Review and Measurements of E1DA 9038S BAL Portable DAC & Amp
This is a review and detailed measurements of the E1DA 9038S portable balanced DAC and headphone amplifier. It is the brainchild of the member @IVX. He kindly sent me a sample for review. The cost is stated as "TBD($70)." He will have to tell us if the price is finalized or not.
The 9038S looks like most "thumb drive" DAC and amps with a USB-c connector at one end. Where it departs is that its output is only balanced 2.5 mm jack:
Given the 2.5 mm, 4 conductor jack, you must use a "balanced" headphone cable with it.
There is a blinking orange LED that shows USB activity that I like. It is not very bright so should not be a bother.
The 9038S weighs essentially nothing. It gets a bit warm but nothing of concern.
There are no volume controls so you have to use the controls in your operating system/player.
@IXV has an audio precision analyzer (series 2) and its claim to fame is very good measurements. BUt let's see how it does using my standardized measurements.
DAC Audio Measurements
Let's start with our dashboard view:
The output voltage is a bit shy of 4 volt I like to see from balanced DACs but given that this is a portable unit, that can be forgiven. The output is certainly higher than a lot of portable DACs of this type.
The star of the show is the THD+N and hence SINAD (signal over noise and distortion). At essentially 110 dB, this is class leading performance with distortion products at astonishingly low, -123 dB! And that is the highest one. The rest are below -130 dB. The SINAD therefore is dominated by baseline noise, not distortion. WIth that noise well below that of 16 bit audio, this DAC produces audible transparent sound in just about any situation.
The 9038S takes its place in our cherished, top tier of DACs regardless of cost and size:
E1DA Portable DAC and Balanced Headphone Amplifier SINAD Audio Measurements.png
Signal to noise ratio is excellent as well:
E1DA Portable DAC and Balanced Headphone Amplifier Dynamic Range Audio Measurements.png
Signal to noise ratio at just 50 millivolt to simulate output to a sensitive IEM is likewise quite good:
Frequency response is just a hair off from flat:
E1DA Portable DAC and Balanced Headphone Amplifier Frequency Response Audio Measurements.png
Jitter test shows the excellence in engineering, keeping all sources of noise and spurious tones out of the DAC's output:
E1DA Portable DAC and Balanced Headphone Amplifier jitter Audio Measurements.png
As the name indicates, an ESS ES9038QM DAC is used. Would it have the dreaded ESS IMD Hump???
E1DA Portable DAC and Balanced Headphone Amplifier IMD distortion Audio Measurements.png
Seems like we have found our second designer (after Topping) which has figured out how to conquer this aspect of ESS implementation. There is only a hint of the hump visible which is totally inconsequential.
What is not inconsequential is matching the Topping DX3 Pro step by step which vast majority of DACs fail to do in desktop size, let alone in a tiny package.
EDIT: Linearity is picture perfect:
E1DA Portable DAC and Balanced Headphone Amplifier Linearity Audio Measurements.png
THD+N versus frequency shows elevated noise/distortion due to wide spectrum of this test:
E1DA Portable DAC and Balanced Headphone Amplifier THD vs Frequency Audio Measurements.png
We can see that the cause is harmonic distortion of high frequencies which are not audible anyway.
Headphone Amplifier Measurements
Let's measure the power versus distortion using 300 ohm load:
E1DA Portable DAC and Balanced Headphone Amplifier Power 300 Audio Measurements.png
At 37 milliwatts, the 9038S blows past anything in its size:
And does this while maintaining exceptionally low noise and distortion.
My only other balanced load is 50 ohm:
E1DA Portable DAC and Balanced Headphone Amplifier Power 50 Audio Measurements.png
As you can see, it actually beats the recently tested Sabaj D5 desktop product in how clean it is! Of course, it doesn't have nearly the same power output. But compared to other portable DACs, it is in a class by itself. We are talking a quarter of a watt into 50 Ohm load.
Output impedance is the lowest I have measured but this is with a new optimized harness I built to just test this DAC:
Headphone Listening Tests
I am waiting for my balanced headphone cable to come in. Will test and report back when it arrives. For now, the power levels predict very good performance.
This is one DAC that you don't want to read by its cover. It looks as ordinary as you can get. But inside lives a potent, highly optimized DAC and efficient headphone amplifier. It shows excellent command of engineering and proper design verification through measurements. The result is a DAC and headphone amplifier which gives many desktop products a run for their money, let alone in this tiny and low cost package.
The requirement for balanced headphone cable may be a barrier to some people as you need to get such a cable for your headphone if you don't have one already.
Overall, it is my pleasure to give my strongest recommendation for E1DA 9038S DAC and headphone amplifier. That is job well done! It put a huge smile on my face to see such strong performance and attention to getting the best performance possible in such a tiny package.
I transferred the balance of my paypal account to my bank account. As a result, it now shows $0.00. That makes me depressed thinking I have no money left!!! so please help replenish that account by donating using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
TonyNL
Of course everyone will start googling this. It's not easy, but you can start here: https://e1dashz.wixsite.com/index
It's very similar and shares the same model name 9038S.
headwhacker
I hope the 3.5mm unbalanced version will have the same excellent measurements?
THW
This runs entirely on USB power and has no batteries in it, right?
JohnYang1997
China
The Two tone file pls? Because i found out previously the seemingly harmonic of 1khz is actually modulations around 2khz.
JohnYang1997
China
According to calculation, this unit only has 65ma current output. I don't know why amir didn't test 32/33ohm here.
My 33 ohm load is unbalanced. Don't have time to build a balanced version right now given my workload.
JohnYang1997
China
I guess this can be used as a balanced dac. For 70 dollars even. And this is probably the best use case can most competitive use case. I would love to see if imd hump is present if connected to thx 789/ hpa4.
TonyNL
IVX
South of China, SHZ area, - Слава Україні
Ohh, thank you for the review. Regarding the SNR, it depends on USB 5V rail quality and current loops around it. I took the video with #9038S tied to the USB OTG Android, powered from power-bank i.e. completely isolated from 230VAC outlet, and you can see the SNR is 122.9-123.8dbA, next I moved my wireless 2.4GHz mouse(DUT AP2702 and mouse on the same table) to stop video record and this action reduced SNR to 121dbA. I submit 1dbA just in case and published -122dbA as specs. -118dbA I never have seen yet but I believe it could be in some particular setup.
JohnYang1997
China
Amir doesn't weight the noise. His numbers are unweighted.
escalibur
Solid performance for such small device. This could be very good option for eg. Office and portable usage.
It seems that no one sells this device at the moment?
A few dB difference is really not material here so I would not worry about the discrepancy. My test fixture for headphone jacks is not made to be absolute lowest noise.
But yes, the quality of USB impacts this. I recall my Samsung output was cleaner than my computer's.
