Review and Measurements of New Topping D50s DAC
Gradius
Iquique, Chile
The tps65130 inside also makes things worse.
I will remove the switcher and supply by lt3045 +-9v.
I suspect that one is driving the OLED too. I haven't looked at it yet.
However, it will be a little more work, as TPS has 24-pin, and LT just 12 pins, and of course they aren't pin compatible.
Reddy
Germany
The 9v will be supply by a networkcable and will also supply the 5v belleson which I have already put in the system.
I use diyinhk modules for the +-9v
yodog
how much did these mods cost you and which ones do you think were worth the money? Are you going to replace any resistors or capacitors?
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
So...who decided this thing needed to be modded? What is the improvement you are seeking, or is it just that it's fun to change stuff?
@JohnYang1997 , @solderdude ... what do you think? These make any sense to you?
UAN
Kyev. Ukraine
Colleagues, tell me, please, the value of the resistors R24, R27 on the D50s board near OPA1612. removed 2.jpg
solderdude
The Neitherlands
Colleagues, tell me, please, the value of the resistors R24, R27 on the D50s board near OPA1612.View attachment 51521
10.0 Ohm, if you have to ask why are you modifying circuits ?
Why not use a multimeter?
Seems to me the absolute minimum required testing tool for anyone doing mods.
solderdude
The Neitherlands
But it has long been noticed that replacing OA with another one with the same TND affects the sound noticeably.
When tested sighted... sure ..
UAN
Kyev. Ukraine
Many thanks! I have a D50, I want to upgrade to remove the "hump ESS". In the D50s it is not.
BDWoody
Chief Cat Herder
Moderator
BDWoody
Chief Cat Herder
Moderator
The difference with disabled switcher is nice
And, these comparisons are also done with no listening controls or measurements...?
