Review and Teardown of Douk audio MC103 PRO switch
LTig
Europe
This is a review of the MC103 Pro XLR switch sold by Douk Audio. There are two versions with the same model name:
  • 3-to-1: 3 inputs (XLR female) and 1 output (XLR male)
  • 1-to-3: 1 input (XLR female) and 3 outputs (XLR male)
The price is around §/€ 60.- for each of them. I have them both, but the review covers the 3-to-1 version.
Here is the view of the front - please note that I took this photo with the lid unscrewed, that's why it is not sitting correctly on the right hand side.
View of the back (also taken with lid unscrewed):
The switch looks a bit cheap, neither fancy nor over the top. Front and back are plastics, bottom and top are metal (aluminium). I would have preferred a full metal housing for better shielding. The switch works precise but does not feel expensive.
Teardown
To open the housing remove 4 screws and lift off the lid:
Measurements
I used my RME ADI-2 PRO fs with +24 dBu reference level to get the highest possible Signal/Noise ratio. The cables were 40 cm long and made by me using Neutrik connectors and Klotz microphone cable. For comparison the following plots always show the loopback performance of the RME for comparison.
THD
I used a 1 kHz signal with +21 dBu level because the THD of the RME is lower at -3 dBFS than at 0 dBFS. I set REW to average 16 spectra of 32 kHz FFT size to dig deep into the noise.
As one can see there is no difference between the switch and the loopback. We can safely assume that any distortion or hum added by the switch (if any) is below that of the RME. We need an AP to dig deeper.
Crossfeed
I measured with several sinus signals between 20 Hz and 20 kHz at 0 dBFS output. We see 5 curves in 3 groups:
  • green/orange: crossfeed of the switch, from left to right channel and from right to left channel
  • pink: crossfeed of the switch, from left channel input X to left channel input Y
  • red/blue: crossfeed of the loopback, from left to right channel and from right to left channel
Results:
  • Above 1 kHz the crossfeed between inputs is 12 dB higher than the interchannel crossfeed of the RME.
  • Above the interchannel crossfeed between left and right channel of one input is about 24 dB higher than the RME.
  • Below 1 kHz the crossfeed results suffer from the inherent noise of the RME although on a very lowe level. We can safely assume that the real crossfeed curves continue to decrease with decreasing frequency.
EDIT:
As @MC_RME has stated in posting 7 the reason for the higher crossfeed above a few hundred Hz is capaciticve coupling. He recommended to redo the test using the balanced phone output due to its much lower output impedance (0.1 Ohm vs. 200 Ohm). Here is the result:
Yep, we are more than 20 dB better at 20 kHz. Looking sharp one sees that the crossfeed of the switch is identical to the RME loopback, so what we see is the limit of my measurement rig. Well done, Douk Audio.
Conclusion
I have been asked whether this switch is an "audiophile" device and whether it could be used between a highend DAC and a highend power amp. Regarding the results I simply say yes. Both distortion and noise added by the switch are below audibility level in all home environments I can think of. Whether an audiophile wants to use such a cheap looking device in his highend system is another question I'm not going to answer.;)
GokieKS
Austin, TX
I have one of these between my DAC (RME ADI-2 DAC FS) and power amp (March Audio P252), and it works perfectly fine. My only issues with it is that the knob doesn't line up perfectly on the center Y marking (but I only use two inputs so I just use X and Z instead), and that it's so light that sometimes the thing will move when I switch inputs if I don't also use a hand to press down on the casing.
LTig
LTig
Europe
Oh, I just bought one to test because I plan to use it to switch between powered monitors for testing. It just came today! :)
Too late ... :p
Well, let's see what your AP finds below the noise floor of my RME.
jjk
San Antonio, TX
This would be really helpful to me, reference my issues with the Freya!
KMN
Does anybody know if pin 1 is switched? or is it just pin 2 and 3 switching?
MC_RME
I excpect the crosstalk to be capacitive coupling on the switch PCB.
What you could try is using the phones outputs in balanced mode with a TRS to XLR M cable. Output impedance is then down to 0.1 Ohm (instead of 200 Ohm). That would remove the influence of capacitive coupling. It would also explain why Amir had measured lower crosstalk (APx has 40 Ohm output impedance).
LTig
LTig
Europe
Just measured with my ohmmeter:
  • pin1 and the shield are always connected
  • pin 2 and 3 are switched
LTig
LTig
Europe
Done, and of course you are right:
At 20 kHz we are more than 20 dB better. I've added the plot to the review above.
OTOH I think that the first measurement using the normal outputs with 200 Ohm output impedance may be closer to real world applications. We know now that sources with higher output impedance suffer higher crossfeed.
MC_RME
Yes, we have to draw the right conclusions. Using 0 Ohms showing a near perfect result does not mean the switch works and we ´(I mean you and Amir) measured it the wrong way. Indeed it should be perfect with 200 Ohm source impedance. So the layout or internal design of the switch could be better (I doubt the front switch itself is doing this...maybe only partly).
On the other hand we are talking about numbers that are far away from any real-world problem, so we learned something and can now forget this 'issue' ;)
beantownT
I have been using the switcher to switch between DAC-> Amp vs AV-Processor to AMP. Was working fine until i put in a more powerful power amp(apollon audio PNC1200). Now i have a hissing noise when i go DAC->Amp. Its only audible <1ft from the front left right and none from the MLP. Any advice? The thought of the hiss is driving me insane
beantownT
@staticV3
i actually have this one (MC3)
MC3 Input A: DAC
MC3 Input B: Processor
MC3 Output: PNC1200
Input A: hiss
Input B: very very little hiss
If i change the PNC1200 to my other Apollon Audio Purifi 1ET400A 8 Channel amp then no hiss on either inputs
i havent tried DAC-> PNC1200 yet.. good point
TurboTruite
Really wanted to like that device as I was planning to use it as a monitor switcher for my home studio.
I thought that it was wired to maintain constant shield connexion even for "not-selected" outputs, but it seems like it's not.
My non selected monitors clearly have the shield floating, with RFI coming in and all. (Coleman LS3 does not exhibit this, speakers remain completely silent, selected or not)
Has anyone confirmed this on their unit?
dagfinn
Nice, just what i needed. With a Mackie Big Knob passive, I can switch between 4 monitor sets and have volume control :).
