REW Help - how to measure with EQ applied?
BrokenEnglishGuy
lol that's a long time back, since then I found it's the windows 11 setting blocking the APO from being effective, now it's up and running amazingly
Wich config?
I want to see the result from REW but i can't using W11 + REW + APO :/
I can use the APO+REW, just not see the post results :/ APO is doing nothing while rew is using
YSC
Wich config?
if it's running without but with rew it stops, I think you need to use non-asio driver for rew and use the java or something?
for my case it's the "sound enhancement" in win 11 being disabled so it won't do anything in reality to the output at first
BrokenEnglishGuy
it doesn't stop, it just not do anything to the rew, i can put the pre-amp at -30dB and REW completely ignore that, works in everything but rew...
i can't Re-measure the results, only apply them
Damian.DJ
what if you apply eq to the sweep file and then play it in REW would that count?
