets the target ? Couls PIR be simulated by soft at designing stage before even start prototyping?
Frank Dernie
Oxfordshire
Intriguing.
I have heard big differences between speakers which I had always attributed to cabinet and driver colouration. This conviction had been somewhat dented by statements here that the FR and directivity makes the most difference since in the case of my experience I didn't have a FR graph to compare similarities.
This speaker looks to have an inert cabinet and quality drivers.
I look forward to the wider studies to see if they coincide with my amateur experience.
ROOSKIE
Minneapolis
That SB acoustics tweeter is really cool. It is the one I plan to use in a DIY active set-up (someday)
A Selection of the DIY community hails it as one of the best tweeters essentially ever. (of course not all agree)
Amir you might want to have a close look at it. It is has an interesting design.
I had the baby M105 for awhile. It had a very, very smooth tweeter. Unfortunately I no longer have it. I purchased it to be used as a reference 5.25 inch driver based speaker. I liked everything about the speaker except that I liked the JBL 530 more & it therefore became my 5.25" driver reference.
The one thing about the REVEL M105 was a less detailed bass compared with the 530. I wonder if that has anything to do with the distortion characteristic? The 530 also seemed to have more depth. (maybe) It was deff more articulate in the bass.
hardisj
Reviewer
North Alabama
Thanks for the data! Lovely speaker.
Looking at the data I noticed the ~5kHz bump, on-axis. Probably because everything else is so dang smooth. Doesn't seem to be a resonance here because it goes away in the other angles so I assume it's a byproduct of the waveguide/angle. It looks like this speaker would actually perform better (more linearly) at the 10° axis. If someone here has the means, I would like to see directivity and CEA data generated using that as the reference axis. Not sure if you can do that easily in your software @amirm or if that's best left to one of the post-processing fellas here.
The distortion above 200Hz is indeed quite low. But the rising distortion below this makes me curious just how loud/low it can play without a subwoofer. Not that I would use this speaker without a subwoofer for high level listening. Some might want to, though.
Also, @amirm can you update the directivity plots to include the legends? Thanks in advance.
hardisj
Reviewer
North Alabama
I don't know that I'd call it the best tweeter ever. There are a lot of other excellent options to choose from. If you haven't seen or heard of BlieSma tweeters, you need to check them out. Incredibly linear on-axis response, high sensitivity and great directivity. Especially their Beryllium version.
http://www.bliesma.de/products.html
Colonel7
Maryland, USA
Thanks for this. Kudos to you for listening and members coming up with suggestions. The speaker reviews and measurements have come a long way in only 6 months.
Edit: it was not my suggestion!
