Review and Measurements of Nord One NC500 Amp
McFly
NZ
I love the hypex amps. Small, cool and powerfull. These measurements are great too if not as good as the NC400's.
Off topic-ish; I bought the NC400 monoblock kit halfway through last year. I remember hooking them up and being very impressed. They did everything right from top to bottom, I heard none of the "class D" cliches I had psyched myself up about. But, something with drums was just not right. Snares and hi-hats especially. I told myself it was just the ultimate clarity and transparency of the amplifier. I used them until last week to get used to the sound.
Switching back to the class AB amp was a real "Ahhhh" moment. There were the snares, hats. Bass guitars even had a bit more flesh and crunch. If living with the hypex was like sleeping in a 5 star hotel It was like coming back home to my own bed. It seems theres no place like ...class AB amps. For me anyway. Call it me enjoying distortion or whatever but the AB amp just sounds more right, if not as transparent and powerful.
gvl
SoCal
Is the switching noise visible on the analog waveform with filtering removed? I presume the level of the switching noise goes up and down with the actual signal, right?
tohoho4
JPN
In my amplifier (TEAC AX-505 using Hypex NCore module), large switching noise is superimposed on 1 kHz sine wave at TEAC AX-505's speaker out.
tohoho4
JPN
Yuck, does the width of the modulation stay constant with varying of the output level?
Yes, the width of the modulation stay constant with varying of the 1kHz sine wave level.
D
Deleted member 2944
Guest
The polarity reversal thing might be expected if there were a single power supply driving both modules.
In that case, you would also see a concurrent polarity reversal on the input jack as well to achieve the double-reversal.
In this case, it's puzzling. Just an assembly mistake I guess.
Dave.
gvl
SoCal
The switching frequency is at around 450kHz. The scope sees it but it does not translate into audio band noise. A speaker simply can't reproduce it. It's filtered out.
I get it, but I like my sine waves clean :) How big is the amplitude of the switching frequency, in Volts?
March Audio
Albany Western Australia
With respect I don't think you do understand it. The sine wave, within the audible band is clean. What gets reproduced by the speaker is clean. There is no trace of the switching frequency being reproduced.
Very few speakers will get to 45kHz let alone 450kHz
gvl
SoCal
I meant for my eyes, not my ears. Most of the tragedies we see on this forum are for the eyes anyway.
March Audio
:) Yes this is true. We sometimes obsess about some of the visuals of graphs without assessing the real audible impact.
If SFDR of a piece of kit is above say 110dB why should we care? Good kit has got there.
Music1969
I've seen posts like this around, about issues with Class D amps affect tweeters:
https://forum.audiogon.com/discussions/pop-crack-on-power-up-followed-by-audible-tweeter-hiss
Another discussion here, where Ribbon tweeters are less susceptible to this "issue" by ultrasonic switching noise:
https://forum.audiogon.com/discussions/anyone-using-a-class-d-amp-w-ribbon-tweeters
March Audio
Anything can be badly designed. You have to separate that and not generalise.
One potential issue is that intermodulation can result *IF* an input signal is close to the switching frequency. However a good design will ensure that the input is filtered and doesnt let signals close to switching frequency in. 450kHz ish in the case of Hypex amps. This is well up into RF range.
I will get the scope on.
gvl
SoCal
So, the switching noise, it's a constant. What voltage is it in absolute terms? Nano? Milli? Kilo?
Music1969
Possible with a DAC is connected direct to power amp?
Especially DAC's that up-sample to high sample rates? Many up-sample to 384kHz and above these days, before converting to analogue?
tohoho4
JPN
In my amplifier, the amplitude of the switching frequency is about 620 mVp-p. I don't know the sound quality is accurately transfered to you on youtube, but the sound quality is excellnt.
Reactions: Tks
