- Thread Starter
- #61
I still have it. I didn't run it that way since the software won't overlay it on analog input tests I had run on other amplifiers.Amir,
Is it possible for you to have the - Power versus Distortion using 300 OHM load - with USB Input for Balaced Output vs Unbalanced ? (Just if you did not return the unit to AntDroid -thanks by the way!-) and of course than to Amir for the amazin job!.
I guess should be similar to the one you presented on XLR Input, but I just wnat to confirm if noise issues are more related to Input or to Output... This would be great as we could compare just the Unbalance vs Balanced outputs just with the same inputs.
