Review and Measurements of the Leaf Audio DSD1796DAC
WolfX-700
China
Last Wednesday, forum member @Zek asked me if I could measure Leaf Audio DSD1796 DAC.Because he was very curious about the DSD1796 chip.
This is a cheap unit. So for this friend's curiosity ... I bought one.
Helping others is also redeeming yourself.
Here is the time for the 555 and Leaf DSD1796 joint show
Designer claims THD + N is 0.008%
-20dbFS
This is much better, so I suspect the problem comes from a USB-powered design with a single 5V power supply
D-R
THD-Ratio
IMD-SMP
And Headphone Amplifier:
I use a 50R resistor as the load
This is a simple review and measurement.
Overall, I think the performance of this unit is average.
But taking into account (I bought) the price and features. I think C / P is high.
Zek
Thank you @WolfX-700 :)
Is the measured device a standard model or a tweaked one?
WolfX-700
WolfX-700
China
Standard model
I have the same OPAMP as the tweaked one, I also tried to replace it and did a quick measurement-basically no change
pma
Prague
Clipping looks different, like crossover distortion. The profile for 0dBFS is analog output stage distortion.
Zek
I tried to explore what the difference was - replacing some capacitors and op-amps I think.
WolfX-700
WolfX-700
China
I asked the developer, tweaked one just changed OPAMP from 4580D to 49720NA
JohnYang1997
China
emmm. The performance is pretty bad regardless of price. Is it better than apple dongle? And meizu dongle?
Zek
I compared the inside images of Leaf Audio and Douk Audio and found differences in 12 capacitors and 3 op-amps.
You measured Douk Audio and not Leaf Audio - is there any difference between the two.
HammerSandwich
That's useless. The DC interface is also a 5V design ...
Could there be a boost converter that can use more input current? I can't imagine including the extra port & switch if they do nothing.
EDIT: And now I've seen @Zek's pictures...
WolfX-700
WolfX-700
China
View attachment 41041View attachment 41042
Aha, you pay great attention to details
However, this is only the difference between production batches ...
bunkbail
Depends on the power of the headphone out, I guess.
