- Joined
- Oct 11, 2019
- Messages
- 1,863
- Likes
- 2,798
Oh, you wanted the ability to remove the dongle. Gotcha!
Yes, the volume cap is on EU dongles per EU regulations. The dongle sold in the rest of the world does not have the volume limiter and has better measured performance.I’ve discovered something regarding the lightning dongle. Living in the UK post Brexit it’s hard to know what our phones and dongles output anymore so I did a little experiment. Within ios14 you can set the volume level to a maximum of 100db manually. Using my HD660S, when I turn this OFF (no limit) and turn the volume to maximum it gets very loud, my comfort(listening) level is about 2-3 clicks from max volume like this. When I turn it ON and set it to 100db I would say it it’s the equivalent volume of about 2 clicks from maximum when it’s turned OFF.
I’ve not got the equipment to test the voltages but this would suggest that there is no 0.5 v limit being applied to the lightning dongle here in the UK anymore based on my basic experiment.
Do any of you guys know any more info about this cap as of now?
Oh, wait—you do not have the volume limit anymore? Good deal.I’ve discovered something regarding the lightning dongle. Living in the UK post Brexit it’s hard to know what our phones and dongles output anymore so I did a little experiment. Within ios14 you can set the volume level to a maximum of 100db manually. Using my HD660S, when I turn this OFF (no limit) and turn the volume to maximum it gets very loud, my comfort(listening) level is about 2-3 clicks from max volume like this. When I turn it ON and set it to 100db I would say it it’s the equivalent volume of about 2 clicks from maximum when it’s turned OFF.
Yes that seems to be the case. I can’t measure the output voltage but based on my little test it would seem that I am managing to get more than the 0.5 v limit (which I think equated to “85-100” dB)Oh, wait—you do not have the volume limit anymore? Good deal.
Cool idea, but why not cut off the TRS and strip the cable and connect it directly to the RCA jacks?
I tried using the usb3 apple dongle tonight from my iPad and that gets even louder than the lightning one from my phone. I’ve no idea anymore what the lighting dongle is outputting.Yes that seems to be the case. I can’t measure the output voltage but based on my little test it would seem that I am managing to get more than the 0.5 v limit (which I think equated to “85-100” dB)
I just purchased the $9.00 generic DAC from Amazon in order to salvage the case and RCA plugs. I’ll then retrofit the Apple USB-C DAC inside, modding the case as necessary. Should be a fun little project.Really just so I can remove/replace the USB-C dongle should I wish to.
I replaced the dongle with a KTB (Khardas Tone Board) and no clicks through the powered speakers when the DAC was not in use.
I then swapped back to the dongle and instead of the powered speakers I used a JDS labs Atom headphone amp and the clicks returned, although (subjectively) they seemed to be far less frequent.
Next is to try another source instead of the mini, but that might have to wait for a time.
From your experience, no I don't think so. Unless you want something with a physical knob you can turn.Still, I guess I don't need to buy an amplifier then?
