Review and Measurements of Allo DigiOne RPI S/PDIF
Thunder240
NorCal
Echoing the preceding question, I’m well aware that @amirm ’s testing of SMPS and LPS units to power DACs has demonstrated that any DC noise that is passed along is filtered by the DAC to inaudible levels. However, with streamers like the Digione, is that still the case? Especially for something like the Digione Sig, where the “clean side” power connector bypasses the RPi’s regulation, there wouldn’t necessarily be any noise suppression.
@Modellbobby , FWIW besides the Shanti, Allo also offered a 5V/2.85A “low noise” SMPS called the Nirvana. I have no experience with it.
Thunder240
NorCal
Well, since you recommended the Shanti earlier in this thread, I figured you had some experience with it.
RenEH
Does anyone know if the DigiOne outputs from the RCA and BNC connector at the same time? I'm currently using Edifier S3000pro speakers that do not have a subwoofer out. To fix this, I use an optical splitter to feed a modi 3 attached to a HSU sub and the Edifier speakers.
Can the Digione feed the modi 3 and the edifier speakers at the same time using its two outputs?
Fahzz
Outside Providence
@Modellbobby , FWIW besides the Shanti, Allo also offered a 5V/2.85A “low noise” SMPS called the Nirvana. I have no experience with it.[/QUOTE]
I bought the Nirvana power supply for a Digione player (not Signature). The Digione is connected directly to my AVR (and its DAC) by SPDIF/Coax.
It seemed to have a positive effect on the sound, particularly at low volume levels, if that makes any sense. I randomly hear "new" instrumentation in familiar tracks. Or maybe it's upgrade bias. Anyway it was less than $70.00 shipped. Price was reasonable, and to me it was an improvement.
Ellisr63
Mexico
I just purchased a ALLO One player with SPDIF out... Do I just use a 75ohm RCA cable to connect it to my Yamaha CXA preamp? My Yamaha has coax and optical ins.
Dennis_FL
Venice, FL
This is a review and detailed measurements of the Allo DigiOne Raspberry Pi digital audio (S/PDIF) interface.
I read that the Digione can't do DSD. Presumably because DSD exceeds the max data rate? What does it do with Tidal MQA ? Does it pass through?
UPDATE: I saw on a Roon post that Digione doesn't pass MQA or DSD.....Roon ends up processing and it ends up 48khz / 24bit max. So I changed my mind on the Digione.
dkinric
Virginia, USA
This is not true. I don't know about DSD, but the Roon/Allo Digione combo will play at least up to 192/24. Roon unfolds partially, the DigiOne hardware does the rest.
Dennis_FL
Venice, FL
dkinric
Virginia, USA
Playing through Tidal Connect is different than Roon. I have been using this combo for a couple of years and am able to easily play 192/24 running Roon on my iPad controlling my DigiOne that is hardwired for networking and coax out to my Topping DX7PRO DAC. Of course, none of these fake extra bits are audible vs lossless 44/16 anyway, but that's another discussion.
Dennis_FL
Venice, FL
I have both Qobus and Tidal plus a significant collection of DSD & FLAC recordings of my own. I haven’t seen any discussions on Digione and Hi Res….
update….I found this.
Blew
Sydney, Australia
Why would the Digione make a difference there? MQA is directly encoded into the PCM stream at 44.1/48KHz, so as long as the Digione supports those frequencies I don't see how it would prevent MQA from being passed to the DAC.
I do know most DACs don't support full MQA decoding via the Toslink and S/PDIF interfaces though, as they only do the final rendering there. So you will need a MQA software decoder to unfold the first layers. Perhaps that's why Roon is interfering?
