- Joined
- Sep 4, 2019
- Messages
- 1,172
- Likes
- 2,322
How much power do I really need? Interesting video.
It is important to keep in mind that power needs are highly dependent on speaker sensitivity and listening distance. Here, the Harbeths sensitivity is a bit on a low side at 84.5db/2.83v/1m. They are a pretty good sized speaker, so will likely go in a reasonably large room. Lets compare how just changing listening distance can vastly change the power needed:
- At a 15 foot listening distance with 800 watts you get 106.3 db peak (loud but not super loud when playing dynamic music)
- Drop that listening distance to 9 feet and the power get 106.3 db drops to 320 watts.
- Go to a more efficient speaker like the Revel Salon 2 (86db/2.83v/1m), which is still on the lower side of efficiency and at 9 feet it takes 200 watts to get the same 106.3 db output.
- Go even more efficient, say a Revel F208 (89db/2.83v/1m), which is pretty average for floorstanding speakers, now your power requirement to reach 106.2 db at 9 feet is down to 100 watts.
When looking at amplifier needs, it is always important to factor in the speaker efficiency, listening distance, and listening levels. When in doubt, go larger, you are less likely to damage a speaker from too much versus clipping the amplifier. I will say that many systems do end up with minor clipping due to not enough power and it often not noticeable until you have an amplifier that doesn't clip, the sound is effortless rather than getting strained or congested at high levels. (For reference my amp puts out 700 watts into the F208s for peaks).
