RME ADI-2 DAC troubleshoot help
AJG
Hi I’m trying to get my RME ADI-2 DAC to recognize the signal from my BluOS 2I Node streamer but there’s no recognition on the RME of any signal coming in (usually reads 44.1 or 96 kHZ etc. Can someone please help me? I can send photos of the rear of of the RME cables going to preamp etc. I have a digital cable going from the BluOS to the RME and I have balanced interconnects going from the rear of the RME into my AR Ref 5 preamp….what am I missing? Thanks all!
tuga
Oxford, England
The obvious question is: have you selected the correct input? What cable are you using to connect the streamer, coax S/PDIF?
A
AJG
Digital cable coming out of Buos into RME
A
AJG
the balanced cables are coming out of the RME into “Aux 1” of the AR Ref 5 preamp.
tuga
Oxford, England
Do you have an alternative digital source with S/PDIF coax out that you can test into the same settings? (e.g. DVD player, TV)
tuga
Oxford, England
Also, can you raise the DAC volume to -3dB?
A
AJG
Meaning take the digital cable out of the BluOS and put in my Oppo player and run that thru the RME? I can try that I just think my RME is not set right it’s very confusing to operate around the menu settings
tuga
Oxford, England
I agree that it is confusing.
Yes, do try plugging the Oppo with the same cable.
Have you selected the COAX input (my remote has that option)?
A
AJG
I can try that but this is the screen where it should show it’s reading the bit rate
Jimbob54
That didn't answer the question as to whether you selected the right input on the rme (ie telling it to receive coax in)
A
AJG
Yes remote is set on Coax, also thanks for so much for trying to help me!. Gonna unplug Streamer now and plug into my Oppo CD player
A
AJG
Ok I’ve got the RME working thru the Oppo player
Jimbob54
Is there a setting on the Node to enable/ disable digital out? I doubt it but worth looking
A
AJG
Now that it’s working via Oppo should I just try and plug in the BluOS again?
A
AJG
Took cable out of Oppo connected back into RME….still nothing
gotta be something SIMPLE on RME settings sooooo frustrating lol
pjn
And check the output on the Node - it (as I recall) has to be told what to do! There's a default and a device option - although their user interface for setup is a nightmare. I usually just pull the plug, wait a moment and then plug it back in.
A
AJG
Ok will try thanks
tuga
Oxford, England
Can you plug the Oppo digital out into the RME in with coax?
A
AJG
Unplugged BluOS still not working arghhh!
