Review and Measurements of Schiit Saga Tube Pre-amp
Palladium
Pardon my noobness but I'm confused about what about does passive or active mode mean on this?
Cougar
It's a Passive Preamp but has a Tube Buffer to help with longer runs of cables from preamp to power amp. It's still 1 to 1 gain or unity gain. So you will need a Source/s that puts a good level on its output or you will be maxing out the volume on the Saga + I would get up to 1-2pm on the volume knob before I got the ART RCA to XLR converter and that was pretty loud for my system which has 87db speakers.
Aneal
so I'm about to pull the plug and buy one of these units to run my audio alchemy overture OM150 amp. Right now I got my Aiyima t9 running as a pre amp. what I like out the saga is the 2 out-puts so i can run one to my sub amp so I don't have to run a Y- connector. question 1: how do you like the saga? from this thread looks like a positive one and 2: is the saga+ worth it? I don't have log cables, the longest is 6 ft. here's my setup, thanks for the help
RedBull15
Hello,
I am interested in using this pre-amp to switch between my AVR line-level output Front R - L Mains and a DMP-A6 DAC to my 2-channel Pass Labs x350. Would this be a good solution for my needs and would it be better to run passive for both line-level inputs or would I benefit from the active stage? I will be controlling my volume from the AVR for theater listening and in 2 channels from the DMP-A6 DAC. If the Saga+ isn't a good solution I am open to recommendations. Looking for the best sound quality without losing gain between connections.
Thanks
GXAlan
Hello,
Thanks
Essentially the passive preamp is going to work great. But if all you need a source selector, you might be fine since you would be running the preamp at full blast and using the upstream sources to control volume.
That has no remote.
I personally opted for this:
To give me a passive volume attenuator and a tube option.
RedBull15
Thank you for the reply, looks like the Freya S in passive mode for my AVR RCA input would work. I am using the internal DAC of the DMP-A6 RCA output as well because I have the XLR output connected to my active subs. Should I use the pre-amp of the DMP-A6 to control volume or run fixed and use the Freya S active tube stage output?
AaronJ
Hello,
Thanks
I would get a preamp with a HT pass-thru instead of a Saga. I think it’s best to separate the volume control so the AVR does the work without being tied to the volume control of the preamp. Something like the bypass input of a Parasound Zpre3 which is a comparable product in price and features.
