Review and Measurements of Benchmark AHB2 Amp
Kal Rubinson
Industry Insider
NYC
I read your review and noticed you were not happy matching this amp with Monitor Audio Silver 8. Did you run into similar issues driving other speakers?
Not yet but the only speakers that I have used them with are much more expensive (not that price is the issue) than the S8.
Manbeard
Subjective impressions...... but I'm using one AHB2 to drive a pair of Silver 300's and the match is great IMO... my ears are extremely happy. I didn't notice any issues with the sound being 'thin' or anything like that. Not the same exact speaker so that could have something to do with it.
RayDunzl
Central Scrutinizer
Riverview FL
If I get a chance I plan to hook them up to my main system and see. The MLs have much more power so at the extreme, it won't be able to match them.
That would present the opportunity to post a few room measurements. Distortion would be interesting, for example, at, say 90dB listening position SPL.
If you already have, I don't remember them... Link?
anmpr1
I worry that people will read this and think that this level of performance translates to improved sound quality over the next ~5 measured amps on the SINAD bar chart.
It's already supremely difficult to tell the difference between amplifiers that are in the 0.01% (-80dB) and 0.001% (-100dB) ballpark in tests designed to reveal distortion. Most would argue it's even inaudible for music. Even some of the most excellent loudspeaker drivers have distortion components around 0.01%.
I have no way to conduct an ABX sort of review, but here's my take: using a decent quality solid state integrated amplifier (100 watts a channel) I could only listen to my speakers at a moderate level. Any louder and an 'aural fatigue' would set in. The sound became edgy and unpleasant. The amplifier (Yamaha AX-592) was measured by Dr. Rich (Audio Critic No. 25) and found to clip at 140 watts/8 ohms; 210 watts/4ohms, with distortion running from -80 to -95 dB depending upon frequency. FR was down .3 dB @ 20kHz, otherwise flat. That is, nothing judged to be audible. My speakers are pretty sensitive, and don't require much wattage (104dB/watt/meter, or there about). So it's not like I was clipping the amplifier in a living room setting.
Source was a PC running Music Bee WASAPI exclusive USB into a Cambridge DAC Magic box. So called Pure Direct into the Yamaha (bypassing tone controls and balance). Both standard PCM and 'hi-res' material. Same thing with a couple of lower powered tube amps--one I built and another a commercial product. Except the bass was notably 'flabby' with the tubes.
Now, using the DAC3HGC/AHB2, I find I can listen to my speakers at a much louder level with no irritation.
I was always pretty much an 'all electronics' sound the same guy. And I'm not even saying the 'sound' between the two amps was different in the usual 'golden ear' sense of 'liquid' midrange/front to back depth/soundstage/pace and rhythm descriptions. None of that. What I'm saying is that the Benchmark is simply 'cleaner'. With less sensative speakers, who can say? With levels matched, maybe the differences I hear would go away. Maybe I'm just making it up and deluding myself. Oh well, even if it's the latter, I can go to bed at night and sleep well knowing I have well built gear. It's not like I splurged five grand on an 8 watt SET made in some guys barn, in his spare time. LOL
DonH56
Monument, CO
Anyone know if there is a volume discount? I just checked and I sent them an email a couple of months ago but never heard back. Earthlink wacked out their antispam scheme around then and it's still somewhat messed up, sending emails to spam even though they are on my contact list, so Benchmark may have responded but it got trashed. Figured I'd check here before pinging them again.
g29
Will you measure and post your Mark Levinson amp specs at some time ???
Reactions: Pio
777
9dB in low-gain ? WTF ? Is this a current buffer or a voltage amplifier ? Even in high-gain there is only decent gain (15x). You need an headphone amplifier to drive AHB2.
It is designed for professional interfaces such as Benchmark's own DAC which output a lot more than consumer products. On high gain though, 2 volts gets you max power so a normal DAC with volume control can drive it.
777
I inderstand. Thank you.
garbulky
Amir these are amazing specs. Hard to believe that this tiny amp can do all that and more. I remember with the Hypex that it couldn't sustain the max output, dropping to only 40 watts or so RMS. What about this unit?
March Audio
Albany Western Australia
This is a review and detailed measurements of the Benchmark AHB2 Amplifier using THX technology to reduce distortion. I was going to request one for testing due to membership demand but to my pleasant surprise, the company volunteered to contact me and send not one, but two units! I requested the second one because of something I was seeing in the measurements that turned out to be my issue, not the amp's. The AHB2 retails for US $2,999 from the company direct.
The AHB2 is a very compact form factor, enabled by use of switching power supply to increase efficiency/density:
There is just a power switch in the front. It might be but I constantly reached for the screw next to it to power it on! Having the power switch be slightly different color or shape may help with this.
There are a set of LEDs that show the status of the amplifier. They are driven by an FPGA (field programmable digital logic) that monitors all aspects of the amplifier and shuts down the unit if stressed. It did so very quickly and efficiently in my testing. Usually this is done with purely analog or maybe a small microprocessor. As such, the coverage of scenarios that could damage the amplifier is much less complete than using the approach Benchmark is using in AHB2.
Here is the back panel:
This is a very minimalistic approach given the small amount of real estate available. Only input is XLR balanced which is just fine in my book. A gain switch allows the input level to be controlled so that you can just use an RCA to XLR adapter and still get full power (2 volt max in high gain). At the other extreme, the low gain setting is designed for professional pre-amps with lots of output, getting its max power at 9.8 volts. Using this scheme, the signal to noise ratio can be improved as you will see in measurements later.
For speaker terminals there are two sets: classic heavy duty banana jacks and SpeakOn. The SpeakOn are locking and provide the best performance. I lost about 3 dB of performance using the banana jacks due to less secure connect there. So the measurements you see are with SpeakOn jacks.
Another minor nit on that note: I had a rather cheap SpeakOn cable and its plug was just large enough to hit the silver screws that the sockets are mounted with. Typical round shaped SpeakOn ones are not an issue. Flush mount screws would solve this problem.
There is a switch for selecting stereo or mono bridged output. The latter quadruples the amount of power available and unlike typical bridging, according to Benchmark comes at no penalty in distortion! I plan to test this later as it has a minimum impedance of 6 ohm so I could not use the 4 ohm setup I used for this testing.
There is a very beefy AC mains cable with really nice locking tabs. Insert it and it stays put unless you push the two red tabs on each side. Nothing is more aggravating than the AC cable coming half-way lose from the IEC socket.
Being a proper company of course the AHB2 comes with full set of regulatory/safety/emissions certifications which is super important with power amplifiers given the high voltages and currents running around in them.
In use the AHB2 stays very cool for a power amplifier when it is idling, outputting little power which was a nice surprise.
As to THX technology, it merges a low-power but very low distortion amplifier with a high power but higher distortion amplifier. The distortion of the latter is not seen because it is producing so much power (so the ratio of distortion is lower). The general scheme is not new, dating back to 1980s but new implementation is. We have seen this in stellar performance of Massdrop THX AAA 789 amplifier which broke new ground in level of distortion and noise. Will the Benchmark AHB2 manage the same? Let's see.
Power Amplifier Audio Measurements
As usual, I start with my 5 watt output test using 4 ohm load using SpeakOn terminals as noted:
I hope your jaw is on the floor just like mine was when I saw this picture emerge! :) 113 dB THD+N in a power amplifier? Are you kidding me?
Look at the harmonic distortion. The worst case spike is below -130 dB! This is insanely good. Of course this type of SINAD (signal and noise ratio) crowns the Benchmark AHB2 as the best I have ever tested:
The performance was so good I literally had to rebuild my dummy load to get there. Even the quality of the metal used in the connectors matters to get to this level of distortion. I replace all my dummy loads with higher precision ones that have much less VCR (voltage coefficient of resistance). Resistor values can become voltage dependent creating distortions of their own. Up to about 105 dB of THD+N, it doesn't matter but beyond that, the VCR was the dominant distortion, not the Benchmark AHB2 amplifier!
It was requested that I show the breakdown and distortion so here we are:
Our best case hearing threshold is -116 dB SPL so no question that this level of distortion is totally inaudible. Separating the noise from THD, we see that it is noise that we are measuring as THD+N, rather than distortion:
And this is with exceptional noise performance of Benchmark AHB2 as we see in the graph of THD+N versus power:
Even in high gain, the AHB2 easily outperforms the DIY Hypex NC400 I had tested before which used to be the best amp I had tested.
We have 185 watts of power at incredibly low distortion of 0.00016%, besting the company specifications.
Note that the FPGA protection mode kicks in and essentially shots the amplifier down past the limit. You get absolutely distortion-less and noiseless performance until there is no more.
EDIT: here is performance in bridged mode using same 4 ohm load:
You get 500 watts of stunningly clean power. Protection circuit shut the unit down after that so it is quite safe to try. With a THD essentially matching the non-bridged mode, there is no reason to be afraid of trying this.
Intermodulation distortion versus power level shows the same story of clean power:
If you want to know what you get for extra money over bargain amplifiers, you can see the difference in the above graph. We are not talking about 5 to 10 dB but whopping 40 dB better!
I have had requests for intermodulation distortion using dual 19 and 20 kHz tones. Here is that:
THD+N versus output level looks far cleaner than anything I have tested before:
Even at the limit of our hearing (20 kHz), we have vanishingly low amount of distortion. The graph is exaggerated so shows a rise there but in absolute levels, despite 90 kHz bandwidth of the test, we have incredibly low THD+N of just .004%.
The sharp spike at 45 Hz in green shows the amplifier going into protection mode. So don't pump that sine wave continuously into it at 133 watts. :)
Frequency response is exceptional too as expected:
Since this is not a switching amplifier, there is no filter there allowing the bandwidth to go to 200 kHz and beyond. Lowest band of AM radio is 450 kHz so likely you could use the AHB2 for an AM radio transmitter! :)
Usually when we test switching amplifiers we see all kind of "interesting" things in their outputs above hearing range. The AHB2 is a classic configuration albeit, with a switching power supply so all is well and clean here:
My reference graph for the Hypex NC400 used an AES filter (by accident) so I ran the AHB2 both ways, with or without that filter. Using the filter (in green) so the two are equal, we see much cleaner spectrum below 200 kHz and of course, no massive switching spikes. Worst case spike is below -115 dB. In other words, the Benchmark AHB2 is clean even in the areas you are not looking! It is like a restaurant scrubbing their parking lot with soap and pad as well as their dishes. :)
My loose wires on dummy loads is not the best setup for measuring crosstalk but here it is anyway:
Where our hearing is most sensitive (2 to 5 kHz), separation is around 100 dB which is way, way more than we need. Despite the small enclosure, the AHB2 manages exceptional numbers here.
It goes without saying that the Benchmark AHB2 breaks new ground with respect to performance of power amplifiers. Using it, you can be assured that any distortion that you hear is from other sources (speaker, source, content, etc.). This is what I look for in high-end audio: absolutely the best performance so no second guessing is involved. You buy once, and you are happy forever!
All of this comes from a company that is a model of transparency with proper and accurate measurements of their products on their site. And importantly, volunteering to have that data shown to be correct by independent sources such as us. Support form the company for me at least has also been exceptional.
Yes, $3,000 is fair bit of money but is pocket change in high-end audio. Sales tax is higher than $3,000 for most of those products! I hear a lot of talk from audiophiles to have the equipment get out of the way of enjoying the music. Well the Benchmark AHB2 at levels that assuredly passes full transparency. So if that is your moto, you better stop buying boutique products with no specs and independent measurements and get an AHB2. Everything you hear then will be what is in your source, not the dirty dishes that your amp my serve your food on.
Needless to say, the Benchmark AHB2 gets my strongest recommendation for power amplifier. The pink panther agrees, having hit the ball out of the park after I took that shot!
The comedian Chris Rock said it best: there is a difference between being rich and wealthy. If a wealthy person had as much money as I have, he would hang himself! So please donate enough money so that I can become wealthy using either:
Patreon: https://www.patreon.com/audiosciencereview), or
upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
Thats very cool. Totally kicks ass :) !
bunkbail
No SNR results?
VintageFlanker
Paris
:) The thought definitely occurred to me.
The combination of AHB2 and APx555 analyzer makes an excellent test bed here! The issue though is that one side needs to be bare to connect to the load resistor to see the difference. Would be fascinating to see how many high-end cables actually make this worse or better.
I'm ready to send my Atlas Hyper 3.5 (terminated with pure copper bananas) speaker cables. Just VERY VERY curious if there is something measurable or not.
maty
Tarragona (Spain)
