I want to better understand the test data AP sends to the DAC during the linearity test, does it always set a single bit to 1 and others to 0, or it uses values, perhaps random, that can result in multiple bits set to 1 in individual samples?
The "data" sent to the DAC is a simple sine wave. Linearity test keeps changing its level and measures the output of the DAC. At all times the DAC sees a sine wave.I want to better understand the test data AP sends to the DAC during the linearity test, does it always set a single bit to 1 and others to 0, or it uses values, perhaps random, that can result in multiple bits set to 1 in individual samples?
I have recently learned that purgatory for audio is having to measure Schiit audio gear over, over and over again...Since dither is generated within the DAC, not provided by the source, I am having a hard time seeing the relevance of this test?
I'd rather Amir spent his time testing something, anything, else...
Purgatory or maybe a Sisyphean task?I have recently learned that purgatory for audio is having to measure Schiit audio gear over, over and over again...
I think with a little photo-shopping we could turn that into a new Avatar.
Pushing Schiit up hill?
There’s something magic, heroic even about the dung beatle , I can’t help but think nature played a cruel joke on the little blighter though, poor bastard ...
Here is the comparison of 16 bits versus 24 bits:
The noise floor jumps up by 30 dB when using 16 bit samples. Is this what you were asking about?
Dither will only improve performance if input bit-depth is higher than output bit depth. That means a 20-bit device can playback any bit-depth equals to or less than 20 bits without causing any truncation errors.
As long as there is no additional DSP (e.g. volume control, EQ etc) between a 16-bit file source and the input of a DAC, dithering will not make any improvement other than adding a layer of useless noise.
Dung is fairly amazing, it can be used for all sorts of things and is vastly superior to schiit.
The bifrost multibit and modi multibit are 16 bit dacs, so the noise wouldn't lower with 24 bit files.I would expect the same sort of thing when playing 24 bit files through the Modi Multibit.
DSP includes upsampling and filtering.Any upsampling and filtering
Of course not. The DAC could tell owners it only accepts 20 bit or less inputs or quality degrades. It could do the proper thing and dither 24 bit input to 20 bit internally.Don't you think that measuring low level linearity of a technically 20-bit DAC with 24-bit input data, especially undithered, is fundamentally wrong?
What do you mean undithered? All signals I send to it is dithered.Don't you think that measuring low level linearity of a technically 20-bit DAC with 24-bit input data, especially undithered, is fundamentally wrong?
