Review and Measurements of Lyngdorf RoomPerfect EQ
onion
So If I had my digital signal fed into the Chord Dac, then into the "high-quality" ADC module, I would gain the sonic benefits of the Chord but can take advantage of the 3400 Roon features, etc.?
I don't think so. My DAC is fed a digital input from a separate streamer (Metrum) which is the Roon endpoint used. I can't use the Roon endpoint in the 3400 with the DAC. I don't think you can route the Roon endpoint in the Lyngdorf to stream music to your DAC and then back to the 3400 for amplification.
onion
LOL - no worries. It's very simple - just use the drop-down menu option for RoomPerfect. Works with any signal you feed the amp.
Sander_web
I use a separate 'streamer' as well, a dCS Network Bridge which in my case functions as a Roon Endpoint.
onslash
just wondering amir but what was your reasoning for purchasing the mark levinson amps you have?
Many reasons. One, I like the way they look. :) Two, I like the efficiency and power they have. Three, I had heard them with my speakers. Four, my company is a dealer for Harman products so I can get them discounted.
JaySlice
Lyngdorf TDAI models claim that no power filter/conditioner is required due to the proprietary PUS, is this true?
Dj7675
This was my unit I sent in. I lived with the unit for about a couple of months. I have a McIntosh MA7900 integrated and at this time used a mini dsp ddrc24 (have since upgraded to the Minidsp SHD) to add dirac for room correction. I would go back and forth between the two systems. Subjectively I just found the McIntosh Amp with Dirac to sound better and the McIntosh could drive my system much louder with ease. However, I thought the Lyngdorf sounded very good and was a very nice compact all in one solution. The Room Perfect implementation is just really well done and is actually really fun to use. You can create and store your own room curves etc. I really appreciate Amir doing such a great job reviewing both the DAC/AMP and Room Perfect. I could find no objective reviews on the Lyngdorf TDAI-3400 (just a bunch of over the top subjective reviews), so even though I decided to sell it I thought it would be really interesting to have it reviewed before I sold it. Also, I hadn't seen much in the way of a test on how Room Perfect handles room correction. It really matched what I heard which was great bass and a fantastic stereo image. It was certainly surprising how poorly the DAC/Amp measured and there really isn't any excuse for such a high priced product to measure so poorly. It is also interesting how critical it is to have high quality room correction for the overall system per
Tip
Willoughby Hills, Ohio
BTW, McIntosh licensed RoomPerfect from Steinway Lyngdorf to use in its more recent A/V processors (e.g. MX160 & MX122) and MEN220 Room Correction System processor.
Dj7675
I believe the mx150/151, mx160, and the men220 have room perfect. Mx122 I believe uses audissey. The mx150/151 looks to be a pretty good value in the used market for around $3k. Used men220s run about $3k. With the mx150/151 you get a very capable preamp in addition to room perfect. I’ve contemplated the mx151 for some time
Duke650
EU
Hi there.
My first post here. Pretty short, english is not my native language, sorry for that.
I wanted to say a big THANK YOU to Amir for the RoomPerfect review.
Based on that i´ve decided to purchase a used Lyngdorf RP-1 aaaand ..... wait for it ...... IT WORKS :)
In my case it was the best way how to spend 1000 EUR for setup-upgrade during the last 30 years or so...
Aaron Garrett
Does anyone know where Radomir Bozovic landed? I still have a TACT Millienium 3, which is an extraordinary piece of kit. I also bought one of his later amps, which died but was really technically innovative. He seemed a bit brusque and incapable of running a company, from my interactions, but also quite brilliant.
Tip
Boz started another company in Albuquerque, NM (at the same address as TacT Audio) called Pontilux (https://www.pontilux.com/Default.php) that does LED lighting for mines and other industrial applications. Boz closed TacT Audio and Boz Audio about a decade ago. Emotiva Audio was going to license the TacT Audio TCS mkIII room correction software/firmware (aka TCS3) for the Emotiva XMC-1 pre-pro in 2012, but the company Emotiva hired to port the software already was porting Dirac room correction for another company and convinced Emotiva that it would be easier and faster to use Dirac instead of TCS3; Emotiva also is using Dirac for their new RMC-1 pre-pro. (I believe I had provided this information before in this thread or Part II of this review.)
I believe that TacT and Lyngdorf each had their own versions of the Millennium 3 digital amp (that was when Boz and Peter Lyngdorf split up TacT Audio). You could check the TacT Audio Users Group on Yahoo Groups for more information (the Lyngdorf Audio User Group has been shut down). I also believe that Peter has given up on the Toccata digital amp, for which he had funded the development and TacT Audio & Lyngdorf Audio used, now that he, Bruno Putzeys, and Lars Risbo have joined together to form Purifi Audio. Steinway Lyngdorf now will be using Purifi Audio's Ncore amp that was developed by Bruno Putzey.
Hephaestus
Rapture
Peter Lyngdorf is one of the founding members of Purifi Audio and acts as a chairman for Purifi Aps - easy to see the NAD and Steinway Lyngdorf connection there...
eliash
Bavaria, near lake Ammersee
This is a follow up to my review of the Lyngdorf TDAI-3400. While that review was focused on objective measurements of the DAC and amplifier, this review is focused on the performance of the room equalization (RoomPerfect). As much as I like to perform a comprehensive test and review of Lyngdorf against a few of its competitors, I just don't have the time to do that. So instead this is a focused test by itself.
I usually don't want to mess up my my main system because it takes me forever to get it back together. In this case I thought it was important to test the Lyngdorf using the same setup given the high cost of the Lyngdorf. At first I was dreading how much rewiring I had to do, only to realize that the Lyndrof has everything my discrete system has sans speaker! So this is the setup:
I took a rather wide shot so that you can get a feel for the room. What you don't see is the rest of the house that is open to this loft area. The volume as such is massive which helps lower room modes to lower frequencies (always a good thing). I normally use Dirac to correct what is left of the bass anomalies up to 200 Hz.
My seating position is between the measurement mic you see poking out of center left and my laptop on the right. This is my own measurement Mic which I used to measure what RoomPerfect had done before and after equalization. The Lyngdorf mic seems higher quality and comes with a long balanced cable. A bit strangely, instead of an XLR input for it in the back, there is an adapter to 3.5 mm which then allows the mic to plug into the front of the unit (this part is convenient).
The Lyngdorf is the black box sitting on my (unused currently) Mark Levinson No 532 power amplifier. For those of you complaining about the cost of the Lyngdorf TDAI-3400, the 523 costs $20,000 by itself! :) Admittedly it has 400 watts using 8 ohm and probably twice as much over 4 ohm so much more powerful than the Lyngdorf. Still, it is just an amplifier.
My everyday amplifiers are the two Mark Levinson No 53 monoblocks flanking the Revel Salon 2 speakers which were used for this testing. Those beasts have 500 watts into 8 ohm and 1000 watts into 4 ohm. In listening tests, the Lyngdorf TDAI-3400 got plenty loud although I had it pretty close to 0 dB at times. Again, this is a huge space so it takes fair bit of power to fill it and shake my seat. :D
To set up the Lyngdorf, I connected it to Ethernet cable and used a browser to configure it. I was pleasantly surprised how well implemented the interface is, feeling just like a mobile app even though it is just a web interface:
The setup could not be any easier. You just follow a handful of steps in the guide and you are done.
Initial measurement is for the main seating (sweet spot) which Lyngdorf calls "Focus." From then, you randomly position the microphone in different parts of the room. What is the idea behind this? One of the problems with room equalization is that if you only measure in one spot, you may make the rest of the room much worse. So in applications such as home theater where multiple people may want to listen at once, you this won't work too well. The random measurements attempt to tease out what is a "room behavior" and what is a "speaker response." To the extent the same problems in frequency response show up in multiple random places, then it is a "property of the speaker" and can be safely equalized. Alternatively, such data can inform how much correction should be applied to some peak if it is not shared in other locations.
Prior to calibration a level check was performed. I was told to dial the volume up to -11 dB or some such number. I could not tolerate the tones above 20 or so dB so that is what I used, thinking I would have to re-do them later. Lower volumes allows more background noise to interfere with measurements although the impact is much lower with newer systems.
The actual measurements consist of playing two seperate sweeps of frequencies, one covering low to mid frequencies and the other from mid to highs. Usually there is only one sweep covering the full audio band. I am thinking there is probably two different filtering schemes for low and high frequencies. Low frequencies require resolution than to one hertz or even lower for precise correction (room modes are very narrow for those of you who want to get technical). This can make the filtering expensive so often a different filter is used (e.g. IIR instead of FIR). I am just speculating here. If Lyngdorf has documented this scheme, maybe someone can chime in with the right answer.
After each pass, you are instructed to move the mic to another random location. I casually did that until the system was happy that it had enough data saying it had understood the room 93%. Objectively I think there was enough data there for 92.295% but I let it go with that. :)
Subjective Results
Nearly 20 years ago I had my first experience with room correction courtesy of a now defunct company, TacT. I remember being startled with what I heard. The transformation is incredible. I forever became convinced that room equalization is mandatory in any home system. I tell you this story because the RoomPerfect was just the same. As soon as I turned on the Focus mode, the (somewhat) boomy bass disappeared, resolution in bass became much higher (allowing individual tones to be distinguished). Soundstage opened up with sound losing its congested character. Everything you think "hifi" is, is applied yet again to your system. You want to sit there and re-listen to your entire library again.
If you have not heard a proper room equalization system, I don't know that you can ever understand the words above. Suffice it to say, nothing, nothing you can do to your system to uplift its performance as much as room equalization can. Why? Details will become obvious in the objective section next but for now, the room gets a hold of the sound out of your speakers and massively modifies the frequency response. Since we are so sensitive to frequency response changes, we hear that as massive coloration. In addition, the changes in bass frequencies translate to elongated (in time domain) notes causing the boominess and lack of resolution.
The effect dies down above a few hundred hertz ("transition frequencies"). Above that the room has subtle changes that are much harder to counter with any kind of equalization. So the transformation in smart systems there is to tonally shape the response. Research shows that we prefer room sound that has more bass than highs. Flat response sounds too bright to us. This type of "target curve" is applied to the equalization as a global touch. For my testing, I used the default target curve. Lyngdorf lets you change that but I did not bother looking for it. Some EQ systems get the target curve wrong and if there is no ability to customize it, you are stuck.
Comparing Focus mode to Global (optimized for wide area), the latter lost a lot of the improvements. It was still a clear step above no EQ but big degradation still. So for any single listening, or even two people side-by-side, I would opt for Focus mode. Indeed shifting my head a foot or two side by side showed more change in Focus mode than in Global (which was almost immune to it).
Let's crystalize these points with actual measurements.
Measurements
I fired up Room Eq Wizard (see my tutorial on REW here: https://www.audiosciencereview.com/...om-measurement-tutorial-for-dummies-part-1.4/). For microphone, I used my USB UMM-6 from minidsp with its calibration file (although I don't necessarily trust the SPL values shown). I placed the mic more or less where the focus measurement point was for RoomPerfect. I then connected to Lyngdorf TDAI-3400 using a USB cable and use it as a "DAC" to drive the speakers with and without RoomPerfect enabled. Here is a comparison of the system without equalization and with RoomPerfect set to "Focus:"
We immediately see the disease and its cure. We clearly see the wild swings in low frequencies that I mentioned (in blue). There is a whopping 32 dB variation in frequency response there!!! :eek: As notes go up and down in frequency in your music, their levels go up and down by these swings, causing massive (linear) distortion of what we are meant to hear. The peaks cause the notes to become louder and last longer, obscuring detail. The valleys are caused by cancellations of bass waves and tend to be less audible due to their narrow width. Still, if they can be dealt with, you want to do that.
For now, ignore everything above 200 Hz or so. RoomPerfect has done exactly what we want it to do: it knocked down the peak around 110 Hz. This is "easy" as you are just reducing level. Not so easy is to fill in the dip which it also managed to do. Improper correction here can result in driving the amplifier and speaker too hard and getting very little for it (cancellations get stronger the more you try to fill in the gap). So very nice to see the gap filled.
Notice the 1/12 filtering of the measurements. For bass frequencies you want to see the detail so I have applied this light filtering. For manual correction I may not apply any filtering but I thought for presentation it made things more clear.
Indeed, when frequencies go up, our hearing resolution, i.e. bandwidth, gets worse and worse. For this reason, to get a good idea of what we are "hearing" as opposed to measuring, you want to dial up the filtering. I choose to 1/3 octave although sometimes I use 1/6 if I am focused more on upper bass:
The extra filtering has smoothed the measurements allowing us to see the trend, and target curve applied (approximately). We see that as I mentioned earlier, Lyngdorf is following the classic target curve of more bass than highs. It has wisely decided to not mess much with the response of my speakers above a few hundred hertz.
Still, I usually find that when you take a way large peaks, somethings the result can be a bit bright. I am detecting a tiny bit of this at times so if this were my system, I would dial up the bass a bit more. Since they are now so clean, having more of them is just goodness. Lyngdorf has EQ settings too that could be used for this purpose (I did not try them).
Lyngdorf RoomPerfect has another setting called "Global" which is designed to give better response in a wider area. Using our higher resolution measurement before, I compared the Focus to Global modes:
As we see, Global mode is very similar to Focus. The main difference is that the amount corrected is lower. That nicely explains my subjective experience of Global not being nearly as good as focus.
As I had expected and hoped, the Lyngdorf RoomPerfect does a wonderful job of correcting the impact of the room, especially in low frequencies. Without correction, every system out there regardless of price of components, suffers from significant audible colorations and loss of detail and focus. No, you can't do the same with room treatment. Even the best treated room requires equalization. Over treating the room to get rid of the modes will create a dull/dead which you want to avoid.
The all-one-one aspect of the Lyngdorf TDAI-3400 showed its value in how it obsolete nearly $70,000 in gear in my room. Integration with Roon player (i.e. streaming) does it for me. Get yourself a pair of excellent speakers and pair it with the Lyngdorf and "you are done." Your tiny system will outperform tons of other systems without equalization.
Note that similar results could be had with other well implemented equalization system. While performance of RoomPerfect was excellent, it didn't do anything other good systems do. So I will be going to my Dirac system and more powerful amplification. But for someone starting fresh and aiming high, the Lyngdorf TDAI-3400 makes a ton of sense and causes you to forget the issues I found in measurements of its electronics.
Overall I am happy to give a recommendation for Lyngdorf TDAI-3400. Its room equalization is a joy to use and makes a fantastic difference to your listening experience.
It is snowing here for the first time this year. I need some money to buy snowshoes. Yes, it is only one inch of snow but you don't want me to fall and get hurt, do you? So please consider donating money using:
Patreon: https://www.patreon.com/audiosciencereview), or
upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
Interesting bass response correction. What I like are the restricted compensation levels to avoid non sweet spot exaggeration. On the other hand, from my experience, having done manual speaker placement tuning in my room (mainly analysing annoying peaks and balancing them) I question myself, if similar might have be achieved with less $$$effort...is the original curve already a result of doing so before?
IVX
South of China, SHZ area, - Слава Україні
Huh, so familiar topic! 3 years ago we designed the room compensation system for subwoofer with minimum phase multi-rate FIR filter
(resolution 2.9Hz, range 20:500Hz, 5mS total latency). iPhone/iPad mic used, $2 DSP ADA1761 + CC2540 = $3.5 opened hardware. During R&D I found that practically impossible to get a well freq.resolution response with a fast sweep in subwoofer range(20-100Hz), just because of echo which requires settling for 100-500mS depends on room size. Finally, I started to use dual sweep, preliminary one for evaluation, and steady-slow next, and the result of compensation was improved a lot. Check this short video out, sorry for unstable camera focus.
Krunok
Zg, Cro
This green part is bugging me from the start of this thread. It is above transition frequency so room shouldn't be causing it and it is hard to imagine speaker of this quality would have it by itself. Maybe more detailed measurements before correction would throw a light on it..
eliash
Imperfection from microphone offset, 10cm?
