Review and Measurements of WesionTEK Khadas Tone Board DAC
March Audio
Albany Western Australia
So looking at the headphone 'conv', this thing can properly direct drive headphones :) ? If so, a cool feature.
It can but due to the 100 ohm resistors in the output it will have limited volume capability dependant on headphone impedance. Also due to this its probably only really suitable for headphones that have a constant impedance V frequency, i.e. magnetic planer types.
Veri
Ahh, yes. Makes sense. I asked because the PecanPi has <1ohm output impedance over RCA and can drive headphones with such a converter/adapter. I was thinking maybe the Khadas could, too :) but alas, won't work well with most headphones!
Zek
In a schematics[1] of this DAC there are opamps marked RT6862D and RT6863.
solderdude
The Neitherlands
RT6863 is the output opamp. As March Audio correctly explained the output R is a bit high (100 Ohm) for all headphones and output voltage a bit low to properly drive high impedance headphones.
As it is a DIY board one can lower R43 and R50 to say around 5 Ohm by paralleling a 5.6 Ohm resistor to R43 and R50 and have a lower output R but the max output voltage will remain the same. The RT6863 is spec'd to deliver 100mA so a 32 Ohm load can be used without issues it seems.
The question is whether or not the DCDC converter can supply 200mA and what the power supply voltage is.
Maybe the output voltage can be increased a bit and it could drive higher impedance headphones better directly.
g29
When we have a new version of audio board, we would love to ship to Amirm for testing, it will be our great honor. Thanks to the review of Khadas Tone Board on Audiosciencereview.com, people began to know it and have to accpet it as a single board without casing. That is really appreciated. As in the past 3 months we dont have any good selling score until the review comes out. @amirm Appreciated.
Cool beans. Any ETA's and information on the new Balanced Version ?
Balanced Version
bornstron
this is the type of things i am mad i don't know about.
i have jds labs atom and i have in mind getting HD650 which has 300 ohm's
i also planned on getting khadas tone board. but i thought i was being smart for waiting since everyone saying khadas will release in Q2 some updated version (have no clue about that and will it affect my listening experience).
now i don't even know if i should get khadas tone board whatsoever.
@March Audio please explain your quote to me. halp me o_O
DarrylG
@bornstron, he's talking about trying to listen to headphones through the Khadas Tone Pro's RCA output jacks instead of the headphone jack of a power amp (like the Atom) that it's connected to. For whatever reason, Khadas includes a cable that allows you to connect headphones to the DAC's output jacks.
March Audio
Bottom line is that the board has high output impedance which is fine for driving amplifiers but not the best situation for driving headphones directly.
Really you need an external amp to use with it, which you do, so all is good :)
g29
For a Benjamin, I decided not to wait for the balanced release and give the unbalanced version a shot. Ordered from DigiKey, should be here by the weekend. If the yet-to-be-released balanced version is a success, may try that one as well. Thanks @amirm for reviewing this one.
g29
Digikey delivered a day early !!! Boy is this thing tiny.
Flashed the latest firmware, deleted the demo drivers, installed the new drivers and sparked it up.
ASIO, Kernel Streaming, WASAPI and Direct Sound showed up in JRMC on Win7-64-Ultimate. 16/44.1 to 24/352.8 Flac as well as 1X & 2X DSD played without a hitch. Only change to JRMC was to select the audio device.
The RCA outs are 6dB down compared to my XLR DAC according to REW.
So far very impressed with this compact DAC package. What a pleasant surprise. It appears good things do come in small packages.
Thanks @amirm for measuring this DAC board and making it known.
nymeria96
Mine is on the way. How did you flash the firmware? Do you need their VIM or can you just hook up the DAC to the PC and update the firmware?
g29
Their instructions can be found on this URL Setup and install instructions and the corresponding download links.
You basically download the packages, unrar them, install the demo drivers on the PC, flash the DAC over the USB connection, uninstall the demo drivers from the PC and then install the latest drivers onto the PC. The flashing tool requires the demo drivers, not the current drivers. Playback uses the current drivers. No VIM is required.
sojer2005
Hi,
Could someone comment on this?
Is Allo DigiOne able to control volume of Khadas Tone Board without degrading sound quality?
I am using Roon Labs software for library management and playing.
xarkkon
Has anyone tried both this and the hifiberry dac+ pro? currently using the latter and looking for an upgrade. wondering if this would be it. Thanks!
