Can anyone recommend a vendor that doesn't ship from China? And ships to Canada?
The DX3Pro would run a 6XX perfectly fine on low gain. High gain doesn't "ruin accuracy", it's that the upper limits of HG output in devices are more prone to approaching audible distortion. That's why there are graphs comparing a device's various output levels that Amir also helpfully comments on.So in the end HD6XX would need high gain switched on for the amp to do the trick? If you were using 6xx exclusively with this thing would you be satisfied? I perhaps wrongly have a fear of high gain ruining the accuracy.
I bought one from the Aoshida store in its 11/11 sale debut and it was delivered within 3 weeks. They declared full value though, but sometimes Chinese retailers won't and you save big on sales tax and import fees.
Thank you for the information.
I don’t need it otherwise, but I’m using high gain to keep the relative volume level closer between the HP and LINE OUT modes.If you read the measurements and review, the conclusion was that in the DX3PRO, even in high gain, distortion was low and below the audible threshold, even with volume at max. Low gain generally measures better, but both low and high have such low distortion as to be inaudible.
Bottom line, if you like the additional volume high gain gives you, there is no reason not to use it.
I also use this with the HD6XX and find high gain very much needed for my listening preferences.
I updated the firmware immediately.
But I do not know what has changed.
(I ordered the second DX3 Pro of Aoshida-HIFI Audio Store to AliExpress 11.11, but DX3 Pro will not reach after 36 days. I asked them about shipping, but they are totally unkind as they are just excuses. I applied for a refund to AliExpress.)
Getting a click when sample rate changes. No clicks in wasapi mode (event) in foobar2000 after every song change/seek function. We should see more detailed answers later.Did the clicks stop?
You will notice more later, trust meBrief testing on my side indicates no clicking sounds when pausing and playing tracks, dead silence when switching from Tidal to Google Chrome and then playing a YT video from there also, clicking sounds only occur when sampling rate is being changed
You can also connect directly to power amp without input volume.Would this unit be a suitable dac and pre amp to plug directly into a power amp like a Vidar or something?
The clicks...Every time you start a YT video, freaking....What do you mean?
