Review and Measurements of Bluesound NODE 2i Streamer
VintageFlanker
Paris
Please focus on the digital outputs
I will focus on whatever the heck I want to. :p
Meaning: pretty much every aspects of a product, if you aren't familiar with my reviews. ;)
This device is mainly used as a streamer with a good quality DAC in my opinion
Seems like you missed the all point of the Node X. Assuming Bluesound claims are correct, your opinion could be very wrong : New dual ES9028Q2M implementation, with 110dB SINAD / 118dB SNR announced.
There would be no reason for the Streamer input to perform differently than the digital inputs. Otherwise, the device would be broken in design.
That, I will verify.
Kelims
Zaměřím se na to, co sakra chci.:p
Význam: téměř všechny aspekty produktu, pokud nejste obeznámeni s mými recenzemi.;)
Zdá se, že jste přehlédli celý bod Node X. Za předpokladu, že tvrzení Bluesoundu jsou správná, váš názor může být velmi mylný: Nová duální implementace ES9028Q2M s oznámeným 110dB SINAD / 118dB SNR.
Nebyl by důvod, aby vstup Streamer fungoval jinak než digitální vstupy. Jinak by se zařízení designově rozbilo.
To si ověřím.
Of course, focus on what you want is your hobby.... I personally would appreciate a focus on HDMI eARC and S/PDIF coax output. Combined with the Hypex Fa it would be an awesome combination if all is well.
Kelims
Here is the performance of Bluesound Node 2i feeding a Topping D30 DAC via coax S/PDIF:
As you see performance is much improved.
Those of you wanting the Topping D30 coax SINAD, you have that one there. :)
Then there is no problem to use it only as a streamer without losing the quality of the digital output to an external DAC. Would it be possible to compare it with, for example, Allo DigiOne S/PDIF?
VintageFlanker
Paris
This graph is 4 years old. It is somewhat "obsolete" by today's standards. In that case, SINAD measurements have to be made either in the digital domain or through a top-performing DAC.
Anyway, if the digital output of whatever the Node 2i, Node 2021 or Node X is not audibly transparent, then it is broken in design.
We don't need to measure it with x or y product. If you get 130dB / 140dB SINAD out of any S/PDIF, then it will be good enough for any DAC on Earth.
Kelims
I look forward to your review of node x and hope to hear the answer.
AdamK
Soundstage conducted and released a set of fairly comprehensive measurements
Anyone care to translate? For example, how does it compare to the Cambridge CXN v2? I have a couple older Nodes and would love something for my bedroom setup that doesn't require an external DAC
Jimbob54
Leaving aside the user experience / interface side of things the CXN whoops the analog output of this - @VintageFlanker measured the CXN on here- its a good streaming DAC. The Node is average at best.
But the CXN is huge and frankly, for bedroom casual listening any performance shortfalls of the Node become somewhat academic.
BUT , personally, I would get a Wiim Pro plus- small and fully functional for far less. The Plus part is important as the DAC in that is competitive. The Pro (non plus) isnt a top flight DAC implementation- for around $70 difference YMMV.
JEntwistle
The DAC portion of the Nodes tend to do poorly in the measurements done here - there is no getting around that. That is the downside. Since you already have some Nodes, if you like BluOS and find it useful, it is hard to beat it for convenience. As Jimbob54 says, the degree to which you would notice the differences is really the question. It might be a situation where the room is not ideal, anyway, so it won't matter much.
But I really wish NAD/Bluesound would get their act together on DACs, because their amps are pretty good, and I do like the BluOS system.
AdamK
Thank you both for the replies.
Context: I am a longtime Roon user. I use old Nodes for outdoors, and a couple Pulse minis in bathrooms. In the living room, I use a Lyngdorf MP-60 2.1. The bedroom and my office will share an old Marantz 8801, which I'm (sentimentally) resisting replacing completely, so figured I'll try a separate streamer and DAC
JoetheLion
Rhineland
If you want a Node whose DAC will probably have very good measurement results, buy a Node X. But you will certainly not hear any difference to the other Nodes (or other DACs discussed here with excellent measurement results) neither in your bathroom, nor living room or outside. All differences are pure measurement differences, all below the hearing threshold.
GTDTS
Can someone help?
I have this unit and it feeds the Anthem STR Stack. When I used the Node’s DAC into the STR Preamp, it sounded terrible. I used the analog out only and it is much better (no Bluesound DAC). Is this copacetic with what the review says?
Thanks!
Any significant improvement if I upgraded a transport unit…Eversolo, PS Audio, Auralic streamer…streamer only. I will use the DAC in the STR Preamp. Thank you for any suggestions!
yodog
Can someone help?
Thanks!
I know from firsthand experience that’s going from a bluesound node to an Auralic Aries g1.1 or better is without a doubt a hugely undeniable difference that’s audible, and felt. Also the sense of rhythm n timing is much more natural and steady.
Good luck and if you got the funds, I highly recommend auralic over the others you mentioned. Good luck. Just curious what speakers, subs, cables, power amp r u using?
VintageFlanker
Paris
Without any objective proof to back that up, it is everything but "hugely undeniable". ;)
Especially if you're talking about digital outputs, there would be zero difference to speak about. Through analog outputs, it could be somehow debatable.
GTDTS
Thanks!
I use the Bluesound as a streamer only and bypassed the DAC. Much better. That feeds an Anthem STR Preamp. Then the separate STR Power Amp to Paradigm Prestige 85F’s.
Furman power conditioner.
Cables are Sewell Silver something or other…many strands. Bi-wired…just for fun.
HSU Sub. VTF MK2…flagship at the time. Love that thing btw.
Rottmannash
Nashville
Isn't the DAC involved when using the RCA outs?
GTDTS
Yes…analogue out. That uses the DAC.
I use the spdif/coax out into my preamp effectively making it a streamer only.
