Review and Measurements of Purifi 1ET400A Amplifier
MJT
Doesn't quite work that way ;):
Thank you! I thought converting to percentages would add linearly, but incorrect. Amir also points out the combined effect is negligible when the two devices vary greatly. You can see how this plays out when using the calculator he linked. The DAC8 excellent SINAD of -118dB has little bearing relative to the Purifi with gain..
-118.027dB (DAC8 Pro) & -104.124dB (Purifi with gain) --> -103.951dB
Yes, that is the point to have least effect, but if we pair up Ultralite with the same Purifi with gain, the difference between the DAC8 and Ultralite isn't even within JND because everything is brought down by the weakest link being -104dB..
-112.860dB (Ultralite) & -104.124dB (Purifi with gain) --> -103.579dB
Thus even with Ultralite's much less SINAD, it's significantly beneficial to get that lower number up with "no gain"..
-112.860dB (Ultralite) & -108.145dB (Purifi no gain) --> -106.881dB
Of course Amir describes the noise component of THD+N is affected by spectrum correlation. The Ultralite spectrum does differ from the Purifi more than the DAC8 does, so the noise component less overlaps/compounds.
Not to get O.T. with these particular DACs, however it's insightful when pairing the Purifi in general.
RandomEar
I'm not sure where to find the SINAD over voltage values for the DAC8 and UltraLite, but I assume the -118 and -112 dB are achieved at their respective maximum voltages, right? If so, I'd say you can't calculate it this way, as the amp would already be far past the clipping point with the gain enabled and >4 V at the input. To make the comparison fair, you'd have to use the DAC SINAD numbers at around 1.5 V, which are significantly lower - probably around -110 and -105 dB. That would give the "full blast + no gain"-combo an even higher SINAD advantage. Likely all in the inaudible territory, but still nice to know ;)
Reactions: MJT
mdsimon2
Detroit, MI
The Ultralite Mk5 does not like amplifiers with low input impedance (like you get when not using a buffer), the result is higher distortion. I show some measurements of this here -> https://www.audiosciencereview.com/...xxmp-buffer-bypass-someone.32763/post-1147902.
That being said I think system SNR (combined DAC and amp) as a function of volume position is the more relevant metric for comparison. THD goes down at lower volume levels but noise stays constant with digital volume control, therefore at most volume positions SNR is more relevant than SINAD (not to mentioned that at higher performance levels SINAD is often dominated by noise).
Michael
MJT
If so, I'd say you can't calculate it this way, as the amp would already be far past the clipping point with the gain enabled and >4 V at the input.;)
The Ultralite signal is 8.6v, Purifi amp is input without pre-gain 10.59v, so 81.2% power. But now this is made irrelevant by..
Very appreciative to know this. Pre-gain required for both options.
I was arriving at this as well. DAC8 excels at SNR and clearly multi-tone test. Since I'm already using NC400 for 7.1, I'll upgrade to the DAC8 (when available) and wait for measurements on the new Purifi 1ET7040SA.
I appreciate learning so much through exchange of ideas. This forum continues to amaze me. Being fully informed of component choices makes final selection more assuring and way more rewarding.
EDIT: Just ordered DAC8. Super excited!
RandomEar
My comment was aimed at the case where you use the DAC at full power and the amp with activated gain - I think the maximum input voltage in that case is 1.5 V, right? Anyway, I think your hardware choices will result in a more than capable setup :)
Reactions: MJT
mdsimon2
Detroit, MI
I've been meaning to write a longer post explaining how to compare noise performance between different DAC and gain settings with the Purifi. Everything shown below is based on values measured by Amir but should be pretty close to spec'd performance for the equipment in question.
DAC8 pro w/ 1ET400A at 27.5 dB gain
DAC SNR = 122 dB at 3.3 V
DAC residual noise = 3.3 x 10^(-122/20) = 2.62 uV
amplified residual noise = 2.62 x 10^(27.5/20) = 62.2 uV
amp SNR at 5 W in to 4 ohm = 105 dB
amp residual noise = sqrt(5 x 4) x 10^(-105/20) = 25.1 uV
system residual noise = sqrt(25.1^2 + 62.2^2) = 67.1 uV
system SNR at 5 W in to 4 ohm = 20 x log (4.47 x 10^6 / 67.1) = 96 dB
Ultralite Mk5 w/ 1ET400A at 12.8 dB gain
DAC SNR = 121 dB at 8.6 V
DAC residual noise = 8.6 x 10^(-121/20) = 7.66 uV
amplified residual noise = 7.66 x 10^(12.8/20) = 33.5 uV
amp SNR at 5 W in to 4 ohm = 110 dB
amp residual noise = sqrt(5 x 4) x 10^(-110/20) = 14.1 uV
system residual noise = sqrt(33.5^2 + 14.1^2) = 36.3 uV
system SNR at 5 W in to 4 ohm = 20 x log(4.47 x 10^6 / 36.3) = 102 dB
So about a 6 dB improvement in system SNR when using the Ultralite Mk5 with the low gain setting. Interestingly enough if you went with an implementation with a mid-gain setting like this -> https://www.audiosciencereview.com/...ics-hpa-s400et-review-stereo-amplifier.32014/ and used the Okto you can get the same noise performance
DAC8 pro w/ 1ET400A at 20.2 dB gain
amplified residual noise = 2.62 x 10^(20.2/20) = 26.8 uV
amp SNR at 5 W in to 4 ohm = 107 dB
amp residual noise = sqrt(5 x 4) x 10^(-107/20) = 20.0 uV
system residual noise = sqrt(26.8^2 + 20.0^2) = 33.5 uV
system SNR at 5 W in to 4 ohm = 20 x log(4.47 x 10^6 / 33.5) = 102 dB
Although honestly all of these systems are very low noise and unless you are using extremely sensitive speakers you will not have any noise issues. For reference I like to keep total residual at less than 200 uV so these are all well below that.
Michael
MJT
Very nice. The mid gain setting looks like the perfect match. Max power at 4.2v (DAC8 4.1v). Most helpful.
auraluxstudio
Back to the original point of this post: Where can I buy one of these already built? Any good reputable companies selling them assembled? TIA!
auraluxstudio
There's a $1000 difference between an NCore 252 amp and a Purifi?? If so hell no it isn't worth the difference. I have a Buckeye 252 and a VTV Purifi and they sound VERY close in SQ. The Purifi appears to have a bit more power but the 252 gets quite loud without distortion. Either would work for most.
I wish the guy from Buckeye would contact me. I requested a callback. Same with VTV. Apparently these guys aren't very "hungry" for sales...?
restorer-john
Matias
São Paulo, Brazil
Rottmannash
Nashville
Call back? I doubt he will call you. Did you PM him on this site? Or on his website? Dylan is very responsive when I've messaged him in the past.
Matias
São Paulo, Brazil
mk1classic
Is the boXem 4215/E2 plenty of power for the following speakers? I never want to under power a speaker. ATC is recommending up to 300 watts.
Speakers: https://atc.audio/professional/loudspeakers/scm20psl-pro/
According to the user manual for your speaker:
"Typically, best performance comes with use of amplifiers capable of >150W continuous into 8 ohms"
The boxem mentioned is 210w @8ohm, so should be more that suitable.
Why would you "overpower" the speakers?
If you need to power and play a studiomonitor to levels where the speaker goes into compression, I would look into other solutions.
Rottmannash
Nashville
I sent a message on his website. Does anyone know what availability is like?
I preordered a 3 ch Purifi amp several months ago (he requires half up front then the rest near completion) and I believe he is getting close to delivering it. I would PM Dylan on ASR.
Julf
Amsterdam, The Netherlands
peng
The answer would depend mostly on:
- your speaker's sensitivity
- distance from the speakers
- maximum spl you listen to
It seems that ATC does not provide a sensitivity spec so if you want to be sure, go with an amp that is rated for 300 W 8 ohms, 500 W 4 ohms, that you know it is plenty. In reality, my educated guess is that the 210 W rated 4215/E2 will have all the power you need for those speakers, that looks to me are more for near field listening. What is you listening distance?
